Question about Zenith L23W36 23 in. HD-Ready LCD Television
Burnt IC's located on LCD backlight power supply board.
Where can I get a replacement for this board? Zenith says when they pull up the diagram it does not show a seperate board for this and I know it does because I unscrewed it from the LCD display back housing panel. This board contains the ballast power to power the backlight for the display panel. Please let me know if you know where I can get one.
Thanks, Derrell
D.C. Repairs
  • Anonymous Oct 19, 2008
    my lcd screen coloursare mixed i am getting pink insted of white
    President:
  • 2,712 Answers
Try http://servicemanuals.vstore.ca/
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on May 14, 2008
  • Swilin Sampson
    Swilin Sampson May 31, 2008
    This thread has gone 14 days or more without a response.
    Please close the thread with a “FixYa” or “Helpful” rating.
    Or post back with latest developments, what steps you took,
    etc. and I will assist you further as best I can.
    Thank you.
    IrishDruid
  • Swilin Sampson
    Swilin Sampson Jun 15, 2008
    Kindly close this thread with a “Fixya” rating if you have been able to
    fix the problem, so that I can remove it from my work queue.
    If the issue is not resolved, please post back with latest developments, what
    steps you took, etc. and I will assist you further as best I can.
    Thank you for understanding,
    IrishDruid
At the near bestbuy store
Westimghouse led sound no picture
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
In some models of LCD TVS; the backlight inverter and its T'Con board will be a part of the panel itself, and will be a built-in type inside the LCD panel. If so, they can't be replaced. In this case; a panel replacement is the only repair. For some other models, the backlight inverter section circuit will be a part of the main power supply regulator [SMPS]. To such sets, the power supply section circuit too should be troubles hooted. Contact any service technician. The circuit will differ with models and versions.
Mar 20, 2015 | Westinghouse DW39F1Y1 39in Class 1080P LED...
Ic number of acer lcd monitor v193hqv?
Hi guys the pwm ic number in acer v193hqv is TEA 1530 AP.......
Aug 05, 2014 | Acer Computers & Internet
Screen lcd problem WESTpoint TEN 3212
I am working on a Westpoint TEN-3212 Led Tv. Found the IC on the panel backlight board burnt. Could you please give me the IC number since I cannot seem to find the backlight driver board on sale anywhere.
Jun 13, 2013 | Sansui HDLCD-3212 32 in. LCD TV
Zenith L30w36 backlight only
If it is back light only and no sounds or pic you possibly have power supply problem or main board.
Dec 03, 2012 | Zenith L30W36 30 in. LCD Television
It looks like the bulb in the screen is burnt out. The screen is completely dark when fully chared.
You can determine if the bulb is bad by simply connect a monitor to the fifteen pin AGP port located at the side of your computer usually color blue. If your computer display the desktop on the monitor,you should change the bulb in your computer display.To change the backlight you need to follow these steps :Power off your Toshiba laptop and make sure the AC adapter is unplugged.
Remove the screws on the side of your laptop screen. Once the screws are removed, you can remove the plastic bezel (screen guard).
Pop the bezel out, exposing all of the LCD screen. Pull the LCD screen gently away from the computer by the corner. Be mindful that the screen is still connected to the computer by a ribbon cable.
Remove the tape over the ribbon cable where it connects to the screen, and gently pull the cable to disconnect it.
Turn the LCD face down, and remove the piece of tape that holds the top metallic foil against the back of the LCD.
Lift the metallic foil to expose the backlight. Remove the single screw at the end of it that holds it in place. Unclip the wire at the end of the backlight from the inverter (power source to the backlight), and remove it from the LCD. Replace it with the new backlight (available at any electronics store or online), and reassemble the device the same way you took it apart.
Aug 30, 2010 | Toshiba Satellite A105 Notebook
I have 140 LG 32LC7DC LCD TV's. 14 out of 140 failed. They would not power up. Have you heard of this problem with this model of LG?
Power Supply board is dead.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Mar 02, 2010 | LG 32LC7DC 32 in. LCD HDTV
I HAVE A VIZIO 55" LCD TV WITH FLICKERING PROBLEM. THEY SAY ITS THE BACKLIGHT. CAN THE BACKKLIGHT BE CHANGED AND WHAT IS THE COST?
More likely to be the backlight inverter board, or the main power supply for the inverter board is bad, power supply is easier to get to than the inverter board, so look there first. Look for burnt parts, bad capacitors.
http://en.wikipedia.org/wiki/Capacitor_plague
Nov 10, 2009 | Vizio VF550M 55 in. LCD HDTV
I have a z20lcd1 tv and it has no picture
in the lcd tv there are three main parts
1)the inverter board(pannel)
2)the main board .
3)the power supply board.
if there is no power at all them main board is faulty.if no front led light is coming ON there is no power .so the main board is not faulty.on the main board there is a fuse located you have to replace that and check first if still no power main board needs to be checked and replaced
if there is sound but no picture and front led light is blinking then its inverter board panel problem.if this is your case replace inverter panel.its located in the lower side of the lcd in the inner area below the main board.
but if there is just front led light blinking , but no picture or sound then its power supply board problem.
on power supply board there are some capacitors and ic located.if any of the component gets short or budged up then it short the power supply board.so you can check the components on power supply board with multimeter and get it replaced by using soldering iron.
also you can get new replaCEment power supply board.this clears the problem completely.
you can get the required board and components at ----- www.partstore.com -------- or from ------ www.radioshack.com ----
if you are not familiar with doing this you can get it done by local tv repair technician familiar with this model tv.
Nov 03, 2009 | Zenith Z19LCD3 TV
I have an old Zenith L30W36 that wont show anything.
Most likely the TV has a power supply related problem. The most common thing to go out is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board.
I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If you have some electronic experience, you can purchase a Service Manual over the internet and diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, test points, and part# lists. Usually, cost under $20.
I hope I shed some light on the subject for you.
Jun 29, 2009 | Zenith L30W36 30 in. LCD Television
LCD TV won't turn on, Screen and Standby light blink
This sounds like the flyback unit on the main board is burnt out! replace and you should be fine!
Dec 12, 2008 | Televison & Video
Zenith L23W36 23 in. HD-Ready LCD Television Logo
408 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
