Question about Pioneer PureVision PDP-4330HD 43 in. HD-Ready Plasma Television
Randomly shutdown and eo1 error
My plasma will randomly shut-off. When I press the on button on the remote or the on button on the plasma display the unit will turn on but there is an eo1 error display. But sometime the unit is working fine and will randomly shut-off again.
  • asc313 May 14, 2008
    Brought my media receiver to a qualified pioneer service center. Use it for one night and no problems occured but on the second night the same problem showed again. The technician said he resoldered some connectors in the power supply. Thanks for replying.
    President:
  • 2,712 Answers
There are several things that can cause it. You are best to have an expert technician come in and take some test on it in order to determine if it is from vertical blanking failure or something else. It is not easy to fix this yourself, if you have no experience, because there are a lot of parts that have to be removed before you can reach the components. It could be as simple as a loose connector ribbon or a bust capacitor, but it could also be more complicated. Hence, in my honest opinion, better get a qualified technician.
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
P.S. - You can rate a solution with one of four ratings as explained under (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem.
  • "Helpful" - The solution provides useful leads that helps solve the problem.
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated.
  • "Inappropriate" - The solution has absolutely nothing to do with the problem.
Thank you for using FIXYA!
IrishDruid
Posted on May 14, 2008
  • Swilin Sampson
    Swilin Sampson May 14, 2008
    Looks like he did not do a very good job. Sounds like cold solders/fractured soldering on the PCB to me..
  • Swilin Sampson
    Swilin Sampson May 31, 2008
    This thread has gone 14 days or more without a response.
    Please close the thread with a “FixYa” or “Helpful” rating.
    Or post back with latest developments, what steps you took,
    etc. and I will assist you further as best I can.
    Thank you.
    IrishDruid
Continuous blinking light on Panasonic Plasma
had the same problem wih my panasonic, it was a faulty power switch. make sure the power switch is sitting centrally in its housing, if not you may need a new switch
Jan 02, 2014 | Panasonic TC-P58V10 Plasma TV
My laptop will just randomly turn off...it will run well for a few minutes and then just turn off and everytime i try to start it over it turns off even quicker...within a minute or two...i realy need help...
Scanning computer to eliminate malwares, spywares and the viruses from your laptop.
2- Repairing and cleaning Windows registry.
These two tips are found to be very helpful to fix the laptop shutdown problem. Almost all the computer users surf internet which could result in viruses attacking your system. Some of these infections are really pesky and cause the machines to shutdown randomly.
The registry errors, however, are the internal errors and can become a cause of system crashes and freezes. The registry keys shall be in good health to keep a system perfect.
When I noticed my laptop keeps shutting down everytime, I tested the Intel Software Partner, RegInOut to fix the random shutdown problem with my laptop.
Nov 02, 2010 | Acer Aspire 5315 Notebook
My dell inspiron 1525 notebook keeps shutting down everytime
Sep 23, 2010 | Dell Inspiron 1525 Notebook
Randomly shuts down. Dell Inspiron 1000 with battery removed it will usually get past login and stay up for a while all hibernation options have been turned off.
check that it is not heated up Scanning computer to eliminate malwares, spywares and the viruses from your laptop.
Aug 31, 2010 | Dell Inspiron 1000 Notebook
My computer is shutting down on its own. Is this
May 15, 2010 | Dell Dimension 3000 PC Desktop
My computer keeps shutting down randomly. Also when i try to use F10 it will not respond if i try and run error checking the system will crash/shut down or give me a black screen. Basicly it randomly...
Possibilities:
1. overheating, and automatic shutdown.
Check that the fans are working.
2. bad RAM, causing "random" crashing.
On a "good" computer, download the free 'MEMTEST86+' software, and run it, to test your RAM.
3. Leaking capacitors on motherboard, causing "voltage-spikes", leading to "random" errors.
4. Bad disk-drive. Remove the disk-drive.
Connect it as a "slave" drive in another computer,
and run 'CHKDSK' ("Check Disk") to look for problems.
Apr 16, 2010 | HP Pavilion a450n PC Desktop
Shuts down randomly. Has been cleaned of dust,
Hello there...
I've been experiencing similar problem once.
In my case it was caused by faulty Network Interface Card, if you have a PCI Network Interface Card try temporarily remove it from the PC and then use the PC as you would normally do.... and see if it still shutdown randomly.
And if after test there is no random shutdown occurs, consider to replace your Network Interface Card.
Hope that helps... :D
Apr 13, 2010 | HP Pavilion s7600n PC Desktop
Aiwa TV MODEL No. TV-A149 AGING
I have Aiwa TV MODEL No. TV-A149
The problem that I am suddenly facing is that I can't change channels or volume or use any other function. I can't even turn it off with remote control.
Its stuck randomly on a particular channel that I was watching at that point of time.
Along with that channel it now shows a message in flashing red color that reads :-
AGING
6EDEH
Now when I press ''Display'' button on remote control volume goes off and this code is shown :-
S123 K234 Y
100 000 0
The numbers in the second line can be navigated by ''CH+'' button and changed between 0 and 1 by ''Vol+'' button.
I really don't know anything about this. So, please help me out of this problem.
Sep 14, 2009 | Aiwa TV-S2011 20"
Sansa e250 froze in shut down mode
You keep on pressing the center button and menu button randomly it will shutdown properly . After it has shut down properly connect to pc and have a virus check over the player . And remove any virus present in it .
Jan 30, 2009 | SanDisk Sansa e250 MP3 Player
Buttons dont respond correctly
Sounds like one or more of the keypad buttons are sticking - That would also cause the remote control to stop functioning.When you saw "P:0 V:0" you somehow managed to put the tv into the service menu. Pull the keyboard away from the plastic buttons and make sure nothing is in the way.
Aug 22, 2007 | RCA P52929 52" Rear Projection Television
Pioneer PureVision PDP-4330HD 43 in. HD-Ready Plasma Television Logo
875 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
