Question about Zojirushi CD-LCC30 Electric Kettle
I brought US rice cooker to Europe and despite converter the fuse went out
  • enkhjaki Sep 12, 2010
    btw both the electric kettle and rice cooker are broken due to wrong voltage.
    is there way i can fix both the rice cooker and electric kettle
    and then use the right converter?
  • 10,515 Answers
Replace the Fuse. If it keeps blowing, then it has a short in it or just a loose wire from the heater. Open and check. If you have an ohm meter, check the heater. The reading should not be infinite.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Sep 12, 2010
  • 19,396 Answers
If the fuse is blowing, that means that the converter is not providing right voltage.
The converter is a machine like this.
Diagnosis is done reading AC voltage at converter output with an adequate multimeter, and then verifying specifications of the appliance.
Can i use the aroma rice cooker w/ 220v?
All you need is a power converter. Go to amazon and put in the search bar 220 volt power converter.
Best regards,
Bill
Oct 25, 2014 | Aroma Rice Cooker ARC-914sbd 8-Cup Cooked...
We bought a Zojirushi NS-WAC18 rice cooker, but I lost the user manual. Where Can I find it on line?
Most of the Zojirushi rice cooker manuals are available from the company's support site: http://www.zojirushi.com/support/manuals_ricecookers.html . For the NS-WAC18, see the manual for the NS-WAC10/18 manual. The direct link to the manual is http://www.zojirushi.com/servicesupport/manuals/manual_pdf/nswac10_18.pdf .
I hope this helps.
Aug 09, 2011 | Zojirushi NS-JCC18 Neuro Fuzzy 10-Cup Rice...
Rice cooker will not start. Wanting to know if its a replaceable fuse.
Good day!!!
commonly on all rice cooker problem if no power is THERMAL FUSE.....
Thermal fuse is for the protection of rice cooker it is blown automatically when the heat is exceed the normal temperature..
you can try to disable the fuse and connect the wire directly to test if the problem is on the thermal fuse but you need to replaced it to protect the machine..
please add a comment if you wish to order the parts and I will search it for you..
Thanks for using fixya...
Jul 30, 2011 | Zojirushi NS-RNC18 Rice Cooker
I have a Rival 6 cup rice cooker RC61 the diode is open but I have not been able to cross it.
Diode?
u must've mean THERMAL cut off fuse?
The fuse cut off power to HEAT up ur rice cooker, changing it w/ the same temp code will fix ur rice cooker!
Nov 05, 2010 | Rival RC61 6-Cup Rice Cooker
Where i find sunbeam rice cooker fuse in midrand
sunbeam rice cooker dead
I have a sunbeam rice cooker working fine and all sunden there no power on the rice cooker. I have test the wall outlet power input which is working fine. I assume the fuse inside the rice cooker burn out the fuse. I could not located the fuse from the inside as opend up everything from the bottom panel rice cooker .Please email to me at vancouvercity2001@yahoo.com
thank you
Jun 03, 2010 | Rival RC160 16-Cup Rice Cooker
Does my Aroma rice cooker have a fuse?
You have a bad connection because the wiring has been bent around too much and has failed...this will not be repairable and you need to replace the cooker...
Here is a tip that I wrote about rice cookers and the amount of rice and water needed...
How much Rice and Water go in the Cooker
http://www.fixya.com/support/r5396567-much_rice_water_go_in_cooker
heatman101
May 27, 2010 | Aroma ARC830 6Cup Rice Cooker
Rice Cooker will not work
On the outside of the rice cooker you should locate a button. Push this down and when rice is cooked, the button should pop up (may or may not ring when finished). Once you see the button pop up (or hear it ring), you should leave the lid on for approx 15 minutes longer to finish steaming.
Dec 27, 2008 | Continental Manufacturing Company CE23201...
Farberware 10 cup rice cooker blows fuse after replacement
yeah it has a short in it or just a wire lose from the heater.
open up and check. If you have an ohm meter check the heater. It should not be infinit
Jun 17, 2008 | Rival RC160 16-Cup Rice Cooker
Rice cooker
First you have to make sure that the power outlet is working fine using a Multi Tester. Next is disconnect the Power Plug from the Rice Cooker and test continuity within the cord.  make sure those two are both working good.  next step is to open the Rice Cooker Bottom.  Again using a multi tester, Test the continuity of the Thermostat, make sure multi tester setting is on the ohm setting. reading should be zero, if reading is higher than 200 ohms, the thermostat is defective.  Which is the reason why your cooker is not turning on is due to an open in the circuitry.  Check warranty with the store you purchased it from or the manufacturer of the rice cooker.
Aug 22, 2007 | Black & Decker RC550 10-Cup Rice Cooker
Fuse
You can't plug electrical items which are 110v into 220v sockets...you need a bulky and expensive transformer to convert the electrcity to the correct voltage. It is the only way to 'step up' the voltage
It sounds like you have might have damaged the cookers beyond repair!
Aug 19, 2007 | Zojirushi NS-ZAC18 Neuro Fuzzy 10-Cup Rice...
Zojirushi CD-LCC30 Electric Kettle Logo
Top Zojirushi Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Zojirushi Kitchen Appliances - Other Expert? Answer questions, earn points and help others
