Question about LG DBRH197H DVD Player/HDD Recorder
I have a lg dbrh 1979 model and the dvd will not recognise any disk. The same thing happened before and I needed to replace the dvd player/burner at a large cost. My question is what dvd burner can I purchase and put in myself to save on costs. Ps have tried cleaning the lens and still doesnt work
dsom
  • 56 Answers
SOURCE: DVD player cant read DVD media
.Vob files contain audio, video and subtitles all together.However, most MPEG-2-capable DVD players don't support subtitle tracks. I guess your DVD player is in the mentioned majority. That's why you can only play them in your computer drive.
Posted on Apr 24, 2007
  • 32 Answers
SOURCE: No disc
This is a power supply problem.Not enough or too much B+. I found the problem but the part is hard to find, no subsutation for part because I deal with famous ECG transistor subsutation manual. The original is a japanise company that went out of business Even if I could help u with the part, u would have to get a tech to do the repair.
Posted on Sep 26, 2007
SOURCE: my DVD recorder won't play my CDs
Recently purchased a unit... You can imagine the joy when I found in Manual: Audio discs can only play if in .mpg or .wma formats! Yes, all the bells and whistles except the most basic of functions such as all common audio formats. Other portable $99 dvd player works with them.
Posted on Mar 16, 2008
SOURCE: dvd player stuck in 'demo repeat mode'
Hold the Stop button for 5 long seconds
Posted on May 06, 2008
  • 104 Answers
SOURCE: my dvd player, lg rc7oon, doesnt recognize any dvd
There are three things you can do that will eventually give you a working solution. Depending on the level of problem. Start with 1 progress to 3 until it works.
1. Use a cleaning disc. (one that use an alcohol based liquid)
2. If the cleaning disc does not solve it, you can use an ear bud, with some iso-propyl alcohol to clean the DVD lens on the drive directly. (you have to open the player and the drive)
3. The guaranteed working solution is to replace the DVD drive inside the player. This is quite a simple process, as most players use a standard IDE DVD-ROM or DVD writer.
You simply remove the face plate, (apply power to the drive, and press eject first) the tray will open. Unclip the tray face, and then with the tray open you can unclip the plastic face plate too.
Remove the old drive, and fit the new drive by reversing the removal procedure.
Once everything is assembled you should be able to watch DVD's again. If you can't find a cheap DVD drive locally, try ebay.
I have done this on over 50 players for my clients in the past. I use LG IDE DVD roms and IDE DVD writers for the DVD recorders, irrespective of brand.
Let me know how it goes.
Posted on Feb 28, 2010
Lg dvd instructions
you need the drivers for it to be recognised by the pc its not a plug and play device
Dec 07, 2013 | Televison & Video
My LG RH397D HDD wont recognise dvds any more
The only thing you can do is try a DVD cleaning kit and follow instructions, if that fails the laser pickup assembly will need to be replaced, but this would be to expensive and far cheaper to replace the player.
Mar 27, 2012 | LG Televison & Video
DVD wont recognise disc
If your DVD drive don't show up in device manager and if there's no yellow exclamation mark in device manager, try to check IDE or SATA cable connection from your DVD drive to the motherboard. Also check the cable itself (are the wires inside broken?)
Feb 01, 2010 | LG GSA 4163B DVD±RW Dual Layer Burner
Cd/dvd burner will only recognise blank cd discs not blank dvd discs
Find some "older" blank DVD-R, or DVD+R, or DVD-RW disks, and insert them.
If they are recognized, then access LG's web-site,
and look for a downloadable "firmware update" for your model.
The newer firmware adds support for "newer" DVD media.
If all else fails, replace the CD/DVD device.
Nov 06, 2009 | LG GMA-4020B Super-Multi...
My LG GSA-H55L super multi DVD rewriter seems to suddenly have a problem recognising disc. I am using the same discs as before (same batch) but now it always tells me no disc.
have you tried a cleaning disk?if not get some cleaning alchol wipe the disk leave a little on it not much,insert the disk ,this might clean the lense.
Sep 11, 2009 | LG 20x8x20 GSA-H55L Super-Multi Disk...
PC will not recognise new DVD Burner
if the recognized it then the wizard will not appeared. u need to install application software for burner like nero, alcohol etc
Nov 27, 2008 | ASUS P4B533-VM Motherboard
DVD recorder model DBRH 197 will not play zone 1 DVDs, is there a solution for this.
1. Power on
2. Open DVD tray
3. Press HOME
4. Select/choose SETUP
5. Use arrows to move to LOCK icon
6. Press 0000000 (press the number 0 (zero) seven (7) times)
- You get the REGION FREE message
8. Confirm OK
OR
Insert a non compatible dvd disc, when the dvd player spits it out again press 0 seven times and the dvd player will congratulate you on making it regionfree.
Aug 08, 2008 | LG Televison & Video
I have a LG dvd player, model DBRH 197, just over a year old & currently will only either turn on or off by both remote & actual player control panel. There is a disc in the slot, which I cannot...
Thanks so much but since this is the second problem we have had in 7 months with this equipment we have decided to replace with a more reliable model!!
cheers Ratory.
Jul 17, 2008 | LG Televison & Video
Dodgy DVD burner
After completion of recording in the DVD, you have to finalised the DVD then after u can read with other devices
Jun 02, 2008 | LG RH1999H DVD Recorder/HDD Recorder
Dvd rewriter
may be some dust in ur dvd drive man ...just try to clean u r lens  by a lens cleaner disk..which is ablable in market with a liquid...
best regards & best of luck..
even u can mail me at my mailing add- sigma_shiva1@yahoo.co.in
Oct 12, 2007 | LG GCC 4320B CD-RW/DVD-ROM Burner
LG DBRH197H DVD Player/HDD Recorder Logo
51 people viewed this question
Computer Repairing
Computer Repairing
