Question about Dell E176FP 17" LCD Monitor
The moniter goes into an energy saving mode when the computer is being booted. It sometimes takes sereral attempts of restarting the compujter to finally get it working.
    Guru:
  • 126 Answers
It will happen when your are using two VGA card adapter plug-in into your computer. The one is built-in and the other one is plug-in into AGP or PCI-Express slots.
Experience with monitor goes into energy saving mode is that try to check inside your VGA card is working properly.
Posted on Sep 12, 2010
Moniter randomly changes resolution after being unplugged and plugged back in.
Restart your computer
During the boot process you will see on the screen to press a certain key to enter setup usually the delete or F2 key
Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart if this fails to fix the problem
During the boot process tap the f8 button three times this will boot into safe mode where the only things working will be your mouse and keyboard enabling you to attempt to repair your computer
you could select the option start at last known configuration that worked this will tell what file has been corrupted or missing you might be able to work your way through problem if you are unable to find a solution
restart back into safe mode you might need to select your operating system to load into safe mode
click start control panel administration tools computer management in the left panel events + to expand then system you will see all errors in right panel right click select properties this will tell you what has occurred and the time it occurred
you might use the system restore to restore your system to an earlier time
click start all programs accessories system tools you should see your system restore option
hope this helps you
Apr 09, 2012 | ViewSonic VA1916w LCD Monitor
My E520 Dell shuts down in to the energy save mode after 1 minute of booting and then the high speed fan comes on and screen goes black
off the energy save mode...it goes revert of ur action...re-install opreating system..is it work? clearfy
Mar 16, 2012 | Dell Dimension E520 PC Desktop
Monitor goes into power save mode as soon as I fire up my computer. Help!
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
or
hope this helps
Aug 18, 2011 | Computers & Internet
Computer will not boot up, only goes to the windows error recovery page, options to start repair or windows normally, none work it goes back to the same page...
or
hope this helps
Jan 07, 2011 | Acer Aspire One PC Notebook
My laptop moniter turns on as usual with the proper reading. I start in safe mode as normal..wait about 10 min and screen goes white
hello
"I start in safe mode as normal."
safe mode is not a normal thing during your windows boot sequence :)
if your display works ok until those 10 minutes of safe mode are over i would say that reinstalling your windows operating system will most likely solve your monitor issues :)
Mar 24, 2010 | Princeton Digital LCD17 17" Flat Panel LCD...
Oversize Message
dear,
run the system on safte mode and then try to manage your screen resolution to minimum and then restart it normally..
regards,
dont forget to rate
Jun 20, 2008 | Kogi l7eh-ta ko 17" Flat Panel LCD Monitor
Flatron L1719S
I think your monitor is unstable. Is it showing power saving when you boot your PC? Does it show something when the Windows XP splash appears?
Jun 05, 2007 | LG Flatron L1750S 17" LCD Monitor
Moniter activation when turning on the cpu
RESETTING DRIVERS with new Video CARD- Start the computer in SAFE MODE (Hold Shift F5 when restarting PC) Go to Control Panel> System>Hardware>Devices - Remove the Old Card Driver (under Video) Press OK (and then Exit) Put the Driver disk in PC - Restart Normally Option 1 When your system reboots it will be in 640x480 16 color mode ignore any prompts. Run Setup from the CD/drivers disk Reboot Windows restarts with corrected drivers Set the Screen Resolution to your choice typically 1024x768 Option 2 When your system reboots it will be in 640x480 16 color mode When your are prompted for the drivers BROWSE the CD/drivers disk- (usually \drivers folder) Select your card from the Mfg list Press OK, OK Reboot Windows restarts with corrected drivers Set the Screen Resolution to your choice typically 1024x768 **Note - there is no shortcut you have to reboot when prompted, especially in safemode. Good Luck Remember to let us know and rate the answers. otherwise theres not sense in answer questions, if you don't know if it helps anyone.
Oct 12, 2006 | E-Machines W4885 PC Desktop
Dell E176FP 17" LCD Monitor Logo
120 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
