Question about HP DeskJet 6540 InkJet Printer
Where can I find a diagram of the black ink cartridge so I can locate the proper place to re-ink it?
    Guru:
  • 170 Answers
NOTE: If a refilled or re manufactured print cartridge, or a cartridge that has been used in another product, is installed the ink level indicator is inaccurate or unavailable.
  • Make sure that the product is turned on and connected to the computer.
  • Click Start and click Control Panel .
  • Double-click the Printer and Faxes folder.
  • Right-click the icon for the product and click Preferences .
  • Click the Services tab, and then click Service this Device .
  • The printer Toolbox opens. Click the Estimated Ink Level tab. A graphic showing the estimated ink levels appears. The graphic shows both the color and black ink cartridge with the ink level indicated by the fill inside the cartridge diagram. Figure 1: Estimated ink levels - both cartridges lowWhere can I find a - c738e3b.gif
    Posted on Sep 12, 2010
    Ink jet cartridge
  • 1 Select the ink cartridge specific to your printer. Canon inks are versatile, so your selection may be as simple as choosing between black, color or a multi-pack with black and color cartridges.
  • 2 Turn on your Canon printer. The switch is generally located on the top right hand side of the printer. Open the printer's lid.
  • 3 Wait a moment. The cartridge carrier will automatically disengage.
  • 4 Put your hand behind the existing ink cartridge and pull the cartridge towards you until it pops out. Dispose of or recycle the used cartridge.
  • 5 Carefully pull the tape off the new cartridge.
  • 6 Position the new cartridge into the cartridge carrier. Make sure it is facing the correct position.
  • 7 Press the cartridge carrier gently until it clicks into place. Some cartridges have indicators to demonstrate that they are properly positioned.
  • 8 Close the printer's lid. Print a test page to ensure everything is working properly.
  • Hope It's resolve all Your Printer Problem,
    Or Still having Problem Then follow Us For
    Canon Printer Support
  • Apr 22, 2014 | Canon MX340 AllInOne InkJet Printer
    Finding compatible upgrade to cpu 870
    Instructions
    5
    6
    7
    8
    Jan 10, 2013 | Dell Studio XPS 8100 PC Desktop
    How do i install the ink cartridge in my lexmark z35 printer
    Oct 31, 2010 | Lexmark Computers & Internet
    MP210 am unable to install ink cartridges properly
    1 Open the printer cover and prop it up with the support brace located on the right-hand side of the cover. It's similar to the way a car hood is propped open.
  • Step 2 Remove the black FINE ink cartridge from its container and locate the protective tape. Gently remove the protective tape used to cover the print head nozzles and electrical contacts.
  • Step 3 Insert the black FINE ink cartridge into the printer slot labeled "B." It will rest on a slight angle. Push the cartridge up and back until it clicks into place.
  • Step 4 Repeat the process for the color FINE ink cartridge, placing it in the slot labeled "C."
  • Step 5 Raise the printer cover slightly to loosen the support brace. Fold the brace inward and replace the cover to its closed position.
  • Step 6 A green LED light will flash on top of the printer. In about a minute, the LED stops flashing and displays "1." Once the "1" appears, you're ready to print.
  • Hope this helps...............Leadfoot44
  • Apr 15, 2010 | Canon PIXMA MP210 InkJet Printer
    How do I open my canon printer to change the ink cartige?
    Step 1
    1. Select the ink cartridge specific to your printer. Canon inks are versatile, so your selection may be as simple as choosing between black, color or a multi-pack with black and color cartridges.
    2. Step 2 Turn on your Canon printer. The switch is generally located on the top right hand side of the printer. Open the printer's lid.
    3. Step 3 Wait a moment. The cartridge carrier will automatically disengage.
    4. Step 4 Put your hand behind the existing ink cartridge and pull the cartridge towards you until it pops out. Dispose of or recycle the used cartridge.
    5. Step 5 Carefully pull the tape off the new cartridge.
    6. Step 6 Position the new cartridge into the cartridge carrier. Make sure it is facing the correct position.
    7. Step 7 Press the cartridge carrier gently until it clicks into place. Some cartridges have indicators to demonstrate that they are properly positioned.
    8. Step 8 Close the printer's lid. Print a test page to ensure everything is working properly. ....plz give feedback..
    Nov 15, 2009 | Cannon Canon i960 Photo Printer
    Ink cartridges are wobbly & not sitting properly-No ownermanual
    tis happens only when u change the places of black and colour catridges
    try fitting correctly
    if still the problem retains then u must hav got the wrong catridges
    Mar 09, 2009 | Canon BJC 2110 InkJet Printer
    U163 keeps coming up!!
    Replacing An Ink Cartridge Use the following procedure to replace empty ink cartridges or when an ink cartridge error appears.
    1. Confirm that the printer is powered on
    2. Lift the Scanning Unit (Printer Cover) with both hands, and pull the Scanning Unit Support down into place (A).
    Note: After confirming that the scanning unit support is fixed into position, release your hands.
    3. Press down on the semi-circular tab located on the top of the cartridge to release the cartridge and then remove it.
    Note: Handle the ink cartridges carefully to avoid staining clothes and surrounding work area.
    4. Remove and replace each cartridge individually. Or, remove the second cartridge after the first has been removed.
    5. Take out a new cartridge from its casing and gently remove the orange protective tape in the direction of the arrow.
    Note: - Do not attempt to reattach the protective tape once you have removed it.
    - Do not touch the gold electrical contacts or the print head nozzles after removing the protective tape.
    6. Insert the ink cartridge into the ink cartridge holder.- Black: the left slot- Color: the right slot**One black cartridge and one color cartridge must be installed in the machine in order for the printer to operate. It does not matter if the capacities (Standard or High) do not match.
    7. Push up on the front of the cartridge until it locks into place. (A click sound will be heard when the cartridge is locked in place.)
    8. Confirm that the ink cartridges are installed properly.
    <1> The ink cartridge is not installed properly.
    <2> The ink cartridge is installed properly.
    1. Fold the scanning unit support and close the scanning unit (printer cover).
    2. Wait until the preparatory operation is complete; it takes about one to two minutes.
    I hoe it helps!!!
    Dec 05, 2008 | Canon PIXMA MX310 All-In-One Printer
    Cartridge problem
    Basically, you placed a black ink cartridge [30] into the compartment for the color one [31]?
    Make sure you have a black ink cartridge in the left compartment, and a color one in the right one. I don't even think it would properly fit if they were in the wrong slots. They should "click" into place, confirming that they're installed properly.
    Sep 08, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
    CANT FAX
      *Optional cartridges PG-40 and CL-41 shown in examples
    9. Fold the scanning unit support and close the scanning unit (printer cover).
    10. Wait until the preparatory operation is complete; it takes about one to two minutes.
    Mar 28, 2008 | Canon MX300 Office All-In-One Printer
    Scanner
    Solution: Replace ink cartridge(s) MX310.
    Feb 08, 2008 | Canon MX300 Office All-In-One Printer
    HP DeskJet 6540 InkJet Printer Logo
    325 people viewed this question
    Ben Johnson
    mukhtar21 shaikh
    mukhtar21 shaikh
