Question about Evga e-GeForce GeForce 7300GS, (256 MB) PCI Express Graphic Card
Installing a video card
I have a dell inspiron 530 and just purchased an EVGA geforce 7300 GT 512MB PCIe w/DVI/HDTVto install on it. I have never installed a video card before. could someone please guide me through the process? i was told i need to disable my current video card? thanks for any help
  • cornell_3 May 14, 2008
    i will try to install it when i go home from work tonight. thank you for your help, i hope it works. i have in intel core 2 quad CPU, 2.4 ghz, 3.0 BG ram, 32-bit operating system with Vista.
Instalar driver de som
Posted on Nov 24, 2008
Gdf
Posted on Sep 26, 2008
    Problem Solver:
  • 5 Answers
Basic process:
Remove power to the computer. do not just turn it off, unplug it..
Open your computer case.
If you have a separate existing video card, remove it.
If not, examine your Video card. look for a physically matching slot on your motherboard.
To do things the right way, either use a grounding strap, or use the ESD wrap that the card came in to grasp the top of the card.
line up the card with the physically matching slot. Keeping it even with the slot, slowly press it in. If it encounters resistance, make sure no wires have gotten in the way. If it still won't go in, double check that the slot you are trying to put it in is the same size as the connector on the bottom of the card.
If it does go in, go ahead and press it in until it stops. put about 10-15lbs of pressure on it, screw it in. make sure one end is not "cocked up", first.
put the case cover back on.
hook the cable from your monitor to the correct connector on the back of the video card.
plug your system back in.
turn it on. if nothing appears on your monitor after 10 seconds, something is wrong; make sure your monitor is plugged into the card properly. you might want to open the case and verify the card is where it's supposed to be.
Try the power again.
It should be working. if its not, something is either wrong with A) The Video card B) the connection from the card to the motherboard or C) the connection from the card to the monitor.
If the monitor shows something, your card hardwar is installed properly. When your operating system finishes booting, software installation is needed.
I would need to know what Operating System you are running to provide software & Driver installation instructions. To give instructions on how to disable a built in Video card (if you did not remove a card earlier), I would need to know your Computer or motherboard Make & Model.
Posted on May 14, 2008
It's very simple. you push the card into the pc and it's a plug and play thing. no hassle
No signal. Installed in a Evga x58 3x sli motherboard.
Is the card seated in the slot correctly.
Did you check the bios by tapping the correct key when the computer boots and making sure the computer is set to use the PCI express slot. Sometimes the bios will not allow the PCI express slot to function without manually configuring it to do so.
Feb 28, 2011 | Evga 01G-P3-1430-LR GeForce GT 430...
My computer using windows 7 cant detect my new video card, (evga geforce 9500 gt, when i turn on my computer i tried connecting vga with the dvi adaptor to my graphics card but that doesnt work, i saw...
Hi drago,
You can find your drivers here:
http://www.evga.com/support/drivers/
Download the drivers you need, and install them manually in the Device Manager.
In Windows 7, goto the Device Manager (click on Start, right click on My Computer, left click on Properties, click on Device Manager) Look for your video cards, click on the + to see which ones are installed.
Once you have the new drivers installed, you may have to uninstall the integrated graphics drivers to force Window to use the new card.
Hope that helps
Dec 25, 2010 | Evga NVIDIA GeForce 9500GT,, PCI Express...
E-geforce resolution compatibility
That is exactly right. Actually that videocard can even go beyond and support 2048 x 1536 resolution so you should be good to.
You can verify this here under product specs:
http://www.dealtime.com/xPO-eVGA-GEFORCE-6200-PCI-512MB-DVI-I-CTLRV-D-S
Sep 16, 2009 | Evga e-GeForce 6200, PCI Video Card
PNY GeForce 9500GT 512MB DDR2 PCIE 2.0 blank screen after install
Is the PCI Express Slot a 2.0 x16? that could be the issue not positive those cards will work without that specific slot Also check on the graphics card for a 6Pin plug usually they wont work well with out it hooked up to the power supply the plug should say PCI-Epress 1 or 2 good luck!
Jul 23, 2009 | Evga NVIDIA GeForce 9500GT,, PCI Express...
Monitor wont work
You were not very clear with your question. If you mean you have disabled your onboard video, then installed the new video card and get nothing then the card is not compatible with your system OR you got a bad card. If you mean you simply installed the card, turn on your computer and get nothing until you move your monitor plug back to the original port (without turning off the computer) then you must disable your onboard video by going into your BIOS settings. Follow the instructions that came with your video card or your computer to do that. Usually you get in by pressing delete or F2 while the computer boots.
Jun 06, 2009 | Evga e-GeForce 7300GT 512MB Graphic Card
Replacing a Graphics card: Presently a GeForce 420 (64mb) upgrading to GeFroce 6200 (256mb). System is a Dell Dimesion 8200 w/Windows XP at 2GB with 100+ GB free. Will the card work? Tim
If the type of card is the same,and will fit into the slot,such as AGP or PCI or PCIe, then it wil work after you install the new video card drier for your operating system of windows.
Dec 27, 2008 | Evga e-GeForce 6200 GeForce 6200, (256 MB)...
Will the e-geforce 7300 gt work with window xp/how to hook up pow
Yes this card will work with xp.
Does you powe4r supply have the proper plug for the card
if it is a pci-e video card and you do not have the proper power plug you can buy an adapter here.
Dec 19, 2008 | Evga e-GeForce 7300GT 512MB Graphic Card
Is my Motherboard compatible?
Try to find out what the AGP voltage is on the motherboard.
Some graphics cards use 1.5 volts and some use 3.
If it's a 1.5 volt AGP slot and you plug a 3 volt graphics card in, it either wont work or you could permanantly damage both card and motherboard.
Mar 07, 2008 | Computers & Internet
Evga e-GeForce GeForce 7300GS, (256 MB) PCI Express Graphic Card Logo
133 people viewed this question
Top Evga Computers & Internet Experts
Tony
David
David
Larry Rider
Larry Rider
Are you an Evga Computer and Internet Expert? Answer questions, earn points and help others
