Question about Garden
How do i adjust talon cs38 chainsaw chain please
    Brigadier General:
  • 4,088 Answers
Loosen the bar retain fasteners to finger tight, then turn the chain adjustment screw to bring the loose chain just up to the bottom of the lower bar and have slight tension. Tighten the bar fasteners and check to see if the chain can be turned by hand fairly easily, but not droop from the bar. Make sure it is being oiled properly by running the bar tip at speed for several moments near some cardboard--it should throw off a thin line of oil. Hope this helps!
Posted on Sep 14, 2010
Need a new Talon Chainsaw sprocket for 35cc 35cm Timber Hawk AC3100-35C
most chain saw chain sprockets are either 1/4 or 3/8" pitch
in your case I would suspect it is 3/8 pitch
measure the distance between the link pins ( not the teeth but the pivot pins of the chain itself )
after that the sprocket will be available as a generic sprocket from any chain saw shop or mower shop
Talons went bust but are being reproduced under a new brand name ( ozito I think)
Jun 28, 2016 | Talon 219 Kart Sprocket 62 Tooth
What size chain do I need for a McCullough MacCat CS38?
Chains have three requirements...pitch, guage and number of links. The pitch is the distance on center between chain links, the guage will be one of three, .043, .050 or .063. To get the number of links, you have to count each link and spacer. If you are missing the chain, you may have to take the saw to a service center and have them tell you.
Sep 27, 2014 | McCulloch Garden
Spear & Jackson chainsaw CS38 cuts out after
There are a couple possibilities. Your Carb adjustment is off or your fuel system is clogged up. On the Carb. there is an L and R you want to richen up the R side adjusting it a quarter turn counter clock wise. If this doesn't solve the problem check your fuel lines and filter. If there is a small tear in the line all the dirt and dust will go into the Carb and stick to the screen inside the carb body. Hope its the first one. Good luck!
Jan 22, 2013 | Garden
Where do i get a chain adjustment screw for Talon A3100 38CC Chainsaw???? in Melbourne, Victoria, Australia
Other brands will work.Or any screw with the right threads to fit the adjuster pin and is long enough will also work just fine.
Mar 03, 2011 | Garden
Where can I find a lower spring mounting for a Spear and Jackson cs38 chainsaw.
They appear to be well constructed, I wish they were available here.
If purchased at Einhell an OM may be found here:
Spear & Jackson
http://www.einhell-uk.co.uk/index.php?id=2&br=7&sb=11
Please click the "Spares & After Sales" link for parts.
If purchased at ARGOS there is a phone number mid page.
Spear and Jackson UK
http://www.spear-and-jackson.com/en/contact-us
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Jul 15, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
I need the part number for the chain adjuster for a mcculloch chainsaw model number cs38
You were a little short with the model number, I think this is what you are after. The IPL for a SCS 38-35 H follows:
http://weborder.husqvarna.com/order_static/doc/MIPL/MIPL2005/MIPL2005_VP0502007.pdf
Page 6;
item 39 is the screw
item 37 is the bar adjustmeny nut
item 38 is I think an e-ring
If I missed on the model please expand some and reply below. I will get back to you. Good Luck. HTH
Lou
Feb 24, 2010 | McCulloch Garden
Talon electric chainsaw, what grade oil?
Hi there... Electric chainsaws only use bar and chain oil. If you go to a hardware store or garden power tool outlet, you will find bottles of bar/chain oil. That is all you need. Just fill the reservoir up and top up as needed. Any decent brand will work well.
Feb 17, 2010 | Talon Electronics - Others
Talon petrol chainsaw ac3100, bar lurication
Talon chain saw wont start, have spark, but fuel drips from exhaust when attempting to start, saw only used a couple of times any suggestions?
Sep 21, 2009 | Garden
Talon oil feeder wont oil chain 38cc tree hawk
hi
first check the oil filter from the oil tank,the oil hose,remove the oil pump and check it(especially the plastic gear inside,if it worn is because of the bearings from crankcase).Clean the holes where oil goes.
bye savumihai71
Jun 08, 2009 | Garden
Garden Logo
265 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
