Question about AO Smith 3hp Pool Pump Motor 2 Speed Ao Smith Electric Motor for Swimming Pool Spa Pump Bn62
Need internal wiring diagram for B383 spl - AO Smith 3hp Pool Pump Motor 2 Speed Ao Smith Electric Motor for Swimming Pool Spa Pump Bn62
  • John Prohaska
    John Prohaska Sep 13, 2010
    Please comment with the serial number as the internal connection varies over time. The serial number will confirm which connection diagram you need.
Where can I get an owner's manual fro this leaf blower?
You have here a manual for a leaf blower
http://www.echo.ca/getattachment/0dc771da-e269-4fba-b383-5de01103f4a4/Blowers.pdf
Maybe you shoud specify your brand and model for better result
May 15, 2015 | Garden
Internal Blue wire from "W"
Please check the bellow links to see the wiring diagram :-
http://www.tpub.com/content/photoprint/TM-10-3610-203-14/css/TM-10-3610-203-14_20.htm
http://www.pdfee.com/search/Air+conditioner+wiring+diagram
Please get back to us if you have any further query or else accept the solution.
Thanks for contacting fixya.com
Oct 27, 2010 | Heating & Cooling
I have a SPL phantom dk-3400 car amp and when i
Even withou the help of any diagram you have a visual indication. Look inside to the area of the burn. identify the component. check around the burned area for the cause of the burn. it could be the failue of the output or the power side. equipped with a multimeter you must be able to identtify stage by stage the short of the circuit. remove, replace and test. afterwards connect the woofer - check if your woofer coils are damaged too- Hope this helps? Good day
Jul 12, 2010 | SPL PHANTOM DK-3400D Car Amp
Amp goes straight to protecting
bad power supply or out put i hat to say it but spl is note a good company i would replace the amp
Jul 07, 2010 | SPL Dynamics CRM1200-2 Car Audio Amplifier
Why do the fuses in my amp keep blowing
You may not have they proper size wire to the amplifier. Most amps now recommend 4 ga. Also make sure your wiring to the speakers are at the proper Ohm load.
Dec 05, 2009 | SPL Dynamics XL2-820 SPL Car Audio...
Disassemble 88 SPL Lower Unit
I dont have a diagram to send you, but if you take the model number and serial number to you local Johnson/OMC dealer they have all the diagrams and have even photo copied them for me to use
Jul 24, 2009 | Boating
Spl 620 wn put out loud enough does have sound did i wire it wrong?
Hello ace_sterling,
Not knowing what you have the SPL-620 driving or knowing how you have it wired, it's rather difficult to determine if it's wired "wrong".
I show the SPL DK2-620 as being a 2-channel amp with 150 watts output at 4 ohms, or 180 watts at 2 ohms. Even if the power is somewhat overrated, it should provide more than enough power for a set of standard 2-way or 3-way speakers, or component speakers with a separate crossover.
Powering one or more subs is another thing. You would get sound, but the subs would not be very loud. In bridged mode, the amp is only stable to 4 ohms. So if you are trying to power 2 4-ohm subs, the best connection would be 1 sub connected to each channel. If you are powering only 1 sub, then the bridged connection would be best.
Hope this helps. If it does, please rate as "FixYa".
Apr 23, 2009 | SPL Audio Car Audio & Video
AO Smith 3hp Pool Pump Motor 2 Speed Ao Smith Electric Motor for  Swimming Pool  Spa Pump Bn62 Logo
180 people viewed this question
Top AO Smith Pool & Spa Experts
Jay Finke
Jay Finke
Steve
Colin Stickland
Colin Stickland
Are you an AO Smith Pool and Spa Expert? Answer questions, earn points and help others
