Question about Bosch 24 in. SHU43 Built-in Dishwasher
Bosch Dishwasher Dishwasher is about 6 years old. It recently stopped cleaning the top rack of dishes. It is getting water to the top propeller, but not with enough force to make it spin. I have checked the tubes running up top and they are not clogged. Could the pump be going bad?
  • 1 more comment
  • usbturbo May 17, 2008
    (Bosch shu3322uc/12)Dishwasher is about 6 years old. It recently stopped cleaning the top rack of dishes. It is getting water to the top propeller, but not with enough force to make it spin. I have checked the tubes running up top and they are not clogged.since the arm does not spin the soap is not getting dispensed. Filters are also clean. Could the pump be going bad?
  • dadfisher May 23, 2008
    I have the same problem. The top spinner does not seem to have enough water pressure to make it spin and the soap is not being dispensed. The filters are clean. The dishwasher is about 6 years old.
  • raejon May 26, 2008
    We have the same problem with our Bosch SHU43 dishwasher. I will try your suggestion but need to know = where's the filter? and how do you replace it. Thanks
Your filters need to be replaced. it's a 10 minutes work
Posted on May 14, 2008
Asko 1996 appears "dead".....no lights flashing, won't respond to repeatedly pushing on/off button. Some water left in the bottom...siphoned it out, cleaned filters, no blockage there. Almost like it's...
Don't know if this will help, but my dishwasher has a "propeller" device above the top and bottom racks that spins while dispensing the water. If the dishes on either rack are stacked too high (i.e. if even one plate comes in contact with that propeller, keeping it from spinning properly) the dishwasher will go through its full cycle but will not use the soap (soap door will still be closed and soap packet still intact) and will not get the dishes clean.
However, it sounds like you either have a bit of a drain issue as well--or perhaps your dishwasher acts the same way as mine (if that's the case) but ceases to drain as well if blocked.
Jun 26, 2010 | Asko D1996SS Built-in Dishwasher
TOP RACK NOT CLEANING DISHES
Possible that the motor impeller has good particles in it, causing poor water pressure, which would be most evident on the top rack. You would have to remove the spray arm, then the filter, then the torx screws to get at impeller....unfortunately, that model of dishwasher isn't the greatest in the first place for washing, since it only has the one spray arm.
Apr 04, 2010 | Frigidaire 24 in. FDB126RB Built-in...
Bosch SHU 8805 upper arm is getting no water.
replace the upper water arm conduit and wash arm hub as they leak under years of pressure and the o-rings leak water and then it can't hold pressure and supply the upper arm with full pressure water,also replace the center arm conduit if it has one as this will wear out too
Mar 23, 2010 | Bosch 23 in. SHU 8805 Built-in Dishwasher
Mold grows on dishes in bosch dishwasher
Put a bowl filled with 2 cups of clorox on the lower rack and run a wash cycle (nothing else in the machine) this will kill the mold spores in the machine, and clear the smell.
Jul 29, 2009 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
The water will not drain from dishwasher. What should I do?
Mar 18, 2009 | Asko D1716 Built-in Dishwasher
ASKO MODEL 1996 WILL NOT WASH DISHES
Mar 14, 2009 | Asko 1996FI Dishwasher
Kitchen aid dishwasher doesn't clean dishes in the top rack
Sounds like you have 1 of 2 problems. Either your pump is clogged or you need a bigger drain loop.
Nov 25, 2008 | Dishwashers
Bosh dishwasher shu3322uc/22
check for leaks where the the top rack plugs into the rear. it might not be sealing. If your unit has the ability to change the top rack height check in the other position and see if it works. In my Samsung (Bosch in disguise) model The tube to the top rack plugs into one of two holes in the rear, depending which rack position I use. Something covers the hole not in use. Bosch uses two seperate pumps for washing and draining. So I don't think the pump could go partially bad. (This happens in other brands when the solenoid gets stuck between pump out and recirculate)
May 17, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishes are not coming out fully clean
first if the pump is running and you can hear it washing it should clean now hot water cleans dishes not the washer the hotter the better at least 130-135 degrees modern dish washers use less water than older models so if you don't get the water as hot as you can stand it at the sink before you turn the washer on you can fill it with cold water second its important that you use jet dry and if your dishes aren't dry at the end of the cycle then on most washers you can turn the disp up for more hope that helps let me know
Dec 01, 2007 | Bosch 24 in. SHU53 Built-in Dishwasher
Bosch 24 in. SHU43 Built-in Dishwasher Logo
225 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
