I have a Phillips FA 9400 stereo with seperate CD player combo attached. Speakers are attached and all functions run but there is no sound or tuner working. I have lost the remote control I house moving and when its powered up the standby lights up on the tuner.Could the problem be that I need to get a infra red remote that activates the tuner to get sound to the other functions or is the tuner stuffed. All I want working is the turn table to transmit sound through the speakers so I can listern to some vynle reconds I have. Jake
SOURCE: Shows to be stuck in Standby.
hold down the enter button and the advanced surround button for 5 seconds or so and the amp will restart, the display will come up and hopefully it will be ok. its often caused by using speakers under 8 ohms, or damaged speaker cables etc
Posted on May 28, 2007
SOURCE: Onkyo TX-SR606 getting no sound from HDMI sources
Not sure if this is your fix, but I had what I thought was the same problem. I played with my Onkyo quite a bit ensuring the correct assignments for HDMI, audio and all that stuff. Turns out I neglected to make sure the output devices were properly assigned. Many devices aren't default to output sound over HDMI. I changed the audio out settings on the cable box to HDMI and suddenly the Onkyo worked great. I know, I'm an idiot for not checking that in the first place, but maybe someone out there is having the same trouble as well.
Posted on Apr 05, 2009
dunnbiker
  • 8546 Answers
SOURCE: won't power up; push power button on, hear click in back left of unti, get nothing on front display and no output from speakers; as if unit trying to operate
Disconnect the speakers and see what happens. Carefully examine the speaker cables for unwanted connections (shorts).
Take a clue from when the power problem appeared. Something was moved and made the buzz a (probable) dead short.
Posted on May 16, 2009
  • 17 Answers
SOURCE: Zone 2 speakers only work with the tuner - no
hi,
zone 2 will only work with analog sources so if your dvd, cable and other devices are connected via HDMI, that alone won't work. What you need to do is hook up RCA (red and white) cables from the dvd player to dvd in of the receiver and same thing for your satellite box (and other sources.) no need to change any setting on the receiver. This way, the HDMI will take care of your main room speakers and the RCA will feed your zone 2 speakers.
Hope this helps.
Posted on Jul 10, 2009
boogieman347
  • 3 Answers
SOURCE: Can't get B Speakers to work
I have almost the same problem except that my tuner doesn't work with my remote/patio spkrs either. No sound on all inputs! The remote speaker light does come on but no sound. Unfortunately I have no remote for this unit (I am using the front panel and/or my Harmony700 RCU). Any help would be appreciated.... hopefully resolve both our problems. ;-)
Posted on May 30, 2010
Need to know if a looped ground would make it where the tuner on my car stereo works fine but the cd player only uses the subs and no other speakers work ? On a 1995 BMW 325i
It sounds to me like you are using more than one amplifier and are using the blue wire (power antenna remote turn on) to turn the amp for the rest of your speakers. The blue wire turns off when leaving tuner mode, thus turning off the amp(s).
Dec 31, 2012 | Sony MEXBT2800 AMFMCD Car Stereo Receiver...
Amplifier - TA-AX380; CD Player - CDP-C40; AM/FM Tuner - ST-JX380; FM Stereo/FM-AM Receiver - STR-AV570X, and Stereo Cassette Deck - TC-W380.....all Sony. Very old system, do not have the manuals, they...
Since you have 2 receivers, you can either use the Sony STR-AV570X or the TA-AX380. You will need 3 Stereo RCA Cables to connect your CD Player, Tuner, and Tape Player. The speakers connect to the receiver you choose using the speaker input terminals.
Here is the diagram (click on picture to enlarge):
Jun 22, 2011 | Audio Players & Recorders
I HAVE A OLDER KENWOOD STACK HOME STEREO SYSTEM WITH OUT MANUALS OR REMOTES AND NEED TO KNOW HOW TO HOOK ALL THE COMPONENTS TOGETHER. KC-206 STEREO CONTROL AMP KT-76 TUNER KX-96W CASSETTE DECK KM-106...
start with the tuner, hook up the equalizer to the tuner, then on the rear of the equilizer hook up all the peripherals except the amps which will go to the tuner outputs and all will feed thru the tuner to the amps and out to the speakers
Oct 23, 2009 | Audio Players & Recorders
I HAVE PANASONIC CQ-C700U STEREO PLAYS ON ALL
are you running the rest of your speakers off an amp? if so, it sounds like you have the amp remote wire connected to the power antenna wire. on some radios there is an amp remote wire and a power antenna wire. the power antenna wire loses power when not listening to the tuner (radio). usuall there is a solid blue and a blue with white stripe. the blue with a white stripe should be amp turn on.
Aug 19, 2009 | Panasonic CQ-C700U Car CD/ MP3 Player
Problem with stereo output on Edirol FA-66
Possibly, your adapter of small to big is not a stereo adapter. Seems like a mono adapter.
Jun 15, 2009 | Edirol FA-66 Sound Card
Does this tv have a digital tuner or will I need a converter box?
Coby tf-dvd1540 tv
No ATSC tuner in this TV. You will need a converter.
Product Features
  • 15-inch flat-panel TFT LCD TV with built-in side-loading DVD player
  • Standard 4:3 aspect ratio, native 1,024 x 768 resolution
  • Plays DVD, CD and recordable MP3 music CD-R/CD-RW
  • Built-in NTSC TV tuner lets you switch between DVD and terrestrial broadcast viewing
  • Stereo speakers with 3 watts per channel; includes full-function remote control; onscreen display simplifies setup and operation
Technical Details
  • Brand Name: Coby
  • Model: TFDVD-1540
  • Display Technology: TFT active matrix
  • Display Size: 15 inches
  • Image Aspect Ratio: 4:3
  • is_hdtv_compatible: N
  • speakers_included_description: 2 speakers
May 13, 2009 | Coby TF-DVD1540 15 in. TV/DVD Combo
Can I plug my MP3 player into the aux. socket on my car radio, with the appropriate cable and play the stored music?
You should be able to do that as long as you have the right cable.
Most of the mp3 players have a "mini-stereo" jack (3.5mm) and some car stereos have the same type of jack for "aux" input, and others car stereos have RCA jacks for the "aux" input.
Even if the jacks are not the same type, you can use an adapter cable that converts the mini-stereo jack to an RCA jack. You can find them at many places like Best Buy, Circuit City or Radio Shack.
Depending on the type of car stereo you have, you would normally press the source button to change between the tuner, cd player, aux or whatever you may have connected to the stereo. You may even have a seperate button to press for the "aux" input.
I hope this was helpful to you, if you need more information just ask, and please give more info on the type of mp3 player and the make and model number of the car stereo.
Jun 21, 2008 | Car Audio & Video
No Sound
most ram trucks came with a infinity system. the amps are in the front doors, mounted to the 6x9 speakers. and they power the tweeters in the columms, and also rear speakers if you have them. I had to replace the entire system.
Aug 23, 2006 | Pioneer DEH-P47DH CD Player
386 people viewed this question
 Grubhead
Grubhead
