Question about BenQ PB6200 Multimedia Projector
The fans are on all the time, no light though, the buttons on the unit do light up. Would this be the lamp?
The fans are on all the time, no light though, the buttons on the unit do light up. Would this be the lamp? No lights on POWER, TEMP and LAMB
Posted on Jan 10, 2011
My infocus IN1 projector won't turn on anymore.
It may be the lamp is out. Normally a projector will try & fire the lamp 3-5 times then shut down with a different color light like amber or red. If the lamp doesn't light then it could be the lamp or perhaps the lamp ballast that starts the lamp has failed. A stuck fan also causes similar symptoms. There's 2-4 fans in the projector if one is stuck or bad it will turn off within 5 seconds or so after the lamp lights.
Does your lamp light at all? Are the lights a different color after it shuts down? Answers to these questions help figure out what's wrong though it's impossible to say for sure without looking at it. I service almost all Infocus projectors if you would like a quote please reply with your email address or write me at prmhelp@earthlink.net
Good Luck,
Jim
Jul 24, 2009 | InFocus Televison & Video
Sony KDS60A200 won't turn on
yes, the 3 blink error code is a defolty fan, you can take the back of the tv off, it will most likelu be the fan that is faceing you on the left side, it is held bu 4 screws, take it out, (1 plug) and blow it off with canned air, or an air compresser, that will buy you a short time, you will need to order a new one on the sony website, sometimes blowing it out wont work, and sometines it will give you around a week
Jan 11, 2009 | Sony KDS-R60XBR1 60" Projection HDTV
Panasonic PT43LC14, blinking green light on the power button
Depends on how much tv you watch, lamps burn out after anywhere from 5,000 up to 8,000 hours also you xould have a bad fan if fan does not work lamp will not come on.
Dec 03, 2008 | Panasonic PT-43LC14 43" Rear Projection...
Panasonic PT43LC14 blinking green light on power button
Check your FAN if fan does not work Lamp will not come on ,also Lamps only last 5,000 up to 8,000 hours so every hour that set plays the lamp timer is counting .Go to E-Bay you can find lamps 99.00
Indicator lights on, no function, no fan, no lamp
Press the MENU button to display the "MAIN MENU", and then select "OPTION".
Press the ENTER button to display the "OPTION" menu, and then select "LAMP RUNTIME".
Press and hold the ENTER button for approximately 3 seconds.
The "LAMP RUNTIME" will change to "TIME RESET [POWER OFF]".
Turn off the power and disconnect the power cord.
This will reset the cumulative usage time for the lamp unit to "0".
Oct 11, 2008 | Panasonic PT-LB20U Multimedia Projector
Panasonic large screen Model # PT-61LCX65
Here is the proceedure to replace the lamp and reset the lamp hours.
Lamp Replacement Procedure:
1. Press the POWER button to turn off the power.
2. Wait for about 1 minute until the cooling fan stops.
Note:
The lamp cooling fan will continue to operate for about 1
minute after the power is turned off. Do not unplug the AC
Cord from the outlet until the fan has stopped. Avoid
interrupting the power by using circuit breakers or switchable
power strips.
3. After the cooling fan has stopped, unplug the AC Cord from
the outlet.
Note:
Please wait more than one hour before replacing the lamp.
[ Forced cooling function ]
If you need to replace the lamp more urgently:
- The Projection display has a forced cooling feature.
After the POWER button is turned OFF, and during the
first minute of the normal cooling fan operation, press
the VOLUME UP button on the unit and CH UP key on
the remote at the same time for more than 5 seconds.
The cooling fan operates for about 10 minutes. (LAMP
LED will flash 5 times every 5 second and POWER LED
will flash red for 10 minutes.)
4. Remove the Front Cover Unit from the latches.
5. Turn the Knob to the left.
6. Pull the Lamp Cover out.
7. Loosen the Screw on the Lamp. Then, pull the Lamp.
Note:
Because the Lamp may still be hot, use caution when
handling.
8. Install the new Lamp, and tighten the Screw.
9. Install the Lamp Cover, and turn the Knob to the right.
10. Install the Front Cover Unit.
Lamp Time Reset Procedure:
Be sure to reset the Lamp time to "0" after replacing the new
Lamp.
1. Plug in the AC Cord, and turn on the power by pressing the
POWER button.
2. Press and hold the VOLUME DOWN button on the unit and
the SPLIT key on the remote together for over 5 seconds
in power on condition.
When the reset is finished, the display will indicate that the lamp hrs have been reset to 0 and the LAMP LED goes out.
Jul 26, 2008 | Panasonic PT-61LCX65 61" Rear Projection...
Canon LV-S1 New bulb but won't power up
Have you cleaned the filters? In this situation, the fan and power shuts down even before the bulb lights up and heats up the unit, but perhaps the unit can detect clogged filters.
You can download the manual here if you don't have one. Instructions for cleaning the filters are on page 37.
May 20, 2008 | Canon LV-LP12 Projector Lamp for LV-S1,...
try pressing and holding the enter button on the projector for about 30 seconds - this resets it. It worked for me!!
Feb 10, 2008 | NEC VT460 Multimedia Projector
Panasonic pt-50dl54j
The 3 times LED code points to no fan rotation. There are 2 fans. Check the larger fan first, p/n = FBL12G12LS, located near the lamp. Even though that fan may be rotating, it may be slow.
thanks
scott
Dec 20, 2007 | Panasonic PT-47WX51 47" Rear Projection...
Lamp will not strike error message
this can sometimes indicate either an overheating issue, a lamp service life problem, or that the cover to the lamp housing has not been secured properly.
Dec 14, 2007 | InFocus LP120 / 1000 Lumens / XGA / DLP...
BenQ PB6200 Multimedia Projector Logo
223 people viewed this question
Top BenQ Office Equipment & Supplies Experts
jasbo
jasbo
Tom Chichester
Electro Med Services...
Are you a BenQ Office Equipment and Supply Expert? Answer questions, earn points and help others
