Question about Coleman Powermate Premium Plus 6250W Portable Generator
Operating manual for a Wolf Model 950 Generator
Pull start
In all honesty, if it came loose once it will again. There are videos on YouTube showing how, but it is a real pig of a job to do, and the damaged to the spring or housing that made it fail could do it again (inspect).
Alternatively, you can replace it with a new complete Recoil. Parts Spares for Generators and Small Engine Machinery
Dec 26, 2016 | Electrical Supplies
Wolf. Why doesn't it stop running?
The on-off switch may be functioning mechanically but not electrically. A continuity test while operating it can confirm the malfunction.
Feb 19, 2016 | Electrical Supplies
Hi we have a wolf 950 generator that wont start,cleaned plug,is there anything else i can try,HELP!
are you getting spark. pull out your plug and with the wire connected. hold the plug about an 1/8 of an inch away from any metal on the motor and ensure your getting spark. also check to ensure your fuel is not bad..
Aug 14, 2011 | Wolf Manufacturing Electrical Supplies
Wolf 800 generator. Engine will run but very electrical power is
is the engine running at the correct speed
3000 rpm to produce 50hz
3600 rpm to produce 60hz
Mar 06, 2010 | Electrical Supplies
No spark on my Wolf 980 generator, 2-stroke. Any repair manuals availabe, please. Regards, Dennis Byatt.
If your generator has a low oil sensor, it will not allow spark. Make sure your oil level is correct and it may work. My generator has one of those.
Jan 29, 2010 | Electronics - Others
Have a Wolf Range Model A-6-9 half the burneres don't light.
I have the same model Wolf Range and need 2 of the Robertshaw SM4 spark modules for it. Robertshaw says they are discontnued. Where can I locate 2 spark modules?
Jul 10, 2009 | Wolf Range Kitchen Ranges
Coleman Powermate Premium Plus 6250W Portable Generator Logo
1,143 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Shawn DuRee
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
