Question about Freeplay Energy BayGen AM/FM/SW Radio
Drive belt has come off my Freeplay S360 and I am unable to get the back off to replace it...HELP!
2 Suggested Answers
SOURCE: Freeplay S360 Need Replacement Battery Pack
I will give my info here and say that I -was- able to replace the battery in my Freeplay S360. I purchased two of the 2/3 AA rechargable NiCD batteries and soldered them together. Then I rewired it into the radio and voila! It works! Total cost: about US $4 Total time: about 20 minutes Now all I need to do is remember to use the thing every month or so, just to keep the battery in good condition.
Posted on Jun 10, 2009
When turning the crank, the spring slips, and the crank flies back to original position. Spring will not wind up.
One day while cranking the freeplay PLUS Radio on a job site with no power, something inside snapped, and made a horrid grinding noise. All of my co - workers laughed. From then on I only used the radio with the AC plug in adapter.
After 8 years of keeping the freeplay plugged in to listen to it I finally decided to open it up and take a look.
Low, and behold I found some broken pieces that looked like a belt. HMMM?
After a little more investigating I found the 2 drive wheels that power the generator... with no belt on them. I looked in my junk drawer, and found a small blue rubber band amongst the others that I save from packaging items. It looked suitable to do the task. After stretching it around the generator drive wheels, I cranked it up, and IT WORKED!
I'm still waiting to see how long this fix works, but in a pinch... keep some rubber bands and a phillips head screwdriver around. This may be the same problem your having. I'm now getting the long lost last laugh.
Hope this helps! KMT
KMT
Feb 19, 2011 | Freeplay Energy BayGen AM/FM/SW Radio
When I wind up the radio, the crank spins back rapidly.
The rachets on the underside of the wheel have fractured. The wheel needs replacing
Jan 06, 2011 | Freeplay Energy S360 AM/FM/SW/DAB Radio
Have undone the screws of the Freeplay 360, but unable to remove the back, why ?
remove the other screw behind the black lable then you will be able to undo the back cover
Sep 10, 2010 | Freeplay Energy S360 AM/FM/SW/DAB Radio
Transmission ack like it is slipping went you are coasting and get back on the gass
check you final drive system(chain or belt freeplay or gear oil). if okay, likely to be your clutch sipping.
Jul 08, 2009 | 2001 Honda VT 600 C Shadow
Jan 05, 2009 | Freeplay Energy S360 AM/FM/SW/DAB Radio
I can't figure out how to losen the serpentine belt on my 1994 jeep grand cherokee
there a tensioner arm with a flat pulley, use a wrench or a ratchet and pull it back to loosen the drive belt.
Dec 17, 2008 | 1999 Jeep Grand Cherokee
Original Freeplay windup radio.
Tony,
Can't help you with the aerial. Mine made the same noise when winding down and I fixed that by pouring talcum powder around the windup section. Let it unwind and allow the talcum to go in,,,, and presto.......no more grinding noises.
Carlo
Jul 07, 2008 | Freeplay Energy BayGen AM/FM/SW Radio
Spring broken?
Solution #2 is correct. My Baygen Freeplay radio was running fast and mine had a broken belt. I could not find a belt on eBay. After hours of searching the internet, I fond a replacement belt at http://www.kenselectronics.com/lists/belts.htm I have the older large Baygen Freeplay radio without solar power and this is the belt that fit my radio... AV-SBS9.5 Replaces SBX9.5 & 1407-36 & SCX9.5 square 9.5 x .047" belt, Baygen Freeplay. Just search the website above... they also have a second size Baygen belt that might fit the newer Baygen Freeplay radios???
Feb 27, 2008 | Freeplay Energy BayGen AM/FM/SW Radio
No more self powerd source
I assume that the rechargeable batteries have expired. The trouble is that the batteries are hard-wired into the radio itself. Unscrewing the back and carefully replacing these with similar-rated cells would be possible but difficult. A poor design, which happened to mine too.
Jan 31, 2007 | Freeplay Energy S360 AM/FM/SW/DAB Radio
Freeplay Energy BayGen AM/FM/SW Radio Logo
197 people viewed this question
Top Freeplay Energy Audio Players & Recorders Experts
RudeRude
John In Milford
John In Milford
Are you a Freeplay Energy Audio Player and Recorder Expert? Answer questions, earn points and help others
