Lost sound after doing a system restore point (I had picked up a trojan virus and only way to get rid of it was to boot in "safe mode" and do system restore.
  • 47 Answers
Hi
Check yous system file, do this :
hi, try this
The suspicion of possible errors in system files in Windows, it may be worth a try to run the "hidden" program that comes with just Windows.
System allows an administrator to scan all protected files to verify their versions.
If System File Checker discovers that a protected file has been overwritten, it retrieves the correct version from the cache folder (% Systemroot% \ System32 \ Dllcache) or source files for Windows installation, and replaces the incorrect file.
System File Checker also checks and filling up the cache folder. You must be logged on as an administrator or a member of the Administrators group to run System File Checker.
If the cache folder becomes damaged or unusable, you can use the sfc / scannow, sfc / Scanonce or sfc / scan boot to repair its contents.
To use SFC:
1) Press Start
2) Select Run ...
3) Enter: sfc / scannow and press OK
(Remember that there should be space after sfc)
More info about the System
Sfc [/ Scannow] [/ Scanonce] [/ Scan Boot] [/ Revert] [/ Purgecache] [/ Cache Size = x]
? / Scannow: Scans all protected system files immediately and replaces incorrect versions with correct Microsoft versions. This command may require access to source files for Windows installation.
? / Scanonce: Scans all protected system files once when you start the computer. This command may require access to source files for Windows installation when you start the computer. SfcScan DWORD value 2 in the following registry key when you run this command:
HKEY_LOCAL_MACHINE \ SOFTWARE \ Microsoft \ Windows NT \ CurrentVersion \ Winlogon
? / Boot Scan: Scans all protected system files every time you start your computer. This command may require access to source files for Windows installation every time you start your computer. SfcScan DWORD value of 1 in the following registry key when you run this command:
? / Revert: Restoring default scan setting (not scan protected files when you start your computer). The default cache size is not reset when you run this command. This command is equivalent to the / Enable switch in Windows 2000.
? / Purgecache: Purges the file cache and scans all protected system files immediately. This command may require access to source files for Windows installation.
Posted on Sep 12, 2010
    Sergeant:
    Champion:
  • 305 Answers
This is the link go to bottom of page
Drivers Downloads - FileHippo.com
hope this helps
Tuvaro virus, can't remove.
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer.
As the computer is booting repeatadly press the F8 key as the computer is booting
If done properly the user should get to a screen similar to the below screen.
Select the option for Safe mode command prompt only
Windows Advanced Options Menu
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice
select the safe mode option
then run your antivirus if still cant get rid of the virus restart again
Use the up and down arrow keys to move the highlight to your choice.
select safe mode with networking download anti malware and microsoft security essentials
http://www.microsoft.com/en-us/download/virus-malware.aspx?q=virus
anti virus and malware
http://windows.microsoft.com/en-US/windows/products/security-essentials
If this fails you might have to go back into safe mode.
You might use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work Manual restore points that you specify with the System
Configuration utility Installation restore points that occur before you install a program or a service.You can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly.
This may also help determine the cause of the configuration error.
To perform a system restore, follow these steps:
1.Click Start, click Run, type msconfig, and then click OK.
2.On the General tab, click Launch System Restore.
3.Select Restore my computer to an earlier time, and then click Next.
4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information.
5.Select a system checkpoint or an installation restore point, and then click Next.
6.Close all other programs.
7.To start the system restore, click Next.
8.Your computer restarts.
Repeat steps 1 through 8 until you fix your configuration issue.
Feb 21, 2014 | Computers & Internet
My dell vostro 3500 won't play sound when I connect it to the computer because I have a deep freeze program on it.
Safe Mode
Enable Boot Logging
Enable VGA mode
Debugging Mode
Reboot
Configuration utility Installation restore points that occur before you install a program or a service. You can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly.
Oct 08, 2013 | Dell Vostro 3500 Laptop Computer (Intel...
Antivirus hp
Safe Mode
Enable Boot Logging
Enable VGA mode
Debugging Mode
Reboot
Jul 12, 2013 | HP TouchSmart Computers & Internet
My problem is with my computer, it seems to have some viruses and I don't have any money to get it fixed.
You might have a virus or malware or it could be a hardware issue
Reboot the computer As the computer is booting repeatadly press the F8 key as the computer is booting If done properly the user should get to a screen similar to the below screen. Select the option for Safe mode command prompt only Windows Advanced Options Menu
Please select an option: Safe Mode
Safe Mode with Command Prompt Enable Boot Logging
Enable VGA mode
Debugging Mode Start Windows Normally
Reboot
Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice select the safe mode option then run your antivirus if still cant get rid of the virus restart again Use the up and down arrow keys to move the highlight to your choice. select safe mode with networking download anti malware and microsoft security essentials http://www.microsoft.com/en-us/download/virus-malware.aspx?q=virus anti virus and malware http://windows.microsoft.com/en-US/windows/products/security-essentials if this fails you might have to go back into safe mode you might use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work Manual restore points that you specify with the System Configuration utility Installation restore points that occur before you install a program or a service you can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly. This may also help determine the cause of the configuration error.
1.Click Start, click Run, type msconfig, and then click OK. 2.On the General tab, click Launch System Restore. 3.Select Restore my computer to an earlier time, and then click Next. 4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information. 5.Select a system checkpoint or an installation restore point, and then click Next. 6.Close all other programs. 7.To start the system restore, click Next. 8.Your computer restarts. Repeat steps 1 through 8 until you fix your configuration issue. other than that you might need to do a format and then re install your operating system
Feb 23, 2013 | HP Pavilion Computers & Internet
Hp pavilion will not boot, error0xc0000409
Step 1:
Enable VGA mode
Reboot
Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice select the safe mode option then run your antivirus if still cant get rid of the virus restart again Use the up and down arrow keys to move the highlight to your choice. select safe mode with networking download anti malware and microsoft security essentials http://www.microsoft.com/en-us/download/virus-malware.aspx?q=virus anti virus and malware http://windows.microsoft.com/en-US/windows/products/security-essentials If this fails you might have to go back into safe mode. You might use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work Manual restore points that you specify with the System Configuration utility Installation restore points that occur before you install a program or a service. You can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly. This may also help determine the cause of the configuration error.
To perform a system restore, follow these steps: 1.Click Start, click Run, type msconfig, and then click OK. 2.On the General tab, click Launch System Restore. 3.Select Restore my computer to an earlier time, and then click Next. 4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information. 5.Select a system checkpoint or an installation restore point, and then click Next. 6.Close all other programs. 7.To start the system restore, click Next. 8.Your computer restarts. Repeat steps 1 through 8 until you fix your configuration issue.
Feb 03, 2013 | HP Pavilion dv7-1245dx Notebook
How to delete virus in my computer
Restart your computer into safe mode where the only things working are the mouse and keyboard allowing you an attempt to repair your computer
Enable VGA mode
Reboot
1.Click Start, click Run, type msconfig, and then click OK. 2.On the General tab, click Launch System Restore. 3.Select Restore my computer to an earlier time, and then click Next. 4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information. 5.Select a system checkpoint or an installation restore point, and then click Next. 6.Close all other programs. 7.To start the system restore, click Next. 8.Your computer restarts. Repeat steps 1 through 8 until you fix your configuration issue. other than that you might need to do a format and then re install your operating system Hope this helps.
Dec 27, 2012 | Computers & Internet
Www.aviraantivitus.com
Enable VGA mode
Reboot
Dec 20, 2012 | Dell OptiPlex GX620 PC Desktop
Everytime i boot up i get an error message stating that there was a boot failure and it loads in safe mode then it prompts me to buy some software to repair my netbook
Sounds like a combination of 2 things.
  1. Machine has contracted a virus.... On startup, the machine would never prompt you to buy anything unless it's infected with a virus or malware.
  2. Corrupted bootlog....Any boot failure is usually due to a corrupted bootlog. This can be for a variety of reasons ie improper shutdown, bad battery, or what I think is the case here is a virus or malware.
If possible, boot directly into safe mode (tapping F5 key while booting). From there you can try different options ie Last known good configuration, run memory test, system restore. If you can't run your anti-virus package in safe mode, you may need to attempt a system restore, preferably to a point just prior to where you picked up the virus.
Jul 09, 2011 | Computers & Internet
I have an hp laptop which has a trojan virus and will no alow me to do anything. Do i have to pess alt F10 to start reboot as i do on my sons acer
hopefully you have an anti virus/spyware programme installed, if so keep pressing F8 on boot up to get you into safe mode, this will not allow the trojan to run.
When you get the list on screen choose safe mode, then when windows starts, choose the administrator account, go straight to my computer>properties>system restore tab, and turn off system restore.
Run your anti virus programme and then when the trojan is found and then reboot pc, then turn system restore back on.
Sep 10, 2008 | Computers & Internet
There is trojan horse virus in my laptop. i ve a symantec norton 2004 antivirus. everytime i update my antivirus, there's some process happening n it comes again unable to hell the virus.... it got...
you need to press F8 while the pc is booting for a startup in safe mode, then when in safe mode select start windows in safe mode, go to my computer, properties>system restore tab and turn off system restore and then run the scan again as these trojans cannot be deleted when the pc is in normal use.
If your antivirus finds them but cannot heal, make a note of the file that has the trojan and then search for the file and delete it manually.
Ensure after the trojans are deleted that you tuirn system restore back on
Oct 21, 2007 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
