How to turn off the beep sound when a button is pressed?
  • 47 Answers
Go in Control Panel in Windows, select audio, then select to change system sounds
Posted on Sep 12, 2010
My Panasonic inverter split zircon with r410a blinking the red timer running indoor motor while out door unit not running?
To display memorized error (Protective operation)
status:
1. Turn power on.
2. Press the CHECK button on the remote controller
continuously for 5 seconds.
3. "- -" will be displayed on the remote controller display.
Note: Display only for "- -". (No transmitting signal, no
receiving sound and no Power LED blinking.)
4. Press the "TIMER" or button on the remote
controller. The code "H00" (no abnormality) will be
displayed and signal will be transmitted to the main
unit. The power LED lights up. If no abnormality is
stored in the memory, three beeps sound will be
heard.
5. Every press of the button (up or down) will increase
abnormality numbers and transmit abnormality code
signal to the main unit.
6. When the latest abnormality code on the main unit
and code transmitted from the remote controller are
matched, power LED will light up for 30 seconds and
a beep sound (continuously for 4 seconds) will be
heard. If no codes are matched, power LED will light
up for 0.5 seconds and no sound will be heard. 7. The breakdown diagnosis mode will be canceled unless pressing the CHECK button continuously for 5
seconds or operating the unit for 30 seconds. 8. The same diagnosis can be repeated by turning
power on again.
To clear memorized error (Protective operation) status after repair:1. Turn power on.
2. Press the AUTO button for 5 seconds (A beep
receiving sound) on the main unit to operate the unit
at Forced Cooling Operation mode.
3. Press the CHECK button on the remote controller for
about 1 second with a pointed object to transmit
signal to main unit. A beep sound is heard from main
unit and the data is cleared.
• Temporary Operation (Depending on breakdown status)
1. Press the AUTO button (A beep receiving sound) on
the main unit to operate the unit. (Remote control will
become possible.)
2. The unit can temporarily be used until repaired
Apr 24, 2017 | Panasonic Heating & Cooling
My acer aspire laptop makes a beep sound when swith on button is pressed
beep are of manyh types how many beeps it gives?????? reply me fast so that i can help u
Jul 06, 2012 | Acer Computers & Internet
I NEED TO KNOW HOW TO CLAER THE BEEPING SOUND WHEN YOU KEY THE BUTTON
The beeping sound when you key the button is called the roger beep. To turn it off, with the radio off, press and hold the "up" button and turn on the radio. More information about all the settings is in the user manual, available HERE.
Nov 13, 2010 | Uniden GMR1038-2 (7 Channels) 2-Way Radio
I turned on my ps3 and nothing is happening it is not giving me the option to sign in or anything. just the blue backround nothing else and now it wont let me turn it off.
Sounds like you PS3 software has become corrupt. Follow these steps to sort it but I must warn you, you will lose all your save games!!
Step 1. Turn the PS3 onto standby (red light on)
Step 2. Press and hold the power button. It will beep as soon as you press it, then beep again 5 seconds later then beep once more and turn off. Release the power button when it turns off.
Step 3. Press and hold the power button again. It will beep as soon as you press it, then beep again 5 seconds later, then there will be 2 quick beeps together. As soon as you hear the two beeps let go of the power button.
Step 4. Your PS3 will now boot into recovery mode. Connect you controller via USB when asked and press the PS button.
Step 5. Select option 5 from the recovery menu, "Restore PS3 system". This will rewrite your PS3 software and hopefully should sort your problem.
Aug 08, 2010 | Sony Playstation 3 (PS3) Console
Three beeps when i try to turn it on
i had the same problem a while back. I fooled around with my camera lens a bit and it turned out that one side of the lens was sticking out a bit. I pressed down on this and pushed the power button and it worked. The next time I turned it on the same thing happened but if you keep doing the same thing it should work.
Hope this helps!
Aug 21, 2009 | Samsung L100 Digital Camera
Annoying Beep on Adidas Watch
try holding down one or more of the buttons at once, you should hear a short beep indicating that the beep is off
Jun 18, 2009 | Adidas Candy Digital watch
Siemens se26t550gb/25 dishwasher
Turn the washer off. While off press and hold the 35 degree economy wash button. Keep it pressed while you switch the washer on. You can now by pressing the 35 degree button select the volume of the beep or continue to press it until no beep is heard and that will be it off.
Jan 11, 2009 | AT&T Siemens S46 GSM Cellular Phone
Shutting the beep sound off when you turn on talkabout T7150
Button Beeps
Every time you press a button on the front of your radio, it beeps unless you turn
Button Beeps Off. To turn Button Beeps Off, turn your radio On while you press and
hold the minus (-). To turn Button Beeps back On, turn the radio Off and then back On again
while you press and hold the minus (-) . On is the Default setting.
http://www.motorola.com/mdirect/manuals/T7100_UserGuide.pdf
Nov 15, 2008 | Motorola Talkabout T7150 Two Pack 2-Way...
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
