Question about Malber WD2000 Front Load Washer / Dryer
My Maulber wd2000 is no longer drying. It spins, just does't heat up. I think maybe the heating element might be shot. Any suggestion?
3 Suggested Answers
SOURCE: Inglis dryer-spinning,not heating,Inglis washer not spinning well
Your heating element is going out. Mine did this a few months ago. It is an easy fix. Look up the part online.
Posted on Apr 13, 2009
tbirdfan1
  • 3051 Answers
SOURCE: No longer heats during dry
HELLO THERE:
if you have cleaned all of the lint from the filter and still no luck you are goiong to be looking at replacing the heating element.
contact your local appliance repair for this part and a price ok?
best regards mike
Posted on Aug 09, 2009
My hotpoint wdl520 washer dryer is no longer drying my clothes. I still spins but there is no heat for the clothes to dry. Is there a reset button on this model or is it going to be more serious??
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Nov 28, 2010 | Hotpoint Washing Machines
The dryer is not heating up or drying clothes. I read another person said it might be a burnt out heat element. How would we check for this.
With no heat comes no dry clothing. The heating element is not coming on, it could be the thermo cutoff(fuse) is burned out, that is alot less $ than the heater. You will need to check with a ohm meter, pull up veiw of part location by use of model# on any parts web page.
Sep 29, 2010 | LG DLE5977 Electric Dryer
It takes longer to dry clothes than usual and the timer control is not moving or stays in one place
The timer is shot and the contacts are not moving so the heating element sensor will cut the heat off for saftey reasons which is equipt in dryers these days
Jan 24, 2010 | Dryers
Dishes come out all wet. Maybe the heating element but would there be any other potential?
You are right -almost-. When the heating element is not working properly and dishes doesn't dry, I don't think the heating element went bad. It's more likely that other part is causing the problem. Perhaps the timer went bad.
When the timer is broken, the heating element doesn't get power to dry the dishes. By the way, the timer are also called electronic controls or control panel. I believe it needs to be replaced.
Aug 29, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
Dryer no longer has heat to dry clothes
The element gets brittle and breaks. The element is in the rear of the dryer under the dustcover.
May 06, 2009 | Kenmore Dryers
Apr 13, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Estate Dryer takes too long to dry load
Since you say the vent is clear, Make sure that the lint filter is cleared before each load. Make sure the door shuts close and is reasonably sealed. If the dryer draws air past the door, it is not fully drawing heat from the element or burner. Also make sure the washer is doing it's job in the spin cycle. It takes much longer to dry fabrics that are still soppy wet. You might try resetting the washer in the spin cycle to further evacuate the water from the clothes before placing in the dryer. See if that makes a difference. Maybe the washer spin is just being lazy. If it's a top loader it may have a loose belt causing the problem.
Dec 16, 2008 | Estate Dryers
Heat temp and time
When a machine takes a longer time to heat up, this is often due to scale on top of the heating element, try using a descaler product, and running a descale cycle a couple of time.
If it is not a scale problem, then it is usually a faulty thermostat or a faulty element.
Nov 22, 2008 | Saeco Vienna SuperAutomatica Coffee...
Heating element Candy DQW150 Where is it please?
i think you amy have 2 faults. the elements for wash and dry are completely separate.
Apr 18, 2008 | Candy DQW150 Front Load Washer / Dryer
GE Prodigy Electric Dryer not getting hot
The exhaust hose in the back will not affect whether the dryer will heat. The hose just removes the used hot air to a place outside your house. I assume dryer drum spins, but you get no heat. If the dryer has gotten a few years of use, I suspect that the heating element has gone bad. Have you noticed that it has taken longer and longer to dry clothes than it used to? If so, most probably the element is bad. The element is not unlike a heating element in an electric stove, and is housed in a duct inside the dryer.
Mar 10, 2008 | GE Profile Harmony DPGT750EC Electric...
Malber WD2000 Front Load Washer / Dryer Logo
73 people viewed this question
Top Malber Washing Machines Experts
Gerry Harvey
Gerry Harvey
ashburton
Dan Webster
Dan Webster
Are you a Malber Washing Machine Expert? Answer questions, earn points and help others
