Question about Compaq Presario M2000 Notebook
LCD backlight not working
Something happened with the LCD backlight - the screen went black as I was working on the computer - and i restarted and rebooted many times but the screen was still black , but I could see a little bit - but it is too dark. I called a computer guy yesterday to have a look at my laptop .. but he said its a problem with the backlight
Hi.....It would appear your backlight has "blown" (it is just a thin,long bulb in the bottom of your screen)....It will need replacing ....Although you could purchase one yourself to fit it would be best to leave this job to a service engineer
Hope this helps
Posted on May 14, 2008
I was watching a movie and the sceen went black i had audio though.i restarted the computer and now no video black screen. did the video card **** out? video card is a nivia 8600 gt
If you are using a lcd monitor, it is very possible that your monitor backlight failed, have you tried connecting a different monitor to check your video adapter?
If the backlight failed, the image is on the screen, but is not visible unless you shine a light on to the screen
Feb 23, 2011 | Evga nForce 680i SLI (122CKNF68)...
Dell E173FP 17 monitor went dark and not working. I restart the pc it shows for only few second and went out again. I plug in one other monitor in my pc and it work fairly well. So something not right with...
Hi!
There are three possible cause why your monitor went black and start working..
1. If your monitor is dead set.. no reaction or lights turn on after power on.. then it needs to check if there is blown capacitor in its power supply section..
2. The high voltage ballast transformer of the backlight inverter is burned - it needs to be replaced so that it will not have a direct effect on the power supply section of the monitor.
3. The backlight inverters are all busted - the backlight was located at the upper and lower back edge of the monitor.. If these lights are busted then all that will be seen in your monitor is black screen.. It will need to be replaced so that image display will come out from your screen..
These 3 reason and its solutions can only be done by yourself if you have the knowledge, proper skills and the right tools to open the back cover of the monitor and replace the problem parts....
Otherwise, bring your monitor to a credible technician and if there is warranty,, avail of this...
Hope that answer your question..
Much appreciated if you rate this help..thanks..
May 20, 2010 | Dell E173FP 17" LCD Monitor
Screen went black
For laptops, there is a lighting source behind, called the backlight.
It may happen that only the backlight needs to be replaced.
You can figure this out by looking thoroughly via the LCD screen. As if only the backlight needs replacement, you will still be having display behind.
Otherwise you will need to replace the unit.
Mar 15, 2010 | Computers & Internet
How do i change my backlight for my sidekick 2008? My screen completely went black.
The problem with your sidekick 2008 screen is the backlight is burned out. this can happen if dropped or if it gets wet.
The only way to fix it is to replace the screen. It is fairly easy to do and new ones run about 65 dollars on ebay.
Below is a guide for the replacement and a link to buy the 2008 LCD screen.
Replace the Sidekcik 2008 LCD screen
Buy Sidekick 2008 LCD Screen
Nov 05, 2009 | Cell Phones
My Motorola Razr v3 cell phone's lcd is blank
unscrew it and change the flex to enable it view programms
Jul 17, 2009 | Motorola Mobility RAZR V3
Dell Inspiron B130 was black when turned on. Holding flashlight to screen, could see desktop and all icons. Was able to open programs, etc., while looking with flashlight. Replaced LCD Inverter listed for...
yes your lucky thing is this problem is LCD CCFL lamp worn, change a new lamp should be fixed.
hwo to change CCFL lamp, step by step:
1) buy a CCFL lamp from eBay, reference:
http://shop.ebay.ca/?_from=R40&_trksid=p3907.m38.l1313&_nkw=Dell+Inspiron+B130+CCFL+lamp&_sacat=See-All-Categories
2) take out LCD panel
3) open the back light cover and change the CCFL lamp, reference:
http://www.laptoprepair101.com/laptop/2007/12/09/replace-laptop-backlight-ccfl-lamp/comment-page-3/
hope help you fix it, please feedback any question any time, pleaae take a rating let me know how much helped you thanks!
May 28, 2009 | Dell Inspiron B130 Notebook
AL1715 Acer this really is annoying
Hi...there,
It's seems your monitor went into hybernation... Hehehe... Just kidding! :) Actually, you got a burnt out backlight inverter. It's time for a replacement. Good lucks, have a nice day!
Sep 19, 2008 | Acer AL1715 (Black, Silver) 17" LCD...
Help needed!
it's probably a problem with the backlight or the backlight inverter... i had the same problem just a little while ago. If your electrical components savvy, you might be able to find the problem on the inverter (which is on the side of the monitor once you get inside). Otherwise look into replacing the bulbs (which are on the top and bottom)
Dec 27, 2007 | ViewSonic VX900 19" LCD Monitor
My PC booted up the screen looked normal then as the windows boot up logo screen came on which is usually black with the logo in the middle, the whole screen went a sivery greay colour and then totaly...
You my friend have a bad backlight. Inside thes LCD monitors there a little tiny flourecnet lights that help the LCD project the images so that you can see what is being displayed. Sounds like your backlight has gone bad. These can be repaired, but can be costly! These things happen often times, 90% of the time I am replacing the backlights to various monitors. Sorry, but I am certain it is your backlight!
Nov 26, 2007 | BenQ FP731 17" LCD Monitor
Blank Screen Now.
Backlight is torched, it happens without warning. These can be repaired, but finding the appropriate backlights, and trying to get this thing apart is a royal pain in the you know what! But your backlight has burned out! Sorry!
Sep 30, 2007 | BenQ FP731 17" LCD Monitor
Compaq Presario M2000 Notebook Logo
129 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
