Smart drive MW059 with fault code 3,5,7,8 wont fill starts and stops filling about 6 times then above fault code shown
  • Washing Mach... Master
  • 713 Answers
Hi Todd,Just read your posting.The fault you have is called OUT OF BALANCE SWITCH FAULT.Now the switch is located under the control module which in turn is located under the top panel.To access the control module remove the 2 screws at the back of the machine up top.Once the screws are removed lift the top panel away from the machine gently as the display wiring is still attached.You will now see the gray control module.You should also see a screw holding the control module to the frame,remove it and look under the gray board to the right.You should see a switch with 2 wires attached .Have you or can you borrow an electrical test meter to test the switch for conductivity on the terminals with the wires attached?If there is any corrosion on the switch terminals or the little button does not click positivity when pushed I think the switch will be faulty.You must have conductivity between the 2 wires.Make sure the power is off at the wall before you remove the top panel.If the switch is good then the fault could be you control module.Hope this helps and please reply on how you got on or for further help.Looking forward to your reply.
Posted on Sep 12, 2010
Smart drive 051 error code 32
Have you tried unplugging it and plugging it in again?
Nov 22, 2013 | Fisher and Paykel Washing Machines
Hello, I have a 10 year old Fisher & Paykel smart drive 9 pride 5.5 clothes washer. Model MW059. When i start cycle, water starts filling and then suddenly stops for a second or two and then repea
That sounds like a bad RPS, you would get fault code 130.
130. (10000010) Single Rotor Position Sensor Error
The Motor Control Module has found an error in the pattern received from the Rotor
Position Sensor. Likely causes of this fault are a bad connection on the harness between
the Rotor Position Sensor and the Motor Control Module, or a faulty Rotor Position Sensor.
Primary Source: Wiring.
Action: Check for corrosion on the RAST connector of the Rotor Position
Sensor and the Motor Control Module connector.
Secondary Source: Rotor Position Sensor.
Action: Check the Rotor Position Sensor with an R.P.S. tester. Replace if
faulty.
Tertiary Source: Motor Control Module.
Action: Replace Motor Control Module.
Quaternary Source: Rotor
Action: Ensure the correct rotor for this phase of machine has been fitted.
Service manual, You will need Adobe reader installed to view PDF's
http://www.angelsnz.net/ZL3SV/misc/F&P%20Service%20manual%20517735.pdf
Feb 13, 2012 | Fisher and Paykel GWL11 Top Load Washer
I have a Fisher and Paykal Smart Drive 053 washine machine. It has just started doing the following: Start load - Cold, warm or Hot and any size Fills intermittent. will fill for a couple of seconds...
Hi just read your posting.When the machine stops and starts does it beep and show an error code.This error code will be a series of lights that light up and the machine will beep.On the wash progress line of lights which lights are lit when the machine beeps,Is it the 1st and 6th or the 4th and 8th etc.Please reply with additional information and I am sure I can help you rectify this fault.Looking forward to your reply.
Jun 05, 2011 | Fisher and Paykel (IWL12)
Fysher and Paykel smart drive 051. takes ages to start. cold water flow seems ok. takes 2-3 times longer for full cycle. sometimes stops and hot water light flashes. yours, jagrat.
Hi just read your posting.Now what water temp have you selected for wash?Is it cold, warm, or hot?Sounds like a water flow problem to me.The water valves on your model of machine sometimes sound like they are filling correctly but they only let a little bit of water in.How long does it take to fill your machine and start agitating when you have selected low water level?Please reply with additional information and I am sure I can help you rectify this fault.Looking forward to your reply.
Aug 18, 2010 | Fisher and Paykel Washing Machines
When using the smart drive 051 the machine attempts to start filling (on a cold wash) then the water flow switches off after a few seconds and timing is inconsistent of the attempts to fill. After 3...
Hi just read your posting.Now when the machine beeps a series of lights will light up.They will be in a row of 8 lights.Starting from the left to right which ones are lit.Is it the 2nd and 4th or the 1st and 6th ---etc---?Please reply with additional information and I can help you rectify this fault.
Aug 03, 2010 | Fisher and Paykel Washing Machines
I have the fisher & paykal excellence 6-5 smart drive model gw609au when i first turn it on the seconds green light is flashing and it is trying to fill up but starts and stops all the time then just...
Hi Damian just read your posting.Your fault on your machine is the out of balance switch is faulty.Do you still require help?Please reply and I can guide you throe the repair of this problem.
Jul 02, 2010 | Fisher and Paykel Fisher & Paykel Washer
Machine wont fill
If you hear a valve or relay opening and closing (a small click), then check both of your hoses for signs of internal collapse and while they are off, clean the screens you may find in both ends.
If you see nothing amiss, open both of your feed faucets to make sure it is not a problem with the water supply itself.
Jun 18, 2008 | LG WFT1071TP Top Load Washer
Bosch
f is fill fault to much or not enough water or water in the sump white plastic base the f code will not go away until you solve the problem when the f code shows up the drain motor will run all of the time
Apr 01, 2006 | Bosch 24 in. SHU6802UC / SHU6806UC...
Washing Machines Logo
155 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
