Question about HP OfficeJet 7410 All-In-One InkJet Printer
HP 7410 Scanner mirror dirty
I have had some work around the house and quite a bit dust. It seems that the scanner mirror is pretty dirty. Can't reach it, don't know exactly how to disassemble the unit.
Any hints or diagrams on taking this thing apart to clean the offending parts?
Much appreciated
  • Anonymous Apr 14, 2009
    This is from the HP manual and does not help with a dirty scanning mirror or underside of the glass giving poor scanned or copy images
  • 1,031 Answers
You can go tru this extract ON HOW TO FIX IT
clean the glass
Dirty glass, from fingerprints, smudges, hair, and so on, slows down
performance and affects the accuracy of special features such as Fit to Page and
Copy.
1 Turn off the unit, unplug the power cord, and raise the lid.
2 Clean the glass with a soft cloth or sponge slightly moistened with a
nonabrasive glass cleaner.
Caution! Do not use abrasives, acetone, benzene, or carbon
tetrachloride on the glass; these can damage it. Do not place
liquids directly on the glass. They may seep under it and damage
the unit.
3 Dry the glass with a chamois or cellulose sponge to prevent spotting.
clean the lid backing
Minor debris can accumulate on the white document-backing located
underneath the unit’s lid.
2 Clean the white document-backing with a soft cloth or sponge slightly
moistened with a mild soap and warm water.
3 Wash the backing gently to loosen debris; do not scrub the backing.
4 Dry the backing with a chamois or soft cloth.
Caution! Do not use paper-based wipes as these may scratch the
backing.
5 If this does not clean the backing well enough, repeat the previous steps
using isopropyl (rubbing) alcohol, and wipe the backing thoroughly with a
damp cloth to remove any residual alcohol.
clean the exterior
Use a soft, damp, lint-free cloth to wipe dust, smudges, and stains off the case.
The interior of the unit does not require cleaning. Keep fluids away from the
interior of the unit as well as the front panel.
Posted on May 14, 2008
Not printing magenta
just remove the toner and shake it and install it if it is empty then install new toner.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Apr 20, 2010 | HP Color LaserJet 2600n Printer
My scanner does not work on my hp laserjet 3055
It is a frequent problem in these models (scanner dirty dust) = Scanner bulb warming up
You need to loosen the top of the device and clean the scanner mirrors 5 more precisely using sticks with cotton on tops.
I will look for help and documentation in case that's the problem
Oct 27, 2009 | HP LaserJet 3055 All-In-One Printer
Magenta cartridge not working despite being full
This happens due to Laser sCANNER Contamination.
Light Output that typically starts fading along the outside edges of the media. The first noticable color would be Magenta.
Dusty Environments can lead to Laser Scanner Contamination. The dust layer on the mirrors prevents proper transmission of the laser output in the imaging system leading to faded colors on the printed page. The initial stages of this failure typically occur in the magenta or yellow color planes as faded or light color. Often the left side is more faded than the middle.
You may need to contact the nearest Authorized Service Tech and get teh Laser Scanner replaced with the new released service part that has a mirror in a location where the dust ideally cannot reach eazily.
Also, please ensure that the printer is relocated from the current location to a more dust free zone.
Aug 27, 2009 | HP Color LaserJet 2600n Printer
Magenta is not printing well, very light.
I have seen lots of printers with this problem. the issue is caused by a build up of dust on the magenta scanner mirror. cleaning the mirrors in the scanner unit is what you need to do. the scanner unit is accessed from the back of the printer. it is a bit of a strip down to remove the scanner unit and clean the mirrors , but it will fix this fault.
Jun 19, 2009 | HP Color LaserJet 2600n Printer
Magenta won't print
It's normally caused by dirty scanner mirrors, the machine will need to be dissembled, the laser scanner unit removed, taken apart and the mirrors cleaned. Unfortunately it is quite fiddly getting the scanner unit out, but this is a very common problem for the HP colour laserjet 2600's
Aug 24, 2008 | HP Color LaserJet 2600n Printer
Faint printing
Indeed, the problem here is dust building up on the scanner mirrors. The mirrors are hidden deep inside the printer, but if you have an hour to kill, you can disassemble the printer, clean them off carefully, and solve the problem. See the very detailed PDF disassembly guide at http://forums11.itrc.hp.com/service/forums/bizsupport/questionanswer.do?admit=109447626+1221679079368+28353475&threadId=1182873 . Solved all my problems.
May 21, 2008 | HP Color LaserJet 2600n Printer
Hp officejet 7410 fax failure
Had the same problem as everyone else here - would copy fine but faxing or scanning resulted in the "whizzzzzz" sound (with or without the sheet feeder) and a mandatory reboot.
I followed the suggestion of moving the scanner head to a different part of the drive belt and it works fine now (at least until that part of the belt wears down!). Here was the procedure - it took about 10 minutes.
  1. Remove all T8 screws from the top of the scanner bed - there are two hidden on the left side under the removable flap and two more hidden behind the front control panel cover, which just snaps off.
  2. There is a bundle of wires that prevents the entire top from lifting completely off, so lift it high enough to clear the plastic parts, then rotate it 180 degrees around and set it on something to support it.
  3. Lift the scanner head until it comes off the guide rod and disengages from the drive belt.
  4. Move the scanner head to the other end of the bed and reingage it onto the belt and guide rod - this is a little tricky to get the belt to pop back into the scanner head, but I got it to go by holding the belt firmly on either side of the head and squeezing both together.
  5. Replace top and all screws, pop control panel cover back into place.
  6. Rejoice in saving yourself lots of $$ and preventing more junk from entering the landfill!
Feb 29, 2008 | HP OfficeJet 7410 All-In-One InkJet...
Scanning from HP OfficeJet 7410 All-In-One to a Mac
Had same problem. Make sure you've closed any other apps. Itunes caused mine to fall over.
Jan 19, 2008 | HP OfficeJet 7410 All-In-One InkJet...
Problem in scanned work
The Reflective Mirror Set in the scanner were subjected to dust. Clean the Mirrors (wipe the Dust with a soft hair 1 inch Brush. Do it under an Expert's Supervision
Dec 02, 2007 | HP ScanJet 3200C Flatbed Scanner
Coppier Problem
The trouble is that the scanner assembly can't find its "home" station. Here is the most common solution. There is a reflective white stipe under the scanner glass that the scanner looks for. If the stripe is dirty, or if the scanner mirrors are dirty, the scanner won't sense its location, and cause a "scanner error". A qualified technician should be able to clean the assembly. The other option is to replace the scanner assembly. I hope this helps.
Feb 27, 2007 | HP LaserJet 3330MFP All-In-One Printer
HP OfficeJet 7410 All-In-One InkJet Printer Logo
329 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
