Question about Sony KP-46WT510 46" Rear Projection HDTV
Timer/stand by light in the front panel is blinking. The picture is all red and only stays on for about 20 seconds and then shuts the tv off. The light is blinking 5 times. Is there a home fix for this or only a technician will be able to diagnose and fix?
  • 1,476 Answers
Dodgebrat250,
By blinking 5 times I will assume that you mean the standby light blinks 5 times approximately 1 second apart, then pauses for 3 seconds and repeats. If this is true then you have a fairly complicated problem which could be anyone of three different areas. If you are not trained in electronics you will probably need a technician to solve the problem.
The problem is on the A or C board or it may need the screen drive turned up. One the C board check Q705, 732, 761 and all associated components. Look for bulging capacitors and replace as necessary. On the A board check Q218, 219, 220 and any associated components. Also look for bad electrolytic capacitors as above.
This is only a small part of what the problem could be and without actually looking at the set and doing testing it is difficult to recommend any further action.
I have a tip at http://www.fixya.com/support/r4425498-basic_standard_tv_troubleshooting which might help track the problem down.
Thanks for using FixYa and for the generous rating.
hardrocko
Posted on Sep 12, 2010
TV turns red,shuts off, stand-by light blinking 8Times
Eight blinks - Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401, and 402. On some projection models of Sony TV sets, this code means that T8005 (flyback transformer), or the associative components in the high voltage circuits are defective on the D board.
Feb 27, 2014 | Sony KP-51HW40 51" Rear Projection...
My bravia will not stay on.
If Bravia tv wont stay On and shuts Off itself that means it got some internal problem, you will see red light flashing on tv front in specific blinking time that is an error code, let me know how many times that red light is blinking after three seconds long pause to diagnose problem.
Thanks.
Feb 08, 2011 | Sony Bravia KDL-46VL130 TV
Tv turns on then off, stand by timer light blinks 4 times
You need to replace the power supply unit on this as it has malfuctioned there about $90 bucks plus labor on that.
May 25, 2009 | Sony FD Trinitron WEGA KV-20FS120 20" TV
Tube 27" sony tv, stand by timer light blinking red?
It has a faulty power supply or processing boards. Must take to agents to sort out. Nothing you can do on the outside.
May 12, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Tv tunrns on then goes to stand by flashes 4 times & repeats
turn tv on picture comes up 2to3 seconds later tv blacks out then stand by red light flashes 4 times in a row repeatedly..can not turn on or off when stand by light starts flashing but before tv blacks out you can turn tv on and off repeatedly and picture and sound work.You have to unplug power cord for 30 seconds after stand by light comes on to get tv to turn on.
Mar 13, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Sony shuts off after being turned on, stand by/timer light blinks
The blinking should be in a pattern of a count, pause, count. That is an indication of the problem circuit. Can you post that count please? That info will allow me to give you possible defective parts and costs for the repair.
Thanks,
Dan
Feb 18, 2009 | Sony KV-27V42 27" TV
The screen stays black when the power is turned on. the stand by/timer ligt blinks
There is a high voltage, and or scan failure. This can be the flyback assembly, and or other support components. If the CRT is defective, it can cause this type of shut-down.
The cost for servicing this would be fairly expensive. It would be best to start shopping for a new set.
Jerry G.
Oct 17, 2008 | Sony FD Trinitron WEGA KV-20FS120 20" TV
Sony Trinitron Color TV KV-35V65 - No Picture, red light stand/by timer flashing
A reset won't fix this. The standby light should be blinking a repeated count with a 3 second pause inbetween. Post that count here. That will indicate the circuit/condition that is preventing the set from turning on.
Thanks,
Dan
Jul 18, 2008 | Sony KV-35V65 TV
Philips 42 in. Plasma shut down
did u cheak the input cables does it do it on dvd input as well as others ?
Feb 01, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Tv turns self off when turned on
Does it blink a certain amount of blinks pause a second or just blink constantly with no pauses? Let me know it will blink a code if its going into protected shutdown. And it will blink constantly for another reason.
Jan 22, 2008 | Sony KP-53HS30 53" Rear Projection...
Sony KP-46WT510 46" Rear Projection HDTV Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
