Question about Hotpoint WMA76 Front Load Washer
We have an Ultima WMA76. We can't get the door lock light to go out and stop beeping, even though the door os locked shut. Can anyone help. Decka
I have the same problem, did you manage to resolve yours?
Posted on Apr 17, 2011
Hey my Samsung cooltech plus is making beeping noises fridge temperature is jumping from one temperature to another while the beeping noise is going on. Can anyone please help me thank you
Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :
http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.
http://www.appliancerepair.net/refrigerator-repair-1.html
Refrigeration System Basics Chapter 1 Cause of Beeping Noise in Frigidaire Refrigerator eHow
Feb 14, 2017 | Samsung Refrigerators
Hi, I have a kenmore elite deep chest freezer. Model 253.16582105. can't stop the beeping, even after replacing the 9 volt battery.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.
Mar 26, 2016 | Kenmore Refrigerators
Wma76 spin and door lock issues
Most likely a motor control issue or possibly the motor itself
Oct 30, 2017 | Hotpoint WMA76 Front Load Washer
How do you get child lock off
Try this procedure.
Hold child lock button down for 4 seconds.
You should hear beeping sound, and child lock safe light should go off.
If it does not work, then try it again.
Please rate my solution.
Thankyou.
Jan 12, 2010 | Hotpoint WMA76 Front Load Washer
"Door Ajar" signal on dash panel stays on even when doors are clo
there should be a switch mounted( or more than one) in the door jamb that tells the car when the car door is open...i will probably look like a little plastic plunger...might be broken off or bad internally
Feb 22, 2009 | 2008 Pontiac G6 Sedan
Pushing Start Button only results in "Beep, beep, beep"
Need to check that the lid is shut properly and the door is locking. You don't mention an error code in the display. Make sure there isn't one showing.
Mar 14, 2008 | Maytag Neptune MAH5500B Front Load Washer
Door lock light flashing
Shame to say it but yes..
You board behind the control pannel is blown. this is caused by either a faulty door swtich or the motor.. Your model number tells me its most likely the door switch.. The control board will need replacing and the door swtich.
Getting to the board is easy only three screws near the soap draw. make sure you write which wires go where and to getto the door lock undue the door rubber if you needany further advice let me know
i have worked on more the 300 of these machines
Dec 24, 2007 | Hotpoint WMA76 Front Load Washer
Faulty door which keeps beeping
The door could be closed physically but the not electricity because a defective lid switch that should be replaced. Good luck!
Nov 01, 2006 | Hotpoint WMA76 Front Load Washer
Hotpoint WMA76 Front Load Washer Logo
205 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
