Recommendations for power strip, etc. for HP Slimline
I'd like any recommendations for a power backup system for my HP Slimline s3100n. I currently have an APS brand power strip (bell shaped one) that's about 7 years old. Should I buy a different power strip, or a UPS or surger protector. I am using a cable modem, and lightning is one of my concerns.
  • 101 Answers
Hi when you buy a power strip especially to prevent lightning strikes ensure that the power strip has gas tube protection alongwith the usual MOV and Fuse
Posted on May 15, 2008
Hello, I have a HP Pavilion s3100n and at first it worked fine until according to Geek Squad at Best Buy said it was my motherboard, so HP replaced it and it worked great until now im haunted yet again...
If you don't see power indicator turned on or neither listen to CPU fans working, maybe the power supply is failing now, you could claim your warranty again if it's into the valid period, you could also check that all cables of your computer are securely connected.
Feb 27, 2011 | HP Hewlett Packard Pavilion Slimline...
My hp s3100n slimline, the screen stays blank but the power come on. The CD spins and the hard drive but there no startup information on the monitor. Please I would be willing to send a small donation to...
Go to this LINK.
i only post the link because there arre several steps to try to resolve your quest.
If you need more help come back.Post / thumbs / testimonial are welcome!
Dec 12, 2010 | HP Hewlett Packard Pavilion Slimline...
The on/off switch does not return to the front when switched on. Seems as if the spring behind the button is weak
jnorsworthy I don't know if the design still holds the same for the Power On switch in the Slimline S3100N, as it does for the Power On switch designs I am used to.
[The Power On switch is located inside the plastic Power On button ]
The one I am used to;
1) Has a square block like shape.
2) The square block is composed of two halves. The two halves fit together like a clamshell.
A) A metal cover with a hole in the center for the top half.
B) A plastic block for the bottom half.
Inside there is a 'plunger', if you will.
The plunger, or post, moves up, and down.
The post is allowed to move up, and down through the hole in the top cover.
The plunger presses against a thin, flat, disk, convex shaped piece of spring metal.
The outside edges of the metal disk are connected to one side of the Soft Power On circuit.
As the plunger is moved down (By the action of pressing against the Power On button), the metal convex shaped disk flattens out.
In the center of the plastic base is the other side of the Soft Power On circuit. The center of the flattened out metal disk touches a contact in the bottom, of the plastic bottom half of the switch.
When the Power On button is released, the disk goes back to the convex shape.
This generic ATX power on switch, is an example of the type of Power On switch I am referring to,
You may find the above generic example is a replacement for the one in the Slimline S3100N.
This is HP Support, the support page for the HP Slimline S3100N desktop computer, and the Manuals page,
On the above page scroll down to the heading - Upgrading and Servicing Guide, and left-click on it.
(It's a PDF file, and may take a few seconds to download. May take a few seconds before you see the first page)
Shows how to open the computer case, and remove the Front Panel. (Front Bezel)
Computer unplugged from power, Observe Anti-Static Precautions.
Anti-Static Precautions:
Your body carries Static electricity.
Static WILL fry out (Short Circuit) the hardware components inside a computer.
1) Work on a table
2) Computer unplugged from power, computer case open
3) TOUCH the metal frame of the open computer case to relieve your body of Static
4) If you leave your computer in the middle of working on it, be SURE to touch the metal frame again upon your return.
Most Power On button assemblies have two tabs, or three, that protrude out from the body of the assembly. These tabs snap into place into the metal frame of the computer case, and into a rectangular hole. They have a hook on one side. Gently squeeze the tabs in, or out. Depends on which way the hooks face.
The plastic Power On button assembly generally has tabs that hold the Power On switch in place. These tabs are eased over to allow removing the Power On switch. You may find that the plastic tabs are brittle due to age, and the heat inside the computer through the years.
You can use a hair dryer set to low heat, and wave the hair dryer slowly back, and forth to soften the plastic.
Motherboard information:
Oct 08, 2010 | HP Hewlett Packard Pavilion Slimline...
How do i reset my HP provillion slimline s3100n pc back to factory setting without a recovery cd
you cannot recover or reset with out a recovery CD
just format it and install a fresh copy of operating System
Aug 29, 2010 | HP Hewlett Packard Pavilion Slimline...
Looking for any complaints regarding the motherboard for the HP Slimline s3100n.
HERE is a whole site of listed complaints regarding the computer you listed. HP Slimline s3100n. I hope this helps and is what you were looking for.
Jun 22, 2010 | HP Hewlett Packard Pavilion Slimline...
Freezing upon boot
restart and tap F8 key, if loads to repair your computer/Advanced boot option, select safe mode using the down arrow key and log in to your account, create a backup of all the data on a removable storage device.
Insert System disk and run a system recovery to the original fcty setting, if backup done, restore from the removable storage device.
Jun 08, 2010 | HP Hewlett Packard Pavilion Slimline...
My HP Slimline s3100n pc crashed and will power on but nothing shows up on the screen. How do i fix this?
Are you able to enter the BIOS ? If no then it's a major hardware failure, most likely the motherboard. If yes then check that the hard disk is still recognized; if it is then reinstall (or Repair, if you are bold) Windows and try to identify the cause of the crash - start by testing the hard disk using HDTune.
Mar 29, 2010 | HP Hewlett Packard Pavilion Slimline...
Slimline s3100n keeps shuttubg down
scan for viruses. maybe it is infected. if still, do the recovery options for hp.
Mar 08, 2010 | HP Hewlett Packard Pavilion Slimline...
HP Pavilion Slimline S3100n keeps shutting down to powersave
It may be a virus or trogan problem. DO clear the Internet explorer cache and browsing history. remove all unwanted programs using add remove programs. please reply to me if u can solve with thos solutions
Apr 06, 2009 | HP Hewlett Packard Pavilion Slimline...
Computers & Internet Logo
109 people viewed this question
David Payne
David Payne
