Question about Kodak EasyShare CX7430 Digital Camera
Kodak easyshare C530
I have the above camera but all photos come out alot darker than real life, i have tried all flash options but nothing works. it is even worse at night when the picture is basically just black. I have had the camera 18 months and it has been like this as long as i remember.
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 480 Answers
Hey neilhowie,
I would make sure that your subject is within the range of the flash which for wide angle shots is 8 feet, and for telephoto shots is 9 feet. Another suggestion is to make sure auto exposure has been achieved by holding the shutter button halfway down until the green light appears and then take the image. Another thing you could try is to increase the exposure compensation. Nighttime photographs are difficult no matter what camera you are using so make sure your mode is set to nighttime, and of course your flash coverage would be the same as mentioned above.
Sincerely,
Allan
Go Ahead. Use Us.
Posted on May 14, 2008
My nikon D40x doesn't seem to work in manual mode, as all of the pictures come out dark. I'm trying to learn how to use manual and although the shutter is releasing very fast, nothing shows up. I am so...
1600 = 1/1600th of a second
try shooting at 125 = 1/125 of a second with an f of about 4? in daylight
something more along the lines of 8 or 1/8th of a second would be better in darker conditions without a flash
no problem but think of it like this....the longer the shutter opens the more light comes in..if your shutter is open very briefly...no light gets in and thus you get a black photo
Feb 07, 2011 | Nikon D40x Digital Camera
The flash isnt working. if i try to take a photo with the flash on, nothing happens
If the Forced flash setting is already enabled and the flash is still not working, then the issue may be due to another camera setting.
Even if the Forced flash setting is enabled, the flash will still not work in the following circumstances:
  1. When shooting MPEG movies.
  2. When shooting in the Twilight or Handheld Twilight mode.
  3. If shooting with the Burst or Multi Burst mode.
  4. Shooting with Sweep Panorama
  5. Shooting with the Fireworks or High Sensitivity mode.
  6. If an external flash is connected.
Please make sure that the Camera is not set to any of these modes. You can check the manual to get the information to change the setting..
  • If the issue persists, please reset the Camera and make sure that battery is fully charged.
  • If the issue persists after performing all the above mentioned troubleshooting steps, service is required.
If you feel that the above Troubleshooting steps helped you. Please rate my answer positively.
Thanks for understanding.
Jan 25, 2011 | Sony Cyber-Shot DSC-S500 Digital Camera
I find that even in a reasonably well lit room my camera struggles to pick up a clear image and always appears to be a lot darker than in real life. I would assume that on automatic setting this shouldn't...
Try bigger ISO-setting (in a well lit room 400-600 and darker even 1600). Also try to fix the exposure according to the darker parts of the room.
Aug 05, 2010 | Cameras
My Canon A430 Camera got a bit wet when I fell into a Dam this weekend. The camera did not at all touch the water, but a few drops of water did land on the camera. After drying the few drops off, the...
Apparently, Some water worked its way into the camera circuitry. You need to stop trying to get it to work...you're only making things worse. Remove the card and battery. Bury the camera in a bowl of dry rice for a few days to absorb any moisture.
Jun 30, 2010 | Canon PowerShot A430 Digital Camera
Blurry indoor results- using flash
Built in flash units on digital cameras are only meant to be used out to a distance of 6-12 feet. When taking photos of events ie graduations, sporting events, concerts you need to do two things. 1). Change the ISO setting on your camera. This is the same as the old film speed ratings the higher the number the more sensitive the camera becomes. try ISO 1600 or above in low light. 2) You have a mode setting, set it for the type of lighting that is in the space you are in, incandescent, flourescent or whatever, it's easy to do. and finally 3) Turn off your flash! When your flash is on your camera closes up the aperature and takes the picture at a higher rate of speed in anticipation of reflected light off of nearby objects, so your pictures will be darker and blurrier with the flash on.
Even high grade professional flashes only work out to 20-30 feet so they won't help you. Read your cameras manual on taking pictures in low light conditions. It will give you all of the above in great detail. You have a great camera but you need to learn how it works, don't give up on it.
Jun 02, 2009 | Sony Cyber-Shot DSC-H1 Digital Camera
Missing shot.
Any auto camera like this is going to have trouble in dark light...
Photography is all about light, and in dark situations, compromise as well.
You best chance is to set the ISO up to the highest setting available, use flash, and a faster shutter speed, however, faster shutter speeds means less light can enter the lens, and hence give a darker image. Higher ISO makes the camera more sensitive to light, but produces grainier images as a result. Flash creates artificial light...
The only real way to get good images at a concert in the dark is with a high end camera, a lens costing many thousands of dollars, a tripod or monopod to steady yourself, and a longer open shutter time.
In the meantime however, experiment with higher ISO setting, flash and try to keep your hand steady at all times because the shutter speed needs to be slightly slower for the lens to capture more light.
Apr 06, 2009 | Fuji FinePix S8000fd Digital Camera
INSIDE PHOTOS ARE DARK AND GRAINY
Regardless of the camera make/model... dark, grainy photos are usually a result of a lighting problem. Looking at the specs for your camera, the flash is only speced for 4m. If you are shooting near or above this you might have trouble. I ended up using an external flash that is triggered by sensing the cameras flash. Pretty inexpensive and pics ar 10x better. Try a local camera shop or B&H Photo (NYC) is where I got mine set up on line.
Jul 24, 2008 | Canon PowerShot A630 Digital Camera
Indoor photos are too dark and skin tones orange-ish
I have the same problem at my church with the indoor lighting on my camera. I'm able to get it work by putting the whole thing on manual and adjusting the lighting settings that way.
Jun 13, 2008 | Sony Cyber-shot DSC-W70 Digital Camera
Kodak EasyShare CX7430 Digital Camera Logo
48 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
