Question about Conceptronic 54Mbps USB adapter
I get the following msg in properties - This device cannot start. (Code 10)
High definition audio controller This device cannot start. (Code 10)
If you run into the error "This device cannot start. Code 10 (often followed by a driver identifier, for example "This device cannot start. Code 10 in audio driver"), here is what it means.
The Windows error "This device cannot start. Code 10 or "This device cannot start. (Code 10)" is a hardware error that most commonly means that you have a bad, missing, or incompatible device driver. So, for example, "This device cannot start. Code 10 in audio driver" means that you have a bad or missing or incompatible driver for your sound card.
The technical explanation for this message, according to Microsoft, is this:
"If the device has a FailReasonString value in its hardware key, that string appears as the error message. The driver or enumerator puts this registry string value there. If there is no FailReasonString in the hardware key, you receive the following error message:
What does that mean in plain English? It means that if the device which is throwing the error has added its own custom error text to your Windows system when the device was installed, then when the device encounters an error, you will see the custom error message specific to that device. But if it doesn't have its own custom error message, then Windows uses its own generic error message for devices, which is "This device cannot start. (Code 10)"
Microsoft recommends that when this happens, you click "Update Driver" to update the drivers for the device. You can also start the Windows troubleshooting wizard by going to the general properties tab of the device, and clicking on "Troubleshoot".
Before doing this, be sure that you have the correct and most up-to-date versions of the driver(s) for that device. You can also try uninstalling and reinstalling the device, using the disk which came with it.
Finally, you can go to the website of the device's manufacturer, and check their downloads or support section for current, up-to-date drivers.
Go to Toshiba support site look for Toshiba Satellite A135 drivers, download the one for your windows 32 or 64 bit install, restart and off you go. Regards, Mike
May 19, 2014 | Toshiba Satellite A135 Notebook
I am getting code 10 error in device manager
Code 10
If the device has a FailReasonString value in its hardware key, that string is displayed as the error message. The driver or enumerator puts this registry string value there. If there is no FailReasonString in the hardware key, you receive the following error message: This device cannot start. (Code 10) Recommended resolutions
Here are some things that you can try to resolve this problem.
Update the driver
In the device Properties dialog box, click the Driver tab, and then click Update Driver to start the Hardware Update Wizard. Follow the instructions to update the driver.
You may be prompted to provide the path of the driver. Windows may have the driver built-in, or may still have the driver files installed from the last time that you set up the device. If you are asked for the driver and you do not have it, you can try to download the latest driver from the hardware vendor's Web site.
View the article in the Microsoft Knowledge Base
For more information about Code 10-related errors , click the following article number to view the article in the Microsoft Knowledge Base: 943104 (http://support.microsoft.com/kb/943104/ ) Description of Code 10-related errors that Device Manager generates on Windows XP-based computers
Sep 15, 2011 | Computers & Internet
It's a can not start Code 10 error.
The Code 10 error code is generated when Device Manager has insufficient information or the error that is bubbled up by the device drivers is not recognized by Device Manager. Additionally, this error may occur when one of the drivers that the device needs does not start. If many drivers are being used by a particular device, it can be difficult to determine the one that failed.
The most common resolution is to update the drivers that are associated with the failing device. To do this, follow these steps:
  1. In the device's Properties dialog box, click the Driver tab.
  2. Click Update Driver to start the Hardware Update Wizard.
  3. Follow the instructions to update the driver.
It would be helpful to know what the device is and is it connected directly to a USB port or through a USB hub.
May 15, 2011 | Computers & Internet
Code 10
If you run into the error "This device cannot start. Code 10? (often followed by a driver identifier, for example "This device cannot start. Code 10 in audio driver"), here is what it means.
The Windows error "This device cannot start. Code 10? or "This device cannot start. (Code 10)" is a hardware error that most commonly means that you have a bad, missing, or incompatible device driver. So, for example, "This device cannot start. Code 10 in audio driver" means that you have a bad or missing or incompatible driver for your sound card.
Mar 15, 2011 | Computers & Internet
HI,
Information as from the Microsoft website:
Code 10
Update the driver
You may be prompted to provide the path of the driver. Windows may have the driver built-in, or may still have the driver files installed from the last time that you set up the device. If you are asked for the driver and you do not have it, you can try to download the latest driver from the hardware vendor’s Web site.
943104 (http://support.microsoft.com/kb/943104/ ) Description of Code 10-related errors that Device Manager generates on Windows XP-based computers For further details: http://support.microsoft.com/kb/310123
Aug 25, 2010 | Microsoft Computers & Internet
CODE ERROR 10
Code 10
If the device has a FailReasonString value in its hardware key, that string is displayed as the error message. The driver or enumerator puts this registry string value there. If there is no FailReasonString in the hardware key, you receive the following error message: This device cannot start. (Code 10)Recommended resolutions
Update the driver
Feb 26, 2010 | Broadcom BCM5721 NetXtreme Ethernet...
Well this error code is fully supported by Microsoft, you can please follow the below link to troubleshoot the error code  -
Please post comments for more help or information.....
Good Luck!!
Thanks
Jan 16, 2010 | Computers & Internet
No sound,,, error code 10
This device cannot start. (Code 10) The most common resolution is to update the drivers that are associated with the failing device. To do this, follow these steps:
Note You may be prompted to provide the path of the driver. Windows may have the driver built-in, or the driver files may still be installed from the last time that you set up the device. If you are asked for the driver and you do not have it, you can try to download the latest driver from the hardware vendor’s Web site.
Nov 18, 2009 | Acer Aspire 4520-5582 Notebook
Acer Aspire M1610 with MS Vista SP2. DVD unit code 10 error
Right click on the dvd drive and select uninstall, the right click anywhere in the window and select scan for hardware changes (or to that direction)
The computer will re-install the drive automatically, if the problem remains follow these instructions
http://www.fixya.com/support/r548399-fix_non_working_cd_dvd_shows_in_device
Sep 11, 2009 | ASUS Computers & Internet
Cd rom wont start (code 10)
Device failed to start. Click Update Driver to update the drivers for this device. On the General Properties tab of the device, click Troubleshoot to start the Troubleshooting Wizard.
943104 (http://support.microsoft.com/kb/943104/) Description of Code 10-related errors that Device Manager generates on Windows XP-based computers
Jun 21, 2008 | E-Machines Computers & Internet
Computers & Internet Logo
Top Conceptronic Computers & Internet Experts
David Payne
David Payne
Are you a Conceptronic Computer and Internet Expert? Answer questions, earn points and help others
