Question about Brandt Washing Machines
I dont know how to open panels in order to fix a water leakage type D800-D/Dj no. 5-47-00090
  • 10,865 Answers
Hello. Usually, you do not have to open up the machine to fix water leaks. Read on
If the washer leaks only during the fill cycle, check these: Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it. The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak. Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak. During drain and spin only A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details. All the time If the washer leaks all the time, check these: Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate. Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician. Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it. Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
Posted on Sep 12, 2010
Has this camera (D800) been recalled for any problems?
It appears that it has!
  • Nikon EN-EL15 Battery Recall Service Advisory en.nikon.ca/.../h0ndzaip/EN-EL15-Battery-Recall-Service-Advisory.html Nikon Canada is asking your cooperation in connection with a voluntary recall of certain lot numbers of its Nikon Model EN-EL15 rechargeable lithium-ion battery pack.
  • Nikon recalls batch of 1 V1, D7000, D800 and D800E ... www.dpreview.com/articles/8182044278/nikon-en-el15-battery-recall
    • FIRST POST: 2012-04-25
    2012-04-25 · Nikon has announced a voluntary replacement scheme for a sub-standard batch of batteries for its 1 V1, D7000, D800 and D800E cameras. EN-EL15 batteries ...
  • Service Advisory - Nikon www.nikonusa.com > Service Advisories > Service Advisory Details Nikon Inc. is asking your cooperation in connection with a voluntary recall of certain lot numbers of its Nikon Model EN-EL15 rechargeable lithium-ion battery pack.
  • Nikon D800 & D800E Review - KenRockwell.com www.kenrockwell.com/nikon/d800.htm The Nikon D800 is the world's highest technical performance DSLR for outdoor, nature, landscape and many other kinds of precision photography.
  • Nikon recalls battery packs sold with D800 and D7000 due ... www.engadget.com/2012/07/11/nikon-d800-d7000-battery-recall 2007-11-12 · Some important news for anyone who bought a Nikon D800 or D7000 DSLR earlier this year. The US Consumer Product Safety Commission and Health ...
  • Is the new D800 "free maintenance service initiative" just ... nikonrumors.com/2015/07/13/is-the-new-d800-free-maintenance... 2015-07-13 · Today Nikon sent out letters to selected D800 camera owners to participate in a free "Nikon Maintenance Service Initiative". I am not sure if this is another
  • Nikon Issues Battery Recall On EN-EL15 For D800, D800E ... www.popphoto.com/.../nikon-issues-battery-recall-en-el15-d800-d800e... 2012-04-25 · Users of the D800, D800E, D7000, V1 take note - Nikon has issued a limited recall of some of your batteries due to electrical issues. This is the EN-EL15 ...
  • Nikon partially recalling D800! Again.: Nikon FX SLR (DF ... www.dpreview.com/forums/post/56139173 Nikon partially recalling D800! ... This is nothing but a recall cleverly disguised ... in Nikon Inc. s Free Maintenance Service Initiative for your Nikon D800 ...
  • Nikon has a fix for the D800/D800E asymmetric focusing issue nikonrumors.com/2012/07/02/nikon-has-a-fix-for-the-d800d800e... 2012-07-02 · Ming Thein mentioned on his blog that Nikon already has an internal fix for the D800/D800E asymmetric left focusing issue: "Was told by NPS this morning ...
  • Nikon Acknowledges D800 Left Focusing Problem - Fix Is ... https://www.slrlounge.com/nikon-acknowledges-d800-left-focusing... Nikon Acknowledges D800 Left Focusing Problem - Fix Is Available. ... • Nikon does actually not know how many D800 of the early batches have been affected.
  • Apr 22, 2016 | Nikon D80 Body Only Digital Camera
    SANYO SPLIT TYPE AIR CONDITIONER LEAKING
    The leakage is probably from condensation and there should be some sort of drain for it. You should check to see if it is clogged or partially clogged. Also since you say it does it when it hasn't operated for a while you may want to check out where the lines pass through the wall and make sure that it is sealed up there so you don't get leakage from out side.
    May 04, 2010 | Sanyo Split System Air Conditioner
    Dell Latitude D800-Win XP- My Dvd/rw wont write
    Because you lost two devices, the DVD and the wireless mini card, I believe your problem is a drivers issue.
    You should make sure you do not have any Malware that is removing these drivers.
    If you have access to the Internet download and install Malwarebytes. It has a quick scan that will ID any infections.
    Then get the newest drivers for those two devices from Dell's support site.
    Before you install the drivers, remove those devices in Control Panel.
    Mar 20, 2010 | Dell Latitude D800 Notebook
    Dell D800 laptop cooling fan issue
    If you want to know all the details of your hardware software ect...
    I would recommend downloading SIW http://www.gtopala.com/
    If the computer does boot up I would simply suggest buying a replacement fan they generally only cost about $10-15 and take only a minute or two to replace
    Here is a link to Dell's part ordering page just select your machine type, if its custom made, you can remove the fan and find the part # on it and search Dell's site by the part # http://accessories.us.dell.com/sna/DellPartsFamily.aspx?c=us&l=en&s=dhs
    If you need further assistance feel free to leave a comment
    Nov 21, 2009 | Dell (6F858) Cooling Fan
    I need help with my laptop, dont vew the hard disc. I changed de disc and continue problem. I want know if there solution.
    If you changed the disk, go into the BIOS, find the boot order, and highlight it, press the SPACE bar to Enable the drive.  It should then recognize it and use it.
    Good luck.
    Mar 14, 2009 | Dell Latitude D800 Notebook
    Stanton C.314 CD tray wont open
    You can replace the cd drive by ordering another one from American DJ online.Give them the model number and replace about three multiple connectors in the same order you have the bad one. That will fix your problem.
    Jan 02, 2009 | Pioneer CDJ-800 Turntable
    Wind noise
    Alan,
    These windows are prone to air/water leakage, especially if the window regulator has been removed or replaced. There are no less than 8 adjustments that need to be performed in a specific order to achieve a tight seal, and to have the door open and close properly. I'm sorry I can't even start to tell you how to do these adjustments in this type of forum. I suggest you try and find a shop that has experience with this type of repair on your vehicle.
    Bret
    RepairPal.com
    Nov 09, 2008 | 1998 Volvo C70
    Dell latitude d800
    is it asking for bios password? if so get in touch with DELL if youre a second user of unit it will be harder for dell to supply you with pass unless you have details of original owner e.t.c there is a third party solution BUT I dont know if I can say here..put it this way ..where theres $$$ theres a way :)
    Dec 18, 2007 | Dell Latitude D800 Notebook
    Opening the case on Dell DJ 30GB
    I have the opposite problem. I have opened my Dell DJ 30 and removed the battery. Where did you buy the battery?
    To get access to the battery, you need to use a sharp knife (construction type). Cut the interface between the plastic bottom at the outside casing interface and remove the plastic in one piece. It is sort of glued to the bottom, but it comes off easy once the perimeter is free. Under the plastic cover, there are 4 philips head screws to remove a small metal covering plate. Once the plate is removed, you can see the connector for the battery. Remove the connector and then gently pull the battery out. There is nothing holding it in place except the friction of the other components inside. Mine came out easily. Now I need to buy a replacement battery.
    Dec 11, 2007 | Dell DJ MP3 Player
    LG Refrigerator LRBC22544st
    Take off the back panel and cut the insullation as in the photo and this will never happen again. What happens is the water gets trapped and then ice forms and builds up and causes the blockage.
    Aug 28, 2007 | LG LRBC22544 Bottom Freezer Refrigerator
    Washing Machines Logo
    61 people viewed this question
    Top Brandt Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
    john mabry
    Are you a Brandt Washing Machine Expert? Answer questions, earn points and help others
