Question about Logitech FreePulse Wireless Consumer Headphones
My Logitech FreePulse headphones won't pair with my Windows 7 laptop. It says no driver is available. Is this right?
SOURCE: no sound
hold both buttons until they blink blue and red. will take around 20 or 30 seconds of holding. When they both blink red and blue, they will sync.
Posted on Nov 26, 2007
SOURCE: logitech freepulse headphones not charging?
Same Problem, Headphones will charge but they wont turn on no matter what you do. Called, got them replaced, so I thought hmmm I can figure out what went wrong with the old ones.
It is the switch itself. The connection next to the charging plug does not make contact anymore. It is a weak point and after putting excessive force on the power button it actually twists the switch enough to beak the solder joint. DO NOT LIFT THE SWITCH ITSELF! Just solder the one next to the charging plug and it will be good to go.
To take them apart is a pain. Remove foam by pulling on it. Remove tiny torrx screw (CR VT-6, bit I used), then remove (actually pry up) silver "ring" at the point where the band meets the ear piece. Finally, pry apart at the band section. I used a razor blade. It is 4 tabs on the inside and is a pain, but came apart. Then take 2 screws out to remove the band and there is the board.
Solder the switch next to the light and charge plug and it is good to go.
Hope this works,
Ryan R. Gerner
Posted on Feb 28, 2009
debasish05
  • 34 Answers
SOURCE: My Logitech headphones mic won´t work with windows
Your headphone mic is all right. The problem is with the sound driver you are using. Many a time the headphone jack are not properly connected so it may be another issue for not working of your headphone. Your operating system is all right check out the sound driver setting from the control panel.
Good Luck
Posted on Mar 02, 2009
  • 11 Answers
SOURCE: Windows 7 and Dell BH200 Bluetooth Headphones
You have to set bluetooth as default audio device. For doing this, go to >Contro Panel> Sound and Audio Devices>Audio(Tab) and in Default Device choose bluetooth device.
In my case, I had problem when i installed SP3 on XP. I changed my bluetooth driver to "Toshiba Bluetooth Stack V6.00.10" and it worked for me.
Posted on Oct 31, 2009
  • 272 Answers
SOURCE: my skullcandy earphones are busted
could be caused by the way you wrap them up the cords should never be wound tightly it causes a short and it just so happens that earphones are made of light weight wiring to make them seem to disapear when wearing them so what to do is instead of winding them when your done simply fold them loosely so to speak
Posted on Feb 25, 2010
I need a replacement earloop for my freepulse wireless head set.Who do I talk to about that?
You can buy here: http://buy.logitech.com/store/logib2c/en_US/DisplayCategoryProductListPage/categoryid.13978300?resid=UOVD9woHAtcAAAw@Ex0AAAAP&rests=1357202423124
Tim
Oct 31, 2010 | Logitech FreePulse Wireless Consumer...
My connector is frozen on blinking red and blue. It will not connect with the head phones and go solid blue.
Have you tried doing the same with the headphones? If you hold the power button down on both the transmitter and heaphones (get them both flashing red and blue), they might pair.
Jul 15, 2010 | Logitech FreePulse Wireless Consumer...
My Freepulse headphone won't pair anymore. Both components charge, both both of them display the red LED light. I've tried the override button on the transmitter, and I've tried holding the power button...
You hold the button on the transmitter for about 50 seconds - light flashes red, solid red, goes off and then flashes blue and red. Then you can do the same on the headphones. Then wait and they should pair.
Jun 29, 2010 | Logitech FreePulse Wireless Consumer...
Samsung's yp-t10, can it be paired with freepulse?
Yeah, they were quite well together i have them both.
To connect
1. Hold the switch button on the Free pulse until it flashes
RED & BLUE
2. Go to bluetooth setting in the T10 and add Headphones
3. Turn on headphones when turning on T10 should automaticaly connect.
Jan 06, 2009 | Logitech FreePulse Wireless Consumer...
Logitech Freepulse headphones won't turn on
There is a reset button on both the headphone and the transmitter. Try to reset them both before attempting to pair them again. Since the led won't turn on there is a possibility that the battery is not charging. Is the orange light working when the headphones are charging? It should be and then it should turn off when the battery is full.
Nov 25, 2008 | Logitech FreePulse Wireless Consumer...
I have Logitech wireless headphones for my Ipod, and I can't get them to work. When I press the on button on both pieces, it goes solid red and not blue.
Visit the Logitech support website and find the instructions to reset and pair them. Since yours is for an Ipod I'm assuming you have the older white/grey model and not the freepulse headphones. The procedure is not the same. From memory the procedure it to reset both (look for the small hole to insert a paperclip). Once both are reset begin with the transmitter. Hold the power button down for about 30 seconds until the light flashes red and blue. When it does do the same for the button of the headphone until it flashes red and blue. When both are flashing red and blue they should pair together and the lights should turn solid blue..
Oct 15, 2008 | Logitech FreePulse Wireless Consumer...
LOGITECH DONGLE
Go to this URL:
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/
std_adp.php?p_faqid=53
You may be able to get a replacement this way..
Mar 04, 2008 | Logitech FreePulse Wireless Consumer...
Batteries
Logitech Customer Sales at 1-800-231-7717, Monday through Friday from 6am - 6pm PST.
cheers
Jan 10, 2008 | Logitech FreePulse Wireless Consumer...
Logitech Freepulse headphones on Ipod only playing on one side
Seems like you have a faulty transmitter unit. Try contacting logitech.
Sep 13, 2007 | Logitech FreePulse Wireless Consumer...
I need to get part for my Logitech FreePulse headphones!
You need to contact these people; http://www.logitech.com/index.cfm/contact/&cl=ru,ru Hope this helps :)
Jun 27, 2007 | Logitech FreePulse Wireless Consumer...
Logitech FreePulse Wireless  Consumer Headphones Logo
293 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Jerry Umali
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
