Question about Dishwashers
Hi there, we have had our dishlex 300 dishwasher switched off for a while and today I turned it on. I started a cycle and it stopped after a few minutes and then the Eco button started flashing. I opened the dishwasher to find it full of water and leaking out of the button. Please help! Regards, Pania
  • pania_dunn Sep 22, 2010
    Hi thanks so much to getting back to me. I had to drain it by hand
  • Dishwashers Master
  • 713 Answers
Hi just read your posting.Now the reason these dishwashers flash ECO is because there is either water in the bottom tray or your drain pump is open circuit.Is the machine making a pumping noise when it is flashing the ECO light,or is it completely silent?Please reply on additional information and I am sure I can help you.Looking forward to your reply.
Posted on Sep 12, 2010
Testimonial: "Excellent! Got back to me within 12 hours.. Very helpful"
  • 3 more comments
  • pania_dunn Sep 12, 2010
    thanks so much for ur reply!
    Yes it makes a pumping noise hen light is flashing
  • luisa_sgro Sep 14, 2010
    Hi Pania.Sorry it has taken me a little bit of time to get back to you but my computer was playing up.Now the problem with your machine is it is leaking water into the bottom tray under the dishwasher.Please turn the machine off at the wall because the pump might burn out if it keep going all the time.Now to repair this fault the leak on your dishwasher must be found.From the information in your 1st posting you mentioned that the machine was full of water when you opened the door.Is this correct?Is the machine empty now?Did it drain automatically or did you drain it by hand.Please reply with additional information on the questions and I am sure I can help you rectify this fault.Looking forward to your reply.
  • luisa_sgro Sep 22, 2010
    Hi Pania,Just read your posting.Now from the information in your posting the machine is full of water and you can hear a pumping sound and it did not drain automatically and you drained it by hand.Is this correct?Now look under the sink to the s bend of the kitchen sink.You should see the drain hose of the dishwasher attached to the s bend pipe. .Remove the clamp holding it to the nozzle of the pipe and gently pull the drain hose away from the s bend.Put a pencil or pen inside the nozzle to see if is blocked.Also turn the machine on and put the end of the hose into a bucket and select a cycle and push start and see if it drains.If the nozzle is blocked the pen should unblock it and if the water does not come out of the drain hose into the bucket the the hose will be kinked or blocked.Please try these things I mentioned and reply back on what happened.Looking forward to your reply.
    Ok great I will give it a go this weekend and get back to you, thanks again
Dishlex global300 is gone into flood mode how do I fix it
Dishlex Global 300 Dishwasher issues - Kitchen - Home - Whirlpool ...
forums.whirlpool.net.au > Home > Kitchen
WhirlpoolAug 31, 2011 - As stated in the title, it is Dishlex Global 300 model and it was here when ... is flooding about to happen inside the DW and prevents flooding). Bosch or Asko dishwasher
Mar 7, 2014
Dishwasher that actually WORKS PROPERLY?
Dec 3, 2012
Dishlex Global 300 dishwasher woes
Aug 8, 2005
Dishwashers ...
Mar 28, 2004
More results from forums.whirlpool.net.au
Nov 25, 2015 | Dishwashers
Starts to fill on normal cycle then stops and fast cycle light comes on
If it's like a Dishlex 300, the fast cycle light means there is a blockage in the drain line, somewhere. Check and clean your filters. Also, check your drain hose going to the sink for a blockage.
Nov 04, 2014 | Dishwashers
Dishwasher stops part way through cycle
Sorry I have taken along time to reply but I lost my email access for awhile.Now the fault with your dishwasher is its taking too long to drain.Please reply if you still require help.Once again sorry for not getting back to you sooner.
May 27, 2010 | Dishwashers
Dishlex Global 300 starts to fill with water, then
ok this sounds like your water has stopped coming in or timed out b4 the pressure switch is activated. hold eco button down, u will hear a beep then a light will come up, keep pushing the button until u see the light.reply and tell me which light has come up, and i can help u fix the problem.
Apr 24, 2010 | Dishwashers
Dishlex 300 eco light
pump auto starts if overfull
sound like the machine is overfilling
check the level ,u may need to clear pressure line
or it may be bocked with gunk
if u dont know call for service
it shouldn't be a major.
Jun 16, 2009 | Dishwashers
Thomo, make sure the sprayer holes in the spray arms are clean. Grains of rice seem to be a dishwashers biggest enemy as they don't desolve and eventually end up lodged in the spray holes. The holes at the end of the spray arms are the ones responsible for the washing out of the soap powder from the dispenser, if they are blocked this does not happen.
Hope this helps
Cheers
May 29, 2008 | Tecnik 24 in. TKD795/3 Built-in Dishwasher
Dishlex global 300
try holding the start and program buttons simultaneously for a few seconds, it seemed to reset itself for me-i have done this a few times now.
Feb 04, 2008 | Dishwashers
Tank is leaking
Is it the tank or just the door seals? Ours was leaking recently, there was an obvious tear in the door seal. Once fixed no probs.
Nov 02, 2007 | Electrolux 23 in. ESL624 Built-in...
Dishwashers Logo
372 people viewed this question
Top Dishwashers Experts
