Question about Hotpoint Ultima WF860 Front Load Washer
Washing machine says its blocked
the washing machine is blocked
if i put it on quick wash by the end of 20minutes the machine doesnt move but just makes a noise.
Take the block off it and it wil work just fine.
Posted on May 14, 2008
How to do a quick wash
You didnt state what machine you have but if your machine has a quick wash it will have a setting for that cycle every machine i delivered GE Maytag LG etc all had a quick wash setting on the dial if this doesnt help call manufacture to see if your machine has one good luck
Apr 22, 2016 | Washing Machines
My GE Front Load Washer (model WPXH214FWW) remains in the 'drain' cycle between the main wash and rinse cycles. It will only move to the next cycle if we manually advance the knob (slight turn)after which...
Before replacing the timer, check the cold water inlet. Rinses usually use cold water only. The screen inside the valve, right where the hose screws onto the machine, may be blocked. If not blocked, check the inlet valve solonoid coil to see if it is open and in need of replacement.
Oct 15, 2008 | Washing Machines
Operation of machine wash, rinse, spin
at the end of the wash does it empty ok it needs to before it can move on to take on water for the rinses if it doesn't check the pump is not blocked if it does empty the issue may be water valve for cold water also on the wash cycle does the machine heat up if not it will just sit there washing forever
Mar 04, 2014 | Indesit Washing Machines
I have a whirlpool washing machine WI4818S which isnt draining. I have checked the hose where the water drains out but that doesnt seem to be blocked there. also when i start the machine up, it doesnt...
Check the water pump, it may be completely dirty, washing powder. Too much washing powder.
By reducing the plastic tube goes into hydrostat. Wyjmnij powder tray, put the washing machine on one side of the plastic pull out the exact reduction and Purge this branch of the sludge and other particles.
S?uchaj Zapis fonetyczny
May 06, 2011 | Washing Machines
Washing machine finished its last wash and is no longer working ?
All HAIER Washing Machines come with a 3 year parts and labour warranty - Ring them and get them to come and repair..
Apr 10, 2009 | Haier Washing Machines
Asko 10505 runs through was cycle in approx. 30 seconds, then wont drain. Simply stops. It doesnt matter which cycle I start with, the dial moves quickly to stop. It fill with water and spins. ANY HELP...
hi sir' start the wash machine empty and see if it happens when nothing is in it.
2. When machine is off, open the top grab the centerpiece inside the wash machine and pull and push it slowly, does it move? (For safety unplug the machine)
3. Make sure machine is 100% level (front to back, left to right)
The most common thing is bad drum bearing, which force the wash machine out of whack when in spin / wash. Which are common and the best thing is to call Maytag.
thank u .........................................please rate
__________________
Sep 11, 2008 | Asko Washing Machines
SPIN
Refer to manual; your filter could be blocked, or something could be clogged in the drain pipes. Plug off the wall & check the pipes, filter first.
Jun 06, 2008 | Kenmore Oasis HE 27062 Top Load Washer
Haier front loader 1400 spin
check to see that pump is not blocked stopping water getting away quick enough
Mar 16, 2008 | Haier XQ8M22-C PORTABLE TOP LOAD WASHER
My washing machine wont drain the water
if its making a humming sound the pump may be blocked turn the pump fan by hand to see if its free,
Mar 14, 2008 | Fisher and Paykel IWL12 Top Load Washer
Washing machine fjs 1025 w can you identify my problem
Put on the machine. Try depressing "end of cycle" button for over 5 seconds. Turn down the temperature knob first. Let me know result.
Dec 27, 2007 | Washing Machines
Hotpoint Ultima WF860 Front Load Washer Logo
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
