Question about Fisher and Paykel Washing Machines
I have a GW712 top load fisher and paykel washing machine when it is filling up on cold water the water pressure is reduced to a trickle what is causing this?
  • mark_jody Sep 12, 2010
    is this a problem that you can fix yourself or do we need to seek help from a professional? What part is needed to fix this problem?
  • 6,784 Answers
HI. This is essentially going to be an issue that concerns the water inlet valve assembly. the cold side is experiencing difficulties when energized by the main control unit. This issue will most likely be a mechanical issue that is isolated to the actual valve solenoid. It is not opening as it should when energized. The necessary actions are to replace that assembly. This is not your average do it yourself repair procedure. if you are not comfortable with disassembling the top section of the unit and extracting this damaged part, i would advise to contact the nearest repair depot for this repair.
Posted on Sep 12, 2010
  • Fisher and P... Master
  • 12,061 Answers
You either have a bad inlet solenoid, or the solenoid driver on the main board isn't working correctly.
rakerprivatelibrary.com/.../F&P%20Parts%20Manual%20for%20several%20models%20517751-Washers-...
Service manual below, above is the parts manual.
ww2.justanswer.com/.../2010-05-31_170211_GWL_11US_FandP_service_manual.pdf FULL service repair manual below here, use this along with the others to troubleshoot and isolate your issue and repair.
http://www.cagrimmett.com/justanswer/fisherpaykel.pdf
Below is a great DIY How to fix, use this along with your manual.
http://www.washerhelp.co.uk/diy-repair-help_3.html
Why won't fisher & paykel gwl11 fill cold water?
If the cold water only comes out at a trickle, you need to replace the valve. I have had to replace the hot and cold water valves on my washer every couple years.
Jul 06, 2014 | Fisher and Paykel GWL11 Top Load Washer
GW712 - cold wash selected but water runs warm. If hot water supply turned off, machine stops?
The cold water temp has been adjusted to a warmer temp,
Move the led back to the first led light with advance button.
Jul 01, 2012 | Fisher and Paykel GWL11 Top Load Washer
F&P GW712 cold water dipping in, hose not blocked, how do we fix this. machine goes well otherwise
if its leaking into the drum whilst the machine is off or while it isnt sposed to be filling then your going to need a new water inlet valve as the plunger inside will be jammed or stuck open
Oct 20, 2011 | Fisher and Paykel GWL11 Top Load Washer
Fisher & Paykel GW712 hot water fills fine - cold water just trickles. Was working fine until yesterday
Turn that spigot off, then unscrew the hose from the machine and inspect the screen that is there (on most machines, some have internal screens/filters) If that screen is clogged, you can clean it or get a new one, if it is damaged. Place the hose inside the washer, or someplace you know the water will drain away, turn on the spigot to make sure you have a flow from the spigot to the end of the hose. Reattach and charge the hose. I believe this will be the answer.
Hope it is helpful. Please rate and comment, Thank You
Joe
Sep 01, 2011 | Fisher and Paykel Fisher & Paykel Washer
I have a fisher and paykel smart drive 5.5 that will not sart filling withwater. All the lights are on and the hoses and filters are not clogged
Hi just found your posting.Do you still require help?Sounds like a lid switch fault to me.Does the machine beep when you push the start button.Please reply for further help.Looking forward to your reply.
Oct 09, 2010 | Fisher and Paykel Fisher & Paykel Washer
GW712 Fisher & Paykel Washer. Cold water will not fill the machine only a trickle. Taps, water temprature and hose working correctly.
THE INLET VALVE FILTER COULD BE BLOCKED TURN WATER OFF UNDO PIPE AND CHECK IF NOT COULD BE A PROBLEM WITH VALVE ! IS YOUR WATER PRESSURE OK
Jan 11, 2010 | Washing Machines
Fisher & Paykel washer GW712 won't spin
There is an issue with your drainage area. Best to remove the pump and check for the obstruction in the line or at the impellar.(If the water is not completely drained, the pressure switch wont send a low level to the timer to allow a spin).
Sep 14, 2009 | Fisher Washing Machines
F & P GW712 - bowl spins, but won't fill.
Read your user manual - but I would suggest that you may not have setup the balance properly. Check the level of the machine and adjust to be as square as possible by adjusting the feet at the bottom. If the water isnt coming in on both hot and cold sounds like a common problem - perhaps the water level sensor is playing up or something else has been knocked during transportation of the machine when you moved house. Check your user manual for troubleshooting. Sounds dumb, but check that 'delay start' isnt selected also. check both hoses filters are not blocked.
Sep 21, 2007 | Fisher and Paykel GWL11 Top Load Washer
Washing Machines Logo
67 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Gerry Harvey
Gerry Harvey
michael_t919
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
