the middle seats come out easily. There are 2 handles you have to lift up on each of the bucket seats, they are in the front of the seat down by the seat tracks. After you lift them, tilt the seat upward in the front and rotate them backward. Then lift out of the hooks. Each seat is held down by 4 hoks.
The 3rd row seat is not designed to come out xcept by a technician. It does slide forward all the way up to the front seat. It has a sliding seat track.
First, lift the T handle under the seat cushion on the left front side of the seat. This will allow you to lift the seat bottom up all the way to lcok in the full up position.
Then, lift the lever on the same side of the seat and slide the seat forward. It will stop in 4 places.
Rear -Rear
6 inches forward of that.
another two ft to the second row seating position
full frward against the front seats.
Pleae rate as fixya if this helps.
Seat —Third Row Bench
Removal
CAUTION: Removal of the third row bench seat requires more than one technician.
- Remove the second row seats. For additional information, refer to Seat—Second Row .
- Remove the floor mats.
- Lock the seat cushion in the upright position.
- Lift the handle to release the cushion.
- Move the third row bench seat to the second row position.
- Lift the seat track release handle.
- Remove the two bolt covers.
- Remove the two seat track front bolts.
- Remove the four seat track rear bolts.
- Position the rear seat cushion floor cover aside.
- Remove the third row bench seat.
The rear bench seat in my 2009 Enclave is ****. The seating position is too low, knees high up in the air, and the seat belt buckle receptor digs into the LR passenger's hip painfully while riding. Should probably have ordered the captain's chairs instead.
My som throughup in the back seat of my enclave. I need to get the 2nd seat out to clean up the mess..
Need to remove seat to clean up large spill
rear struts on a 1008 buick enclave
light for airbag is on. They said it was probably from sitting a heavy bag in the seat. needs to be reset but they want $90 to do it.
Can I reset it myself?
