Question about Dell UltraSharp 1704FPT 17" Flat Panel LCD Monitor
My dell lcd 1704fpt serial ports doesnot work
  • 11,361 Answers
Can you please verify the serial port? There is no serial port on the monitor.
http://s807.photobucket.com/albums/yy352/budm/Dell%201704FPT/
Posted on Sep 13, 2010
Help, can't seem to get the USB ports on my monitor to work again. I have the following dell monitor 1704fpt 17in. running windows XP Pro sp. 2
Since the USB ports on this monitor are just the powered USB Hub, you should try it with another PC if you know for sure that the USB port of the PC taht is feeding this Powered USB Hub on the monitor are OK, also check the cable.
The USB board replacement for thsi will not be woth it. Also check for 5vdc on PIN1 of the USB port.
http://s807.photobucket.com/albums/yy352/budm/DELL/Dell%201704FPT/
May 05, 2011 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Can I use the USB ports on the left side of my Dell 1704FPT monitor to connect devices? (e.g., Logitech webcam)
yes you can use the usb port but let me tell you one thing very clearly there is problem with these ports either they dont recognize your usb or maybe your monitor screen flickers... so use monitor port with a lot of care and i advised you to atlest read the manual before you do anything.
Jan 08, 2011 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Why don't the ports on the monitor work?
This monitor has 8-port USB hub that the USB input of the monitor must be connected to the PC USB port. There are fuses for the USB port also to protect the 5VDC output at the USB ports.
Document:
http://support.dell.com/support/edocs/monitors/1704fpt/en/about.htm#Specifications
May 12, 2010 | Dell 1704FPTt 17" TFT LCD Flat Panel...
Dell 1704FPT won't come on at all. Only the sound
  • Check connection integrity at both ends of the video cable
  • Ensure the monitor and computer are plugged in to a working electrical outlet
  • Ensure power button depressed fully
  • Press the input select button the front of the monitor and ensure the correct input source is selected
  • Increase brightness & contrast controls
  • Perform monitor self-test feature check
  • Check for bent or broken pins
  • Re-boot your computer and monitor.
Jan 17, 2010 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Dell 1704fpt usb ports: how do you find the
you should not need drivers for a usb port is the cable hooked up ? if so they are probably broken
Nov 27, 2009 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Dell 1704FPT LCD will not turn on.
The adapter you have been using might be faulty. Make sure the cable is inserted fully. If that does not work, try the VGA or the DVI adapter you have not been using. Verify also the socket to which its connected (the power source) is not faulty either.
Hope it helps.
Aug 29, 2009 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Dell 1704FPT Flat Screen Monitor USB ports
you need to run the usb to your computer first have you done that
May 08, 2008 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Pink tint on Dell 1704FPT Flatpanel LCD
The monitor is broken. The circuits that generate green in the RGB setup are not working. If its under warranty, replace it.
Apr 23, 2008 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Dell 1704fpt Screen turns white
ok,your monitor has a defective vertical ic.when vertical ic is defective you can see the horizontal line.
Oct 18, 2007 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Open Questions:
Dell UltraSharp 1704FPT 17" Flat Panel LCD Monitor Logo
69 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
