Question about Samsung Televison & Video
My Samsung LCD TV will turn on with picture for about one second and then the picture will dim a bit for again a second and then no picture at all. There is still some sound. I opened the back and see the backlight will turn on then flicker and then turn off. I didn't see any bulging capacitors in the board. Hope somebody can help me with it. Thanks
Same problem. Had power supply replaced 1 day earlier.
I will never buy another Samsung product.
Posted on Oct 24, 2010
Should I fix my TV or buy anew one?
Before you buy a new TV go through all the TV menu options to see if it has automatic dimming depending on the amount of light in the room. If it does it may be malfunctioning and turning that feature off may fix the problem.
May 29, 2016 | Samsung 6030 Series UN46FH6030 46" LED TV...
Picture dimmed. can see the picture and in menu increased the backlight to max but did not go back to normal. checked eco settings and did factory reset. still very dim but can see the picture.
Yah kindly follow this tip. After loosing the back cover when the tv power cord is removed from power socket, check for bulged or defect power capacitors in both the primary & secondary side of the power pack if found any kindly replace it with the actual or equivalent value as this electrolytic capacitor defects is much common for Samsung power packs
Apr 04, 2016 | Samsung UN46EH5300 - 46" LED-backlit LCD...
My Samsung TV color fades out after about 30 seconds.
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
May 28, 2014 | Televison & Video
Samsung ln22a450 no picture just audio in the back
- Flickering screen
- Dim screen
- Slow start
May 03, 2014 | Samsung LN22A450 22 in. LCD HDTV
Samsung ln22a450 red light indicator blinking 5 times also sound like initial screen but no picture no audio after that. 10 min later the tv it shut off by it self
- Flickering screen
- Dim screen
- Slow start
May 02, 2014 | Televison & Video
Samsung LCD TV Problem with Video
If this is a LCD, you have a failing LCD panel. Typical of older Samsung sets!
Jun 10, 2013 | Samsung Televison & Video
This great monitor has been flawless for the past four years. It is now experiencing a problem which is minor but a bit anoying. The picture brightens and dims slightly in intensity about every 20 - 30...
This problems,there are no fix to it.This problems will continue to happen as the tv in used years after years.As over the years in uesd of the tv.The floorscent tubes incorporate in the LCD screen slowly dimming as the rest of the tv life.
Jan 04, 2011 | Pioneer PDP-507CMX Television
Samsung LCD cm07 good then bad picture, powers off and on
well this could be a power supply issue try this web site they could have the part www.discount-merchant.com
Ness
Jan 05, 2010 | Samsung HLN5065W 50" Rear Projection...
Samsung LN-S3241D HDTV LCD snowy display
The main board may cause this problem. If it wass happened when you play DVD, so the main board needs replacing.
Aug 16, 2009 | Samsung LN-S3241D 32 in.LCD HDTV
The TV turns on and off after a few seconds and repeats itself.
Hi.
Either the stk convergence modules or the vertical ic have failed.
replace the 3 parts and it should fire up again.
Nov 21, 2008 | Samsung HCN653W 65" Rear Projection...
Televison & Video Logo
246 people viewed this question
Henry  Thomas
Henry Thomas
