Question about Humminbird Matrix 12 Fishing System
I understand that matrix 12 is GPS ready ,how do i connect GPS to unit
The GPS system is already in the sounder, you need the G.P.S aerial which is purchased separately. I have this model with the aerial connected and it works well
Posted on Jul 14, 2011
Hummingbird matrix 12 not powering on
The Power Supply just crapped out, Sorry.....
Apr 12, 2013 | Humminbird Matrix 12 Fishing System
How do you get started... where do you plug in the gps in my toyota avalon? I have a 5045
Hello, If i understand correctly, you are just trying to set up your Magellan gps into your Toyota Avalon. First of depending on the kit you got for the bracket to hold the unit, it normally will have a suction cup, that secures the bracket, put the bracket on the window, normally to the right of driver view and toward bottom of window, then after putting mounting (suction cup and gps holder) on window, then mount gps in to bracket, now your gps is mounted at this point on window. Now, of course you have to plug it in. GPS kits when you buy them normally have a 110 power plug ( to plug into home outlet) and some will have with the kit, a 12 volt cigarette type of plug to plug in your car (which is 12 volt power) In your home of course you can charge the gps off your 110 power, and gps will run off internal battery for a few hours, but you will find out like with mine, that your better off to plug into car for power, because the internal battery does not last very long. I have a Magellan as well, and they are great units. NOW this being said, if you did not get with your gps a 12 volt car adapter for your gps, you will have to get one. ( unless you have a power converter, which takes 12 volt and converts it to 110 power, but that's another story and only recommended for devices that do not have 12 volt adapter capabilities)
In conclusion if you have the 12 volt adapter to plug in your gps, all you do is find your cigarette lighter, take out your cigarette lighter, put in glove box for storage, and plug your gps in your cigarette lighter, or any other 12 volt cig lighter plugin. That's all there is to it, and now you have power running off your car. Thanks mike , hope this helps
Jul 23, 2011 | Magellan Roadmate 5045 3065 3055 3045-LM...
I need user instruction manual
If you visit this url there is a download button that gives you the manual for this GPS device.
http://www.retrevo.com/support/Humminbird-12-GPS-manual/id/540bh447/t/2/
I will also post a direct link to the button itself.
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=201775fbd475319d607a772a6cc14dea&modelid=540447&q=Humminbird+Matrix+12
Cheers!
May 02, 2011 | Humminbird Matrix 12 Fishing System
Why map disapears and picture of computer&gps reciver apears when you plug the charger or usb connector to charge it so its not possible to navigate
It sounds like your basic operating system may have become corrupt in some manner. The picture of the GPS and computer should normally only appear when you connect your GPS to your computer. This will normally let you know that your GPS is synchronized to your computer and is ready for you to copy material over from your computer to your GPS. You can try to reset the GPS to see if that will resolve the issue. There is a reset button on the bottom of your GPS. Turn on your GPS. Then using something that does not have a sharp point, depress the reset button for several seconds, about 10-12 should do it. Your GPS should reset itself and come up with the normal loading screen. If you still have the problem then what you can do is go to the Garmin website and download and install the unit software. If you are unable to connect to your GPS with your computer as it normally would you may have to contact Garmin support to find out how you can reload your unit software.
Mar 16, 2011 | Garmin nuvi 200W Car GPS Receiver
Just installed speed only sensor self test on Matrix 17 finds everything else cannot find sensor, any tips welcome. Thanks Bill
the sensors position and the quality of the connection are important also reconnection when the device is starting up is when it senses new and current connections
Jan 14, 2011 | Humminbird Speed Sensor SW GPS Units
I cannot get a clear high definition picture on my gps. also no fish symbols on sonar. low voltage message keeps appearing on screen. any help would really be appreciated.
sounds like you might not be getting a full 12 volts DC to the unit. check the voltage with a volt meter,, and also check to make sure that your battery/batteries are in top shape and charging properly. ( one bad battery in a bank of many can cause voltage issues ).
c...
Dec 31, 2010 | Humminbird Matrix 97 Combo Fish Finder And...
My Humminbird Matrix 67 shows 11.3 volts on the
Hi!
Go into the menu (press menu twice) and look for the alarms tab. There is a setting you can change for a low battery warning, make sure it is set to off or as low as you can get it. Also it may be time for a software upgrade (available at a service center)
Best of luck!
Mike
Jul 08, 2009 | Humminbird MATRIX 97 GPS Receiver
When powering up[on land] it says transducer not connected,checked cable and connections.It use to work maybe went bad? Humminbird Matrix 10
Disconnect cable from back of unit clean the pin connections on the unit and on the cable. If rusty clean with Corrosion X are WD
IF it doesnt work replace cable Jim OMC Retired Mech
Jul 05, 2009 | Humminbird Matrix 12 Fishing System
Need instructon manuals
Thanks I found copies on the net.
May 24, 2009 | Humminbird Matrix 12 Fishing System
Hummingbird GPS Matrix 12
evidently the installer put 2 inline fuses to the power line. After more investigating I located the second fuse which was blown.
Jun 22, 2008 | Audio Players & Recorders
Humminbird Matrix 12 Fishing System Logo
268 people viewed this question
Top Humminbird Boating Experts
Mike Marcotte
Mike Marcotte
Phil Walker
Phil Walker
Steve
Steve
Are you a Humminbird Boating Expert? Answer questions, earn points and help others
