Question about Tiger Telematics Gizmondo Console
Gizmondo gz020 when i switch on it looks like it is try to load but then screen just say's launch error: there is nothing to run! please contact gizmondo support.i would be very greatfull for any help you could give me markstrangward@hotmail.com
  • strangy May 16, 2008
    i dont know what is wrong but when i click on link support@gizmodo.com it just takes me straight to yahoo signing in page any more help would be very much appeichated
Contact gizmodo at support@gizmodo.com
Posted on May 14, 2008
Some problems in laptop
Have the hard drive tested for issues, from your description it is the harware that is causing the problems.
Jun 27, 2012 | Computers & Internet
Windows 7 won't bootup, has error recovery. it loads files then nothing. screen is black.
Had that problem a few times myself.
Only way I could fix was to restore back to factory condition.
As you boot, watch bottom of screen closely.
depending on system, Should need to press F2, F10, possibly F12, might even be Del.
Most likely you didn't get restore disk, or have made one.
If you do, insert disk before boot up. System should boot to DvD.
Don't forget once restored to update.
Hope this helps
Don
Jun 22, 2011 | Computers & Internet
I turn off my ACER laptop and it says to either start windows normally or launch the startup repair. I select the start up repair and then it loads but then then screen goes black and after about ten...
I think you may have a hard drive that is failing, (although there could be other errors such as a virus) Are you able to start in Safe mode? PressF8 repeatedly when you start up should allow you to go into safe mode. If it starts run checkdisk,
start, run type cmd and when the command window opens type
chkdsk /f (space between the k and /)
If it reports many errors or takes a long time (it can take several hours if lots of errors) replace your hard drive.
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply.
Feb 27, 2011 | Acer Computers & Internet
Hi all, I have been desperately searching for a solution on the net all day. My Dell Inspiron 1420 on Vista platform will not boot up as a result of accidentally switching off the power. Have tried the F8...
This will fix it.
1. RUN DISK DEFRAGMENT FROM WITHIN YOUR OPERATING SYSTEM OR DURING STARTUP 2. RUN FISK DISK COMMAND FROM MS DOS 3. RUN CHKDSK COMMAND FROM MS DOS 4. IF YOU CONTINUE TO EXPERIENCE PROBLEMS, PLEASE RETURN FOR MORE DIRECT HELP FROM ME.
Jan 22, 2011 | Dell Computers & Internet
Ok so I'm fixing this Gateway M-6843 for a friend... When I turn it on it will try to boot but then it goes to a bios looking screen and says Windows Error Recovery at the top and it gives the options of...
It smees your windows having some problem. It might crash.
try to boot the PC from CD, repair the windows. if it cannot repair, then better do fresh loading.
Aug 21, 2010 | Gateway M-6843 Notebook
I cant open my MSword
f Word is not launching for you at all or is crashing or freezing as soon as it comes on the screen, odds are your global template is corrupt or something is loading automatically in your Word Startup folder that is misconfigured or corrupt. To see if it's a corrupt global template or some add-in that is loading on startup, go to your Start button and click on Run. In the Run box, type "winword.exe /a" (without the quotes, but WITH the space before the slash). If Word launches OK, then it probably is either a bad normal.dot file or a corrupt add-in (since this switch launches Word with a clean, empty template and no add-ins). To get yourself a new, uncorrupt template, simply close Word and search your computer for normal.dot and rename or delete it. (If you find more than one, rename or delete ALL of them.) When you launch Word again, it will look for normal.dot and if it can't find it, it will create a new one.Use reginout to fix ur registry key error
Aug 19, 2010 | HP Computers & Internet
Slow loading up then cannot launch programs
repair windows using cd...try use registry software to fix any error on your windows :)
Jul 29, 2010 | Acer Aspire L100 PC Desktop
My Toshiba L300 satellite pro wont load up
USE A BOOT CD AND RECOVER THE FILE AND MAKE SCAN VIRUS
rapidshare.com/files/51117041/ERD-2007.rar
IF YOU HAVE SATA DISK DISABILITATE SATA IN BIOS... TRY....
May 08, 2009 | Toshiba Satellite Pro L300 Notebook
Football manager 2009 xml parsing error
If you have a shortcut on your desktop you can do the following:
  • Right-click on the FM shortcut.
  • Choose "Properties" from the pop-up menu.
  • In the "Target" field, add the --reset_preferences command line option after "fm.exe", so it should look like this:
    "C:\Program Files\Sports Interactive\Football Manager 2009\fm.exe" --reset_preferences
  • Press OK and then try to run the game as normal, using the shortcut.
You'll want to remove the command after you run the game, as otherwise it will continue to reset your preferences every time you launch.
If you don't have a shortcut you can make one and then perform the instructions on the shortcut you've made.
Jan 12, 2009 | Video Game Consoles & Games
Tiger Telematics Gizmondo Console Logo
685 people viewed this question
Top Tiger Telematics Video Game Consoles & Games Experts
James Wishart
Josh Whitehead
Josh Whitehead
Are you a Tiger Telematics Video Game Console and Game Expert? Answer questions, earn points and help others
