Question about Sewing Machines
Pfaff quilt expression 4 It shreds thread when free machine quilting and will not cut threads with the cutter. I need to be able to fmq without worrying. I have had a new cutter and keep cleaning out the cutting place and the velcro type pad.
Hi,I was having so many issues with my Pfaff QE 4 until...I was told NO machine likes coats and clarks thread and I was choosing the correct setting sensormatic free motion, but foolishly not disengaging the idt in the back. Also, my dealer recommended that I change the pivot height to -2. So I along with all of this and trying Gutermann thread things are going pretty smoothly now!
Posted on Feb 11, 2012
    Genius:
  • 1,788 Answers
Are you using the right needles, size and type? Before, you wreck your material, take it in and have it serviced. I know everyone hates to pay for service, but if you like your machine it will be worth it to have it running at its peak. Just like a car, we spend tons on them but expect a sewing machine to never need anything. Remember, it is worth it.
Posted on Sep 13, 2010
How to Free motion quilting on Janome 1600P QC
Be sure to use a darning foot (or free motion quilting foot).
Use a brand new sharp needle, ie top stitch, embroidery, or microtex work well.
Check that the thread, needle, and fabric are compatible--Caution, the needle eye should be the right size for the thread weight.
AVOID old or bargain bin thread!
Be sure to drop or cover the feed dogs.
If your machine has it, use the needle down feature.
You may need to adjust the tension for FMQ--I have to tighten the bobbin tension a little to keep the bobbin thread below the quilt surface (so I bought a special bobbin case and set the tension for FMQ and that's all I use it for.)
Lots of web sites that talk about how to free motion quilt. Then, it's PRACTICE, PRACTICE, PRACTICE! I use a portable white board and draw free motion designs on it (while watching TV, etc.). The idea is to get it fluid without jerking, jumping, speeding up or slowing down, etc. When your hand and brain are able to work smoothly, then you can probably do free motion quilting. Practice on scraps of fabric and batting (preferably the same kind you will be working on). Cut up some 14 inch squares of fabric and batting and draw designs on them and see if you can stitch them. Some advice: don't watch the needle...look at where you are going in front of the needle. Don't expect perfection to happen overnight. Many quilters have been FMQing for years and still make mistakes. (I've made a few quilts and my stuff still looks less than professional, but it's all mine!)
Free Motion Quilting with Janome 1600P sewing discussion topic...
All About Needles
Jul 23, 2017 | Janome Sewing Machines
CANT QUILT WITH MY JUKI TENSION PROBLEMS
Okay, you've tried a lot of things. The question is this: is the thread snapping (where abouts in the path), or is it shredding at the needle? Here are a few more:
Remove the top thread, ALWAYS RAISE the presser foot, and rethread from the beginning.
Try different thread--perhaps a polyester thread like Isacord or Aurafil. (AVOID old or bargain bin thread.)
Try a different kind of needle (brand new needle!)--like a top-stitch, microtex, or embroidery. The top stitch needle has a larger scarf that will better protect the thread if shredding is the issue. (I use a special bobbin case that I've increased the tension for Isacord thread and I use the same thread in top and bobbin.) I also decrease the top tension a tad so the bobbin thread will not pull to the top. You may need to install brand-new needles several times on one quilt when they get dull.
Usually an 80 or 90 needle will work for FMQ through a fabric/batting sandwich.
Check that the needle's eye is the appropriate size for the thread (also a cause of shredding thread).
Set the upper tension at the midway point perhaps a bit looser for FMQ (this tension will probably need to be tweaked for your particular machine due to wear and age).
Use an FMQ foot and drop the feed dogs. A Supreme Slider (avlb on the internet) is very helpful in helping move the quilt while doing FMQ.
Work at a moderate but steady pace. I find a faster speed while FMQ gets me into trouble...like spots I can't get out of, overlapping stitches, or outside the quilt edge.
FWIW, I still get some skipped stitches with FMQ. Usually, it happens when I move the fabric too fast, especially around a curve. I have a tendency of speeding up while going around a curve that will cause skipped stitches or eyelashing.
I'm also wondering if there is something to do with the fabric and/or batting you are using...like is it Batik? Batik is very tightly woven and presents some particular challenges. The type of batting could be more dense, making it harder for the needle to penetrate the sandwich. Also, pulling or stretching the fabric can cause skipped stitches.
Basic Maintenance Tension Skipped Stitches
Here What to Do if Your Sewing Machine is Skipping Stitches
10 reasons for skipped stitches
If you see no improvement in your machine's stitching, you may want to have it serviced.
Apr 28, 2017 | Juki Sewing Machines
What number is satin stitch on Piaf quilt expressions 4.0
A satin stitch is simply a zig-zag stitch that is shortened enough so the threads lay next to each other without laying over another but also without any space (fabric) showing between. Keep in mind that the thread weight will cause the satin stitch to differ.
Sewing Perfect Satin Stitch Wildly Wonderful Wearables Patterns Notions...
Feb 19, 2017 | Sewing Machines
My new Quilt Expressions 4.2 sews fine when I piece but when I fmq I have problems with thread shredding How to fix?
Shredding thread could be several things. First, make sure the thread and needle are compatible. If the needle's eye is too small for the thread, it will eventually shred the thread. There are also needles with larger scarfs that will protect the thread from shredding as it repeatedly pierces fabric. Also, trying a different brand/type of thread may make a difference--focus on good quality thread for fmq. The tension may be set too tight. Finally, there could be a burr or snag somewhere that is causing the thread to shred.
All About Needles
Machine Quilting Thread Shreds Then Breaks
Dec 17, 2016 | Sewing Machines
Janome 1600P DBX
You need to drop the feed dogs, install a darning or free motion quilting foot (make sure the presser foot is lowered). Because you will not be using the machine to move the fabric, the stitch length selection is of no importance. Make sure the stitch width is set to zero. You should test FMQ on a scrap quilt sandwich of the same makeup of your project, ie quilt fabric with batting sandwiched between. The upper tension should be set so that both threads meet in the middle of the quilt sandwich. Because it is FMQ, some extra adjustment may be needed.
Once the tension is where you want it, you can practice FMQ until you can move it smoothly in conjunction with the machine speed.
Practicing on a white board with erasable markers is a handy way to learn to move smoothly. The most difficult part of free motion quilting is learning to move the fabric smoothly. Do NOT lack for practice as that is the only way to improve. Those people who make it look simple have been doing it for years!
How to Free Motion Quilt on Regular Sewing Machine
Free Motion Quilting for Beginners Part 1 Video from Sewing with Nancy
Learn How to Free Motion Quilt Stippling
Oct 31, 2016 | Janome Sewing Machines
Pfaff quilt expression 4 0
The top thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
8. Try a different spool or cone of thread
Aug 23, 2013 | Sewing Machines
Janome 1600 thread shred and breakage
could be a bad section of the thread
check for burrs around the needle plate area and also in the bobbin
area and on the thread guide close to the needle.
The needle thread breaks
Dec 09, 2012 | Sewing Machines
Thread breaks
If the thread is feeding from the spool without hanging up, the problem is within the threading system.
If this machine auto-threads, try to manual threading.
Call your dealer and tell them what is happening and you need their assistance. The machine may have to be serviced. Take a sample of the problem with you.
Too many bells and whistles can sometimes be, too many bells and whistles!
Mar 14, 2010 | PfaFF Sewing Machines
Just bought a brand new Pfaff Quilt Expression 4.0 and the top thread keeps getting shredded and breaking while doing free motion quilting. I've checked threading diagrams, changed to four different...
this is a known issue with the pfaff.....i have just bought the machine and it has thread uptake issues...thread tension issues and it comes unthreaded by itself often...leaving globs of thread on the bottom stuck in the feed dogs and under the throat plate.....then the stitches are not properly balanced because the tension gets too loose on the bobbin thread....very disappointed to find out it is a known issue with all the viking husqvarna made machines...which are pfaff, janome and viking.....sux.
Oct 21, 2009 | PfaFF Sewing Machines
Cannot machine quilt without the thread breaking and/or shredding. I've change needle, thread type and size and tension on my fabric.
If the thread is shredding and breaking, there is an incompatibility of your needle, thread, and fabric. Could be old, bargain bin, or poor quality thread--does the thread have little "hairs" of thread lint sticking out of it--that's probably not good quality. Look for fresh, good quality thread. Try a brand new needle--a sharp if you are sewing woven fabric. Make sure the thread is not too big for the needle eye. Sometimes, a top-stitch needle or embroidery needle will work well on FMQ. (A top-stitch needle has a longer scarf which helps protect the thread during the multiple times the needle penetrates the fabric before the thread forms a stitch. Shredding means the thread is getting worn out before it forms a stitch. A piece of thread penetrates the fabric 10-20 times before it forms a stitch.) Could also be a snag somewhere that is damaging the thread.
Sewing Needle Troubleshooting Guide
SCHMETZ Household Needle Chart
Most FMQ instructions say the upper and bobbin tension should be the same, however, I find my machine works a bit better when the bobbin thread is just a little tighter than the upper thread. Then the bobbin thread does not "pop" up on the top of my fabric quite as much. It's probably something you will just need to experiment with in getting used to your machine.
P.S.--when threading your machine, make sure the Presser Foot is ALWAYS RAISED so the top thread will seat properly in the tension disk. Failure to do this will cause thread barfs (usually referred to as thread nests or bird nests) under your fabric. Also, before beginning your FMQ, ALWAYS PULL the bobbin thread to the top of the fabric, then hold both thread tails gently in your left hand while you slowly take the first couple of stitches.
How and Why to Bring up the Bobbin Thread
Mar 01, 2017 | Brother Sewing Machines
Sewing Machines Logo
421 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
