Question about Kitchen Appliances - Others
The pilot light doesnt stay on to light the fryer... is there anything i can do? it is a lincat twin gas fryer....
  • 3,740 Answers
Hi and welcome to FixYa. Most of the time this is as simple as changing the thermocouple. Any Appliance parts source will most likely have one that will fit your unit. (GAS VALVE OFF) It is a matter or unscrewing the thermocouple nut from the gas valve and then un-mounting the thermocouple probe end to change it out.
Take your OLD thermocouple with you to your LOCAL Appliance parts source so they can match the total length. Heating and Air-conditioning stores may have the thermocouple but your going to pay up to purchase a thermocouple from them. Same goes for restaurant equipment sources! $$$
Just make sure before you reinstall the new probe assy that your clean / wipe out the gas valve hole where the thermocouple nut mates to the gas valve very well. The probe works via micro volts and any dirt / corrosion / debris can affect the way the probe operates.
After changing out the thermocouple everything should work normally again. If not then the gas valve itself has a problem (highly unlikely) In the future if you need detailed info please pass your units model number in your response.
Thanks for choosing FixYa.
Kelly
Posted on Sep 12, 2010
How do you check hi limit stat on lincat fryer j10/n
if you ask the question in the correct section, you might get the answer.
a twin tank commercial fryer is not a digital camera - unless I'm missing something.
Nov 28, 2014 | Cameras
I have got lincat fryer j10 the pilot won't stay
Hi there.
Make sure that the thermopile is receiving enough heat from the pilot and if it does, check if the hi limit is good, check and tighten also all of the wiring connections, before replacing the gas valve.
Regards.
Jun 11, 2013 | Kitchen Appliances - Others
Hello i have a J5 lincat fryer and the pilot stays alight but the burners won't connect (light) have replaced the thermostat and the thermo couple but still no joy any ideas on this not sure what to do...
Check if there is 500 to 750 millivolts across the thermopile wires; thermopile generates 500 to 750 millivolts if properly heated to energize pilot and main valve solenoids of the gas valve for pilot and main burner operation. If the voltage across the thermopile is good and all wiring connections are ok, I think you have to replace the gas valve.
Regards.
Jun 15, 2011 | Imperial IFS40 Deep Fryer
The burners will not light. The pilot does light. I had my staff try to hit anything that looked a reset, but I don't know if the high limit switch has a reset or if the switch itself is bad.
The high limit switch has nothing to do with the pilot light, but will shut down the main burners. It the pilot light will not stay lit, then it is most likely the thermocouple. If the pilot light will not light at all, then gas is not reaching the pilot. Most likely, the pilot light tube is clogged with grease. When you push on the button to light the pilot, you are overriding all safeties inside the unit and sending gas to the pilot. Also make sure that the unit itself is getting gas. New regulations require a shut off within the hose that feeds the appliance which will shut off due to a surge of gas through the hose. To reset it, disconnect/reconnect the hose at the intake end and when you turn the gas back on, turn it on slowly.
Jun 11, 2011 | Pitco Frialator 35CS Deep Fryer
My problem is the pilot flame will not stay on when turning the gas valve to the ON position. The machine is a Lincat donut fryer.
This sounds like a "thermocouple". You can buy them just about anywhere and are easy to replace, most have little to no hardware. You can buy a universal one if it is too difficult to locate a model and serial number. One other thing to check would the gas supply- you want to make sure that supply for the gas is not turned off or the valve inside the equipment is faulty. If the gas valve is locked up or there is no gas supply then you will want to address that first.
Hope this helps, James
Jan 05, 2011 | Heating & Cooling
Light pilot on Royal deep fryer. Pilot will not stay lit. Second fryer has larger pilot have no trouble keeping it lit. How can I adjust the pilot so that it will stay lit?
there is a small adjustment screw on the gas valve,turn it clockwise to increase pilot,if that does not work the vent cap on the gas regulator on the back of the unit could be stopped up,remove that cap ,clean out or replace unit can operate without it just fine.If you increase the pilot and it still wont stay lit replace the thermocouple
Feb 06, 2010 | Vulcan GR45 Deep Fryer
Imperial fryer
Try to clean the pilot orfice,ive seen even though the pilot stays lit it doesnt have enough millivolts to energize the gas valve.Did you check the wiring really good?
Feb 08, 2009 | Imperial IFS40 Deep Fryer
Imperial fryer IFS-40
I had a very simular problem. My fryer would do exactly as you described, but sometimes the pilot light would stay on until the burners tried to re-ignite and then it would go out.
I finally had to call the gas company. They took the pilot light apart and cleaned it. The fryer works perfect now.
Hope this helps!
Ken
Oct 18, 2008 | Imperial IFS40 Deep Fryer
Fryer will not fire
The coil in the valve is barely being held closed. Most of the time, 90%+, the thermocoupler (or thermopile) is bad.
You can clean and check the connections, and test it again. Otherwise, spend $20, and replace the thermocoupler. (thermopiles $50) Reason is, a gas valve will likely cost $250 or more. Good luck - Mike
Jun 25, 2008 | Imperial IFS2525 Deep Fryer
Kitchen Appliances - Others Logo
603 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
