Question about Teac Audio Players & Recorders
The CD player was fine yesterday. Now it just says "reading" and wont open or play the CD which is now stuck in the machine. We have not done anything to the player to do this! It is a TEAC CR-H248
  • spamtomek Sep 20, 2010
    I've got the exact same problem with the CR-H225. It's about 2 years old and the problem only started a week ago. Anyone got a solution?
KaeZoo
  • 156 Answers
SOURCE: cd ejection
Reset this unit by pressing and holding the power/ATT and SEL buttons at the same time for several seconds.
Posted on Mar 15, 2007
VOTIT
  • 2071 Answers
SOURCE: CD player won't play disk and says "no disk"
The problem of "'no discs'"displayed is in the mechanism in the roller thats moving back and port bringing the lense set .The old grease thier is already hardened that cause the problem.Clean that by using a lighter fluid or like that fluid to take the old grease,and put it with a new one first class grease type-A grease put only a little grease and wipe the lense with a cotton buds without any chemicals on it .Try this solution so performance will be better.
Posted on Jun 18, 2008
SOURCE: onkyo c707chx...
This is an easy fix if you are somewhat handy.... The belt for the door/tray is slipping. If you remove the enclosure and face plate, you will see two motors below the disc drive. Press eject while observing the pulley to the left. You should see the problem with the motor shaft spinning and the belt slipping. Replacing the belt is possible without any further dissassembly. Simply bend some light wire into an L shape and you should be able to hook both pulleys and lace the new belt on. As far as obtaining a new belt I decided to do the simple thing and use a slightly smaller rubber band. The repair has held now for almost three months and the player is used everyday. Good luck.
Posted on Dec 20, 2008
  • 55 Answers
SOURCE: CD player is not working.
I would first try removing the fuse to the radio/cd player, see if that resets the system and get the cd out.
Hope this helps some.
Matt
Posted on Jun 30, 2009
VOTIT
  • 2071 Answers
SOURCE: why wont my kenwood cd player work ?
First you do is to unplug the cord of your CD unit for 5 hours in order to drain the stored current,the purpose is to reset the unit. After the 5 hours plug the CD see to it if it open If not,just try to press down on the stop button and pressing eject button at same time and it will unlock the tray .Then the other option is to open the cover of the CD unit and unplug the unit again to avoid electricshock . When open already look for the disc platter moved it outward while driving the gear or simply push out. The drawer or door of the CD player and you will see a small circular disc which is often called turntable or disc platter.When the disc platter is out push it back and push it out you do this three times so the slider mechanism align it properly.If you do already what i said then plug it again and if works already closed the cover. The slider mechanism, depending on the age of the unit and the manufacturer, consists of the small chrome rail, a drive motor, a small gear assembly, and (in some units) a small belt that drives the slider unit via the motor. This small belt causes all sorts of problems. If the belt is broken or slipping, it can cause skipping, dropouts, or simply no start up at all. Also, if the belt breaks in the middle of the disc, the drive mechanism gets hair or dirt wrapped up into the gears, or the pick-up assembly doesn?t return to the start position (called home), the unit will (99% of the time) refuse to release the disc, causing it to become stuck inside the unit. There?s a little micro or leaf type switch located at home position that sometimes gets dirty or breaks and, causing this problem also. Hope it may help you;
Regards;
VOTIT
DONT FORGET TO RATE;
Posted on Jul 02, 2009
CD player rotates but wont play or read disc.
Cd spins but player can not play - ecoustics.com
www.ecoustics.com > Forum > Home Audio Forum > Mini Systems Forum
Oct 30, 2003 - Cd spins once system is on but player can not read discs. ... Traywon't eject. ... I have a Memorex 2Extreme CD player, and I insert the disk, and pushplay, and the CD acts like it's searching for awhile and then the screen ... Dvd player won't read any CDs (but use to ) - eCoustics.com
Sep 22, 2005
Cd makes clicking noise and I get Disc Read Error PLZ HELP ...
Dec 24, 2004
CD Player screen reads no disc - ecoustics.com
May 30, 2004
More results from www.ecoustics.com
How to fix a boombox CD player when it wont play - YouTube
? 5:15
https://www.youtube.com/watch?v=pH33UZveLYI
Jun 24, 2013 - Uploaded by Shyzah
How to fix a boombox CD player when it wont play .... My box reads "no disc", but it is in proper position ...
Dec 22, 2015 | Audio Players & Recorders
MESSAGE READS "NO DEVICE"...Yesterday musice stopped playing for all 5 discs
Have you tried disconecting it from the power completely leaving it for five minutes and plugging it in again?
Aug 02, 2014 | Sony CDPCE500 cdp-ce500 5-disc cd changer
I have a dell 755 that the CD drive won't play certain CD's. It is not the CD because it plays on other machines. Some CD's will play just fine. Get's the error message Unable to Access Drive D tr
it depends on the files on the cd ...they might require a certain software to be installed in order to be read..for example the player may not be able to read mp4 without a codec installed ..or vcd (video cd ) to need a dvd player installed or a player that supports video cd and dvd-es..Same way for other file types...or ...certain speeds being imposed on writing ..and your cd drive to be unable to read them on those speeds..
Nov 09, 2011 | Dell Optiplex 755 Desktop Desktop Computer...
Toshiba satellite a300 wont load dvd but will play cd. Was working fine yesterday (dvds work ok on my other laptop)
Try to upgrade the driver for the DVD player. This is done in the Device Manager.
Upgrade or reinstall the software used to play the DVD.
One of the best players for DVD and all sorts of other media is the VLC player - a free download.
Please rate fixya answers.
Feb 20, 2011 | Toshiba Satellite A300-0CF035 Notebook
CD player wont play and says "initializing"
This is common problem with CD players. Try to clean the Lens first by using CD cleaner. If same issue will happen after cleaning. You need to bring the unit to an electrician and have it opened and have the Lens adjusted.
Jun 07, 2010 | 2003 Hummer H2
My cd player wont play cds
take the panel off 4 screws or so just on cd player & over heater control . remove cd player , cover screw's , wire harness ... cd 's probably stuck . remove all cd's put everything back together install cd's again . took me 6month's to figure out my girlfriend did in less than hour with wout breaking a nail!!!!!! lol gd luck .
Apr 28, 2010 | 2004 Nissan Titan
Matt
Jun 19, 2009 | 2003 Mazda Mazda6
Stanton C303 wont eject CD
Remove the power completely replug and then quickly turn it on press eject emediatly..... this should work
Jan 01, 2009 | Stanton C-303 Single Top Loading CD Player...
Cd Tray
Hi Fred..
I've done about 100 CD transports so far.
Try changing any belts in the unit. On some CD players ,if the open/close belt is bad, it wont allow the CD to be read either.
Also,VERY lightly cleaning the laser lens and dusting the unit out helps too.
Dec 28, 2008 | Yamaha CDC-845 5-Disc CD Changer
Discs stuck inside CD Player. Screen says ''Reading.''
Try resetting the CD (Cambridge soundworks) by unplugging, then repluging. Then hold down the eject button while you turn on the power.
Nov 15, 2008 | Cambridge Soundworks 740I CD Player
46 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
