Question about Canon imageRUNNER 2200
Copies have a dark shadow across the top inch of the paper.
What needs to replaced or cleaned in order to get rid of this line?
  • Anonymous Dec 01, 2008
    The copies are coming out with the image of the letter head at the bottom also. How can I fix this?
  • Canon Expert
  • 1,326 Answers
You need to replace the drum unit to resolve the problem.
Posted on May 15, 2008
How do I get rid of the black line when I scan or make copy's
I had a professional to clean the scanner and copy machine. The line was gone. He had special tools to clean the machine parts.. Hope that helps.
Jul 17, 2014 | Brother MFC 8950DW
Tip
How to Put on Eye Shadow
Achieving Smoky Eyes.If you're looking for a way to play up your eye color, go smoky. A smoky effect makes eye color pop and creates a dramatic evening look. Read on to learn how to create a flawless smoky eye. <br /><br />Create a smooth canvas for eye makeup. First, you'll want to apply a primer to your entire face, including the eye area. Then apply a concealer to get rid of redness and dark circles. Finish off by applying a moisturizing foundation to create a flawless canvas. <br /><br />Apply eyeliner. Use a black liner and draw a line across the upper lash line. When you get to the middle of the eye, make the line a little bit thicker. Choose a lighter-colored eyeliner and line the bottom of your eye. Smudge the liner with your finger to create a smoky appearance. <br /><br />Apply two colors of eye shadow. In order to select the right products, check out eye shadow reviews. You'll want a color palette that has both a light and a dark color, such as L'Oreal Paris HiP Concentrated Shadow Duo. Use the lighter color as a base and blend the color all over your upper lid. Then, apply the dark eye shadow, starting at the lash line and blending upward.
on Nov 22, 2010 | Health & Beauty
Mysterious fluctuation in quality of copies.
fuser drum is bad. photocopier use electricity to transfer the toner to the paper, then it is heat fused to paper. it appears that the problem is occurring around the time that the toner is attracted to the paper.
Mar 07, 2014 | Canon PC-940 Black and White Copier
I have a Brother MFC 8440..the paper has vertical black lines
Try changing the toner, if it's generic that's your problem, and if it's either an old brother drum or a generic you may need a new one. There is also a glass to clean, it's right above where the drum sits inside, 1/2 inch wide across the top. Wipe with a dry cloth.
Sep 14, 2009 | Brother MFC-8440 All-In-One Laser Printer
HP Laserjet 5P shading edges of page
This is probably due to a defective cartridge, Charge Roller or Transfer roller.
Check the cartridge for a band of toner still on the drum.
Check the Charge roller for oil or smudges, this roller should be a lighter color and should be relatively free of toner or marks.
Same as the Transfer Roll, which will be dark, though excess toner should be evident.
A relatively smooth straight line is generally the cartridge.
A rather wavey or broken line is most likely the rollers.
You can however attempt to print a large amount of pages (25-50) in an attempt to clean the parts, however if either part is defective they will need to be replaced and no manner of printing will clean them.
Apr 14, 2009 | HP LaserJet 5p Printer
Lines across printed page on photos
Change the paper type and paper size and that should resolve the issue.
Regrads,  raj_p5983
Jan 05, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
I have a dark line across copies
Whats the make and model of the copier?
One culprit might be the drum.  If you can take a look at the drum from your copier and you see black lines on it.  It could be scratches on the drum or it may need a new cleaning blade to clean the toner off the drum.
Nov 11, 2008 | Office Equipment & Supplies
Dark line across the top of 56HM66
I had the same problem on my tv found a simple solution its been a week and no problems so far.pull out light engine you will find round piece of tape pull it of there will be a #2 phillips screw in about 3 inches turn it clockwise and watch it vanish.i turned mine a little further to assure it would be gone.only took a couple of minutes to do dont know how long it will last though good luck
TelecomTech
jb
Oct 26, 2008 | Toshiba 42H83 42" Rear Projection...
2 parallel lines show up on the copies
try to clean the cover glass at the top of the copier with alchol.
be sure that ther is no any dot or lines on top of tha glass specialy the right side.
Apr 11, 2008 | Sharp AL 1631 Copier
Canon imageRUNNER 2200 Logo
118 people viewed this question
old marine
old marine
Corne Viljoen
