Question about LG Heating & Cooling
. It just started after unit was turned off for 5
  • LG Master
  • 3,740 Answers
There ae several causes for the symptom you describe.
Initial problem:
Unit off 5 hours and now seems to be making it's own ice. (Hail reference)
This is usually caused by a restriction in the coolant system. Most often the restriction occurs at the evaporator manifold. Once debris (internal corrosion in coolant system or any particulate) is in the coolant system is blocks 1 or 2 of the 3 manifold distribution holes of the evaporator. When that happens one or 2 sections of the evaporator start freezing up. As it freezes up the temp sensor notices the vast temp change and shuts off the compressor. (Fan still running) The ice then melts from fan air and then gets injested into the blower fan. Hence you get the hail sound.
As for the drain problem An Air-Conditioner that is used 19 - 24 hours everyday should have a 90 day total cleaning cycle. This involves removing the fan assy and using a power washer on the condensor, evaporator and both fan blades. If you look in the drain pan drain area it will will have a mucous looking goo in the drain pan. Once the drain hole is clogged the condensor gets dirty and the unit efficiency degrades.
I doubt there is anything that you as the homeowner can do to stop the icing. The coolant system will most likely have to be purged to get rid of the internal foreign debris and the coolant levels serviced. You can have it cleaned but even after cleaning it is highly probable that your symtom is going to repeat.
Thanks for choosing FixYa.
Kelly
Posted on Sep 12, 2010
My humidifier dont collect water
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
May 16, 2011 | Maytag Dehumidifiers
Tip
Taking the Confusion Out of Using a Dehumidier
Many consumers are confused about setting the proper levels of humidity on dehumidifier units. And then think something is mechanically wrong with the unit. When in fact, over 70% of the time it operator error. That and a lack of proper routine maintenance are the problem.
The numbers on the LED screen represent the amount of humidity you want to maintain. Not the amount you want to remove. For example: If you set the level at 70%, which is rather high, more than likely the unit may start up momentarily and then shut OFF. That's because the setting is to high. Now, if you set it at 45%, the unit will turn ON and run until either the bucket is full and/or the humidity level has reached 45%.
Here's a good rule of thumb if you use your humidifier year round.
In the Winter you want to maintain a humidity level of 50 to 60%. The moister the air, the more comfortable it will feel. Plus, the humidity helps eliminate static electricity in the air.
Conversely, in the hot, humid Summer months, you want to keep the humidity level as low as possible (35% or less). Also, if you have ceiling fans, using them 24 hours a day, helps to move the air and generate a windchill, which fools your body into thinking it's cooler than what it really is. At the same time, it's saving on energy costs by not having to run your AC as much, because the dehumidifier is removing the humidity.
Just remember, the higher the setting, the higher the humidity level will stay. The lower the setting, the more humidity will be removed and the more comfortable you'll feel in the Summer.
And don't forget Routine Maintenance. Clean the air intake filter regularly. Clean and wipe down the refrigerant coils every 60 days. And don't allow water to remain in the collection bucket to long. As mold can build up in it.
Speaking of which, the water in the bucket, when fresh, is great for watering house plants. Because, when it's fresh, it's distilled water. No chlorine or minerals.
on May 04, 2011 | Maytag M7DH45B2A Dehumidifier
When the mode button is pushed, I only receive the option of dehumidifying, or just fan. The manual claims it has a heat option but it is not available. A friend of mine has the same one and they have the...
Sorry to read about your problem, I hope this helps you out.
Their has to be a model difference issue . I have checked the Manuel and have put a copy of the section, for modes. and their is no heat only mode.
Your unit uses heat anyway, so i really do not know how, heat only would help you. I would say to look at the sticker on your friends model, and see if the numbers are exact.
Default Setting:
When the unit is first connected to a power supply, the electronic circuit board will automatically default to the following factory settings;
Mode: Dehumidifier Humidity Set Air Value:60% RH Fan Speed: = Low
NOTE: In the event of a power failure or the unit is switched 'Off', the most recent settings are retained and restored once the power is switched "On"/resumed.
IMPORTANT NOTE: Depending on the ambient humidity conditions, when power is restored or switched 'On' the dehumidifier may not start automatically under the factory or custom (see page 7) default setting. This is an indica- tion that the ambient RH% level of the surrounding envi- ronment is lower than the current default setting and it may be necessary to select a lower set RH% value.
DRY MODE SELECTION: 1. The unit does not have to be switched on (opera- tional) to select/set a program. All programs can be selected with the unit in the "off" position.
2. Press the MODE button until the Dry symbol is shown in the mode area of the display. Note: Each time the MODE button is pressed, the setting will alternate between DRY (dehumidifier) and FAN (only) mode.
3. Press the or cursor buttons to select the desired RH% operating value. To select CONTINUOUS operation,pressthe buttonuntilthesymbol"--" appears in the SET AIR display. During CONTINUOUS mode operation, the humidistat (control) will be by-passed and the compressor will operate non-stop regardless of humidity conditions.
FAN SPEED SELECTION:
4. Press the fan symbol on the keypad. Each time the button is pressed, the mode selection will alternate between "High Fan" and "Low Fan" speed options. The fan speed you select will appear in the LED display; either a 4 blade fan symbol for 'high fan' or a 3 blade fan symbol for 'low fan' will be shown in the display area.
5. When all settings are complete, press the I/O button to start the selected operation (MODE) and the blue opera- tion light will illuminate.
FAN ONLY MODE SELECTION:
1. Press the MODE button until the fan blade symbol is shown in the mode area of the display. 2. Press the "Fan" symbol on the keypad. Each time the button is pressed, the mode selection will alternate between "High Fan" and "Low Fan" speed options.
3. When all settings are complete, press the on/off button to start fan mode operation and the blue operation light will illuminate.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Dec 31, 2010 | Danby DDR586R Dehumidifier
Whirlpool side by side made in 1998 is not cold. freezer side temp ranges between 32 - 40 degrees at coldest setting. coils are clean. blower is working. could thermostat be stuck or freon low? where do...
Most of the time there is an automatic defrosting problem when the freezer starts warming up. Ice builds up on the evporator coils.. airflow gets restricted and the temps warm up. Check to see that your evaporator fan is running at full speed. If it is then do a manual defrost by performing the following steps:
1. Unplug the unit
2. Remove freezer contents
3. Place a fan blowing air into the freezer compartment for a little over 2 hours. (Makes a mess... rags and Mop time)
4. After 2 hours wipe out any residual water...
5, Plug in unit
6. Reload freezer.
7. Check temps in 4 - 5 hours.
If temps are normal you have an Automatic defrost problem.
Causes can be:
1. Defrost timer / control
2. Defrost Heating Element
3. Wiring
There are other causes but timer / control or the element in a 10 + year old unit are the normal failures.
Do this step before the manual defrost
Make sure that the condensor fan in the lower rear part of the unit is running at FULL speed.and that the condensor coils are free of lint and debris. If the condensor and fan are loaded with lint it will cause warmer operating temps. Clean as needed.
If after you do a manual defrost and the temps come back to normal for at least 24 hours you will need to troubleshoot the auto-defrost circuit. If you need help at that time just respond here and I will help you.
Thanks for Choosing FixYa
Kelly
Sep 18, 2010 | Whirlpool Refrigerators
Need to recharge my A/C. This one has front and rear A/C. Most guages say not to go over 45psi. Is this the same for the bigger systems like mine? I have it at 45 psi right now and it's cool not cold like...
Without knowing where you are or the temp/humidity conditions it's a tough call.You should understand this:too much freon is just as bad as not enough when it comes to A/C performance.Have someone help with this.Run the engine at about 2,000 rpm for 4-5 minuets,A/C on,fan on high speed.On a 70-75 deg.F day with moderate humidity, I would like to see 30-35 psi low side,225-250 high side.(even 275 isn't too bad).The hotter/more humid the day,the higher both pressures will be.Holding the engine rpm while testing is very important!If you see over 40 psi low side you could be over charged.Make sure the radiator fan(s)are working properly.
Apr 12, 2010 | 2001 Ford Explorer
TM-T88III print speeds and other issues
Try setting both switch 1-7 and 1-8 to ON for 38400 baud, set switch 1-2 to OFF to give a 4k buffer, set switch 2-5 to OFF to release the busy buffer at 256 bytes, set switches 2-3 and 2-4 to ON & OFF for medium print density and OFF & ON for dark print density or OFF & OFF for normal print density.
Also remember that the thermal TM-T88III also prints faster when the print head is cooler and slower when it heats up. The print speed is adjusted automatically depending on the voltage applied and head temperature. So make sure your power supply is providing a steady 24VDC at full load and has enough capacity to provide a peak of 7.7A in full speed mode. If you are using the printer in high temp and humidity you might want to swap the unit out for a Star Printer which performs faster and uses the same protocol or use a cooling fan.
Also make sure you use a good quality paper and that the humidity is within range at 10 – 90% RH although the paper performance will be greatly diminished at higher humidity levels.
Specifications:
High-speed = Approx. 150 mm/s {5.9"/s} max.; 47.2 lps, max. (3.18 mm {1/8"} feed);
35.5 lps, max. (4.23 mm {1/6"} feed, at 24 V, 28°C {82°F}, density level 1).
Low-power: Approx. 16.5 lps (4.23 mm feed {1/6"}); 70 mm/s {2.76"/s}
Ladder bar code: Approx. 42 mm/s {approx. 1.7"/s}
High-speed mode: Mean: Approx. 1.8A Peak: Approximately 7.7A @24VDC
Low-power mode: Mean: Approx. 1.2A Peak: Approximately 6.6A @ 24VDC
Operating temp = 5 to 45°C {41 to 113°F}
Operating Humidity = 10% - 90% RH
Aug 28, 2009 | Epson TM-T88III Thermal Printer
I have a GE air conditioner with ditigal panel. I
Wash out outside coil from time to time.This is the most over looked part of window units. Take care not to spray water directly into fan motor. If not real humid in house check temp coming out of ac inside and make sure filter and coil are clean. run on high speed and the air should have good force. 20 to 30 degree temp drop of room temp should be about right. Much depend on outside temp and humidity and indoor humidity plus insulation factor of area. How many people are in the area and if you keep unit on day and night .
Jun 28, 2009 | GE AJCQ08ACB Air Conditioner
My gateway Mx6920 is overheated
First off you should know that laptop fans have three speeds high, low, and off. When you first turn a laptop on it will start on high/low (depending on brand) and after a short time will turn off, it may not turn on again for a while. i have had some that will not make it to the desktop without the fan and i had on that was running for several month straight without the fan plugged in (i don't recommend doing this, it was a mistake burned it, reached 70 degrees C).
I would like you to first download Speedfan http://www.almico.com/speedfan437.exe and install it. once installed leave your computer completely off for at least 1 hour. then turn on your computer and once you get to the desktop run speed fan make note of the temps. leave this opened and now use you computer normally for a little bit then come back to speed fan after a while and make note of those temps. once you have done this if you post them in a reply so i can verify if the fan is bad or if it is something else.
Feb 05, 2009 | Gateway MT3705 Notebook
LG LD65EL Dehumidifier doesn't work properly
What do you have the humidity level set at on your dehumidifier? The average is 65%. Make sure you do not have it set at 75% because if you do this could be causing it to keep the humidity so high.
Jul 02, 2008 | LG LD65EL Dehumidifier
Samsung 8000 btu window air conditioner
Air conditioners rely on a difference in pressure between the "high side" and "low side" in order to perform. Of course, a/c's are designed to work in the heat. Having a cooler outdoor temp of 70 degrees probably is not sufficient to maintain adequate head pressure and will result in reduced cooling capacity. Also, since it was 68 in the morning in the room, it is possible that the indoor coil began to freeze up. Basically, you have a cold coil that you keep warm by moving air over it. If the air doesn't have enough specific heat (what your thermometer measures) it can allow the coil to get colder than 32 degrees and the condensate from all of your humidity will begin to freeze on the coil. My recommendation would be to check the a/c on a day that is 80+ degrees. If you have an avarage indoor temp of 70 degrees you should be able to look for the air coming out to be approximately 20-25 degrees colder than the air being sucked in.
Jun 10, 2008 | Heating & Cooling
Heating & Cooling Logo
74 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
