Question about Hotpoint (HSM25IFTSA) Side by Side Refrigerator
Replace cylinoid in feezer area
Have to replace the cylinoid in the freezer of my Hotpoint Side by Side Refrigerator. Have the part (also the ice maker motor if replacing the cylinoid doesn't fix the problem). Do I just take off the white panel cover to get to these parts??
  • 65 Answers
Take of the piece that contains the motor and the solinoid. most were held in by three screws.
Posted on Jan 27, 2009
Where do I direct the hot air from an hair dryer to thaw out the water line in my hotpoint side by side refrigerator ?
Hotpoint ref.
made by GE
There is 2 different place they freeze up inside door water line for cold water dispenser & water feed to ice maker.
for cold water disp. Water line depends on model # will start at bottom of door loop over the disp. control and back down from top of control to cup area to defrost this line best way is to shut down ref and leave door on freezer open can take up to 12 hours.
taking door apart is a major project.
If its your ice maker fill tube easy fix turn water supply off.
on back of ref. there is a water line going up to the top of freezer
this tube will pull out from back the whole fill tube will come out
take to sink thaw with warm water replace tube You may need some caulk to seal area tube meet ref.
Mar 24, 2015 | Hotpoint Refrigerators
Hotpoint side by side has warm fridge and ice build up on back wall of freezer side, barely keeping ice frozen.
OK, you will need to replace the "defrost thermostat" that is located on the coils in the freezer. Here is the part to order. If that was the problem before, the repair tech sold you a part you didn't need. I can't stand service techs that do that! Anyways, keep me posted.
Nov 28, 2012 | Hotpoint HSS25GFP Side by Side...
Hotpoint G/E Side by side refrigerator Model
I have seen this issues with GE and HotPoints. I recorded video for You. Hope this will help. I replace usually both : main board and evaporator fan motor.
Nov 24, 2010 | Hotpoint HSM25GFRSA
Feezer cold frig.warm
sounds like your freezer is not defrosting, causing lack of air flow to fresh food side
May 09, 2010 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Refrigerator side not cooling, but feezer is still freezing
DEFROST HEATERS IN THE FREEZER. IF THERE IS FROST ON THE BACK WALL INSIDE THE LOWER AREA OF THE FREEZER SECTION. YOU THEN HAVE A DEFROST PROBLEM. THE HEATER IS THE MOST COMMON. REMOVE THAT PANEL AND DEFROST WITH HAIR DRYER. THIS FROST IS BLOCKING THE AIR FLOW TO THE REF. SIDE. AFTER THIS IT WILL WORK FOR 10-21 DAYS WITH OUT REPLACING THE DEFROST HEATER. 95 PERCENT CHANCE. JUST REPLACE THE HEATER SOON AFTER DEFROSTING SO YOU DONOT HAVE TO DO IT AGAIN.
Apr 25, 2010 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
I have a hotpoint csx27h side by side refrigerator. the freezer get cold but the fridge part just started to where it wouldnt cool down. any suggestions? maybe the defrost?? the only things i have noticed...
check the operation of your damper door between the freezer and refrige compartments,this door opens and closes to throttle cold air from freezer to refrigerator compartment through the cold control,sometimes they freeze upand can't move,sounds like your door has frozen closed,if so,remove entire damper door unit,clean and deice,replace and see if this rectifies your troubles
Jan 12, 2010 | Hotpoint (HSM25IFTSA) Side by Side...
Hotpoint ice dispenser door not sealing
clean with white vinegar to remove lime deposit.
flapper may have got bent, bend back or replace flapper.
Sep 24, 2009 | Hotpoint HSS25GFP Side by Side...
Freezer temp and fridge temp not as they should be
you should try and defrost the feezer completely as ice might be blocking the cold coming in. it happed to my fridge freezer and that cured it and it is working perfect now.
Jul 19, 2009 | Hotpoint HSS25GFP Side by Side...
Hotpoint side by side csx22grbk serial vz247504
chances are you have a faulty module (board) sounds like you'll have to call an engineer oput to replace it
Dec 09, 2007 | Hotpoint HSS25GFP Side by Side...
Hotpoint Fridge freezer FFA90 - Noisy fan top fridge
worthwhile checking closer. noisy fan can be due to fan blade hitting ice if there has been a build-up. otherwise needs replacing
May 07, 2007 | Hotpoint FFA90 Bottom Freezer Refrigerator
Hotpoint (HSM25IFTSA) Side by Side Refrigerator Logo
65 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
