Question about Denon Audio Players & Recorders
I have a Denon DP-51F turntable. It was fine the last time I played it, which was a number of years ago. Recently I wanted to resurrect it and I seem to have a problem with the lifter and/or tone arm. The platter turns, the lifter lifts the arm up and moves it to right above the record, but the arm won't lower down onto the record. Any ideas? Thanks! Paulann
  • centsayuma Jun 07, 2011
    Dear filmclass,
    I actually have not yet tried the solution. Your query has reminded me about it. so thanks! I'll let you know how it goes.
    centsayuma@pacbell.net
    Champion:
  • Denon Expert
  • 271 Answers
Hi, it has seized from lack of use. Disassemble and lube it. styluscity@gmail.com
Posted on Sep 13, 2010
  • centsayuma Sep 14, 2010
    Dear styluscity,
    thanks for your response to my question about the non-lowering tone arm on my denon turntable. What kind of lube do you recommend?
    Thanks!
    padraiginr
  • filmclass Jun 07, 2011
    Greetings. I seem to have the same problem with my Denon DP-300F. Did you find a solution to your problem. I'm probably going to open it up to see if some of the linkages need oil/lubrication.
    Cheers,
    Soon
    filmclass@gmail.com
Brand new Denon DP 300F turns extremely slowly.
The turntable should be under warranty still so contact the makers and they should sort it out. Any tampering with it could void any warranty so don't let any unathoriesed person touch it.
Dec 13, 2014 | Denon DP-300F Turntable
Adjust pitch
Register (free) at Vinyl Engine and download the service manual. The adjustment you need to do seems fairly simple. You will need a turntable strobe disk to get the the speed right, unless you have perfect pitch.
http://www.vinylengine.com/library/denon/dp-29f.shtml
Jun 19, 2014 | Denon DP-29F Turntable
In my DENON DP-300F tone arm don't come back after playing record. It just stays in the end of record? How can i fix it?
A lot of decks don't actually do that anyway. But if it previously did this then it's probably a mechanical problem. Removing the bottom of the turntable might show up the cause of the problem.
Dec 08, 2012 | Denon DP-300F Turntable
What cartridge to use on Denon DP-DJ151?
Anything that will fit the headshell. You can spend a few pounds or few hundred on them. It depends what kind of quality you want.
Dec 04, 2012 | Denon DP-DJ151 Turntable
DP29F turntable has static
either you haven't earthed the deck to the amp, on the proper ground screw, or your head shell wires are touching.
if the cartage(the thing the needle slots into) unscrews from the tone-arm, try unscrewing it,then putting back on, nice & tight....
if it still does it then it's your RCA leads that go from the deck to the amp(phono cables).
normally you would wire a deck/decks to a mixer first, then from the master out on the mixer to the AUX IN on the amp.
Oct 21, 2012 | Denon DP-29F Turntable
Denon DP-297 Turntable Tone Arm Skating
There should be a weight on the end of the arm, this needs to be adjusted. Some have numbers on them, increase the number shown. To get it to work right you will have to do it by trial and error. Increasing the weight in small steps, then playing a record. The trick being so it stays in the groove, but not too much so it rumbles on the sound. You will need to repeat the process several times till it sounds right and stays in the groove.
Jan 10, 2012 | Denon DP-29F Turntable
Which thickness setting should I use when playing my 33 rpm records on my Denon DP 297 fully automatic turntable? 17 or 30?
hi,
There are only two types of records available like 17 and 30. the size 30 will be as same as the turn table plater's size. 17 will be in half sized of the 30.
OK
Oct 22, 2011 | Denon DP-47F Turntable
Do I need an adapter for playing 45rpm records on my denon dp-26f
The only adapter you will need for 45's are for the ones with a large hole in often used in jukeboxes.
Jul 17, 2010 | Denon DP-47F Turntable
I have a Denon DP-51F Turntable that recently developed a speed control issue when playing. I noticed the "lock" indicator also flickers when the speed becomes erratic. It's direct drive, and I...
Hi. I also have a DP-51F and am experiencing severe problems with tracking. My sense is that the tone arm may be damaged. Would you be willing to sell parts from your turntable if you're not going to repair it? Let me know as I would be interested.
Oct 21, 2008 | Audio Players & Recorders
766 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
