Question about JBL Music
JBL JRX115 producing very muffled sound even though graphics on mixer at normally used settings. Someone suggested we may have "popped" the horns. Is this potentially the problem. We have been running 600watt amps thru them. We have a big gig coming up. Help! Michele
  • JBL Master
  • 5,603 Answers
The speakers are rated 250 Watts. Driving with 600 Watt amps requires one to be careful of how much the volume is turned up to avoid damage. You MAY have damaged more than just the compression drivers on the horns but the voice coils on the 15 inch speakers as well. Further use could also damage the amplifiers. You did not mention what brand amps and it is possible they have a problem.
You best replace the units with ones rated for the power of the amps as restoring them on short notice for a gig is not practical.
Posted on Sep 12, 2010
  • Fred Yearian Sep 12, 2010
    The test you need to do is to "sweep" the units with frequencies from 30 HZ TO 12 KHZ. That will tell you the condition of the speakers.
How do I connect a 8channel mixer to a Kustom PA PA112S Powered Sub and 2 JBL EON615
I'd have to know the make and model mixer to properly advise you. In general, if I were you, I'd come out of the L/R mixer outs to the JBLs and run the sub from an aux send set to post faders.
However, I would suggest getting a different sub. That one will not keep up with the eon's.
You would probably need 4 of them to get close to matching.
Jul 12, 2016 | JBL Music
How to retract the cord
If your referring to removing the speakon connector you need to pull back on the silver tab on the top of the connector and turn the whole thing counter clockwise
Feb 25, 2015 | JBL JRX 115 JRX115 15 JRX118s 118s Speaker...
Muffled Sound From Speakers.
Please illuminate me explaining the word "Muffled" means and i will be glad to help you out...
Feb 10, 2013 | JBL *new* Jbl Jrx115 15" 2-way Speaker...
Sound gets muffled at certain frequencies. Please Help!
I think that rather than the mixer, that your front speakers may have a limiter built into the high frequncey amp. You may be asking them to do more that they are capable of.
Mar 04, 2017 | Behringer Sx2442fx Eurodesk 24channel...
JBL JRX118SP POWERED SUB. Getting power and signal light flashes when theres a signal. Just no sound??? Speaker/coil looks fine..
There's a 8-pin ic located right at the side of output devices & power supply filter caps, that is a common issue with JRX active subwoofers, hope it helps.
Jan 29, 2012 | JBL JRX 115 JRX115 15 JRX118s 118s Speaker...
I have 2 x jbl jrx 115 and 2 x jbl jrx 118s, we set up a power amp to desk and the 118s, into the left hand speakon connection, using a speakon to speakon cable, from the 118s a speakon cable is run out...
In spite of your description it is not quite clear of the connections... In general you should limit the number of speakers connected to an amp output to a maximum of two. I am not sure if you might have more than that in your daisy chain. Let's go over another important thing: are ALL of the amps and the mixer (desk?) powered from the SAME receptacle or power conditioning module? If not, make it so even if you have to run extension cords. The ground bounce of building power at venues can destroy your equipment. The brand/model of the amp(s) and the mixer would be useful to analyzing the problem. It is unlikely the failing battery in a guitar would kill one side of the PA. If the amp is overloaded, the thermal cutout may be disabling part of the amp and the system. Also please verify the RMS capability of your amp. You want the power of the amp to NOT exceed the rating of the speakers USE RMS VALUES... not the fakey "program" or "peak" ratings... those are just advertising gimmiks to show my numbers are bigger than yours... we know that game...
Sep 18, 2011 | JBL JRX 115 JRX115 15 JRX118s 118s Speaker...
How to hook up speakers? Sound sounds muffled
You DON'T connect speakers to this... this is NOT a powered mixer... you MUST use external amplifier !!!! You use bvalanced (TRS) cables to a suitable power amplifier which connects to speakers. Some Behringer mixers such as the PMP5000 have built in amplifiers to drive speakers... yours does not.
Jul 23, 2011 | Behringer Xenyx 1002fx Mixer 10 Input 2...
We just had our church sound system totally redone. When any equipment is plugged in or unplugged we get really bad pops. The system has to be off to change any instrument. The guy who installed it said...
If your system has a mixer attached (I'm assuming it does) make sure mixer channels are muted when turning system on and off. Also mute channels when plugging in instruments. Muting channels will protect system from pops (and yes they are normal) You really should have someone operating mixer whenever you use system. For more info; contact folks at ALS (Audio Logic Systems) they're in Bloomington, Minnesota but contact them online and they'll help you through any problems. They specialize in House of Worship Audio.
Feb 24, 2011 | Music
Music Logo
306 people viewed this question
Top JBL Music Experts
Michial Gueffroy
Owen Barnes
rhodesworks
Are you a JBL Music Expert? Answer questions, earn points and help others
