Question about Pyle PIFMDK6 iPod Car Stereo FM Transmitter w/LCD Display
Ia6420 what does this wireless fm transmitter do and how do you hook it up
The FM function starts off great but loses reception after a couple of minutes and now the AM function has so much static you can not hear
AM FM TV Reception Guide and Directory ยป FM Reception ...
www.amfmreception.com/fm-radio/fm-reception-guide
Coax is a source of loss of signal from the FM antenna to the FM receiver and can also .... I believe the FM sound quality would strictly be a function of the tuner when ...It picks up the least off the side, but it does pick up some of the side. ...... THE ELECTRONICS so as not to short anything or to start the Great Chicago Fire of ...Missing: video
How to Avoid Distortion in Audio/Video Transmitters ' eBay
www.ebay.com > ... > Audio/Video Transmitters
An audio / video transmitter, or AV transmitter, is a wireless device that sends audioand ... As with all wireless signals, one can experience distortion or signal loss. ... AV signals are usually transmitted via wideband FM (frequency modulation) ... that of indoor transmitters, but the range drops off significantly the moment an ...
Jan 17, 2016 | Audio Players & Recorders
How do I hook-up satellite radio
Although it's about $50, this is the best FM transmitter I've found so far. I use it primarily with my MP3Player, but the concept is the same for your satellite radio. It should have a 1/8" audio plug.
Simply plug this little adapter in your cigarette lighter, plug the 1/8" cable between your Satellite radio and the adapter, and tune your radio to the station on the adapter (you can choose another station if there is already something playing on its default station).
This works for me. I tried other brands and they all eaither had poor reception or died within a month or so. This one has been working for me for well over a year now GOgroove FlexSMART X2 Wireless In Car Bluetooth FM Transmitter with...
Apr 23, 2014 | Cars & Trucks
Forex fm transmitter start file
It is not worth time and money for parts to fix this. Replace it.
Dec 20, 2013 | Quantum FX FMT-7 mp3 Player Wireless FM...
Connecting mp3 car radio
If you radio has an Aux input then you can connect a audio cable from your MP3 player to the Aux input on your radio.
If your radio does not have an Aux input the you can use a FM transmitter device. Connect the MP3 player to the FM transmitter and tune your FM radio to the radio frequency on this FM adapter to listen to your audio book on your MP3 player.
Check out these WEB sites fro FM transmitters.
http://dx.com/c/car-accessories-799/car-audio-systems-707/fm-transmitters-players-710
http://www.amazon.com/Coby-CA-745-Wireless-Transmitter-Cigarette/dp/B000OTF6G0
http://www.popularmechanics.com/technology/how-to/gadgets/4307160
Feb 05, 2013 | Audio Players & Recorders
My GPS losses satelite if my MP3 is also connected
I'm thinkin that ur fm transmitter is interfeering with ur satilite signal. solution i suppose would be to purchase head unit that has sat and mp3 plug in capatible... or stop using ur fm transmitter while ur using ur gps.
Aug 01, 2012 | Navman iCN 320 GPS Receiver
WANNA PLAY MY XM FROM MY PHONE WIRELESS THROUGH THE RADIO
Buy the device 'FM Transmitter' and power up it in mobile charger hole.
If you want to make it happen through your phone then get a handset with in-build fm transmitter.
Set the frequency of the fm transmitter app. as same as in the head unit. Play a music in your phone or calls...
You have done it!!
Pls rate
Sep 24, 2011 | Pioneer DEH-P3700MP CD/MP3/WMA/WAV...
Station to get signal from FM transmitter
I put the transmitter closer to  the antenna and it periodically worked. So, I don't there is a specific station.
May 18, 2009 | Audio Players & Recorders
Technika fm in car transmitter
Tune in the transmitter to one of your car wireless stations - switch on - play MP3 player and it should work
Hope it works
Tony
Jul 11, 2008 | Pyle iPod Car Stereo FM Transmitter w/LCD...
STATIC/INTERFERENCE
&R=11812445&C=17577363&K=NBy0rr?h=2mv3s7&r=11812445 Your SIRIUS radio contains an FM transmitter that allows it to operate wirelessly through your car FM radio. We have determined that the output of this transmitter exceeds the limits established by the Federal Communications Commission (FCC). As a result, the unit may interfere with the performance of radios operating in areas adjacent to your radio. There are no health or safety concerns associated with this issue.
  • If you listen to your SIRIUS radio wirelessly through your vehicle's FM radio, then please review the solutions listed below and select the one that works best for you. SIRIUS will provide you the best solution at no cost.
  • If you use your SIRIUS radio only when docked in a boombox, or directly connected to your car radio or home stereo using audio cables or a cassette tape adapter, then no interference can occur and no further action is required, provided you have turned off your FM transmitter. To turn off the FM transmitter, first press the MENU button. Use the channel up/down buttons to highlight “FM Transmitter” and push the SELECT button. Use the channel up/down buttons to highlight the "FM On/Off" menu item and then press the SELECT button. Use the up/down buttons to highlight "FM Off" and press the SELECT button. To exit the "FM On/Off" menu, press the MENU button. Use the same procedure to turn off the FM transmitter if you use Solution 1 or Solution 2 below..
Solution 1 - Direct Wired Audio Connection: If your vehicle radio has a “LINE IN” or “AUX IN” jack, you can use a stereo cable to connect directly to your SIRIUS radio. This solution is the easiest to install and provides the best audio performance. Many newer vehicles provide the required audio input jack. It will normally be found on or near the front faceplate of your vehicle’s radio.
Solution 2 - Cassette Tape Adapter
: If your vehicle has a cassette tape player, you can use a cassette adapter that allows you to play your SIRIUS radio through the cassette portion of your vehicle radio. The adapter slips into your vehicle radio as easily as a cassette tape and provides better performance than a wireless connection. fcc_a_2.jpg
Solution 3 - FM Extender Cable Kit: An FM extender cable will provide a special transmitter antenna that allows you to obtain the best audio performance through your vehicle’s FM radio. This solution is easy to self-install, but does require that an easy-to-hide wire be run in your vehicle so the transmitter antenna can be placed in close proximity to your vehicle’s radio antenna. Using this FM Extender Cable Kit, you will continue to use your SIRIUS radio exactly the same way as you do currently. fcc_a_3.jpg
Solution 4 - FM Direct Adapter with Professional Installation: An FM Direct Adapter provides a wired connection between your SIRIUS radio and your vehicle’s radio. You will continue to listen to your SIRIUS radio through the FM tuner of your car radio, but the FM Direct Adapter eliminates the outside static and interference you sometimes experience when using a wireless FM connection. This solution usually requires professional installation. We will provide a certificate redeemable for installation at an installation center in your area.
Please go to www.sirius.com/optimize and select the solution that works best for you. If you have any questions, please call 1-(877) 635-5130. Detailed instructions will be included with your solution.
You will improve the performance of your SIRIUS radio and reduce the potential for interfering with adjacent radios if you properly tune your FM transmitter. Please see the FM Transmitter Set-Up Tips below for more information.
We are sorry for this inconvenience. We are confident these solutions will allow you to continue to enjoy the great music, news, sports and entertainment that only SIRIUS Satellite Radio can offer with no impact on your radio’s performance.
Sincerely,
SIRIUS SATELLITE RADIO
To tune your FM transmitter turn off your SIRIUS radio and tune through the FM channels on your vehicle’s radio to locate an FM channel (except 87.7/87.9) that is not broadcasting in your area. If you use an FM channel that is being used by a local broadcaster, it will interfere with the performance of your SIRIUS radio. Once you have located an FM channel that is not being used for broadcasting in your area, save it as a preset on your vehicle radio. This will become your SIRIUS preset. If you’re not sure which FM channels are not being used in your home or travel cities, you can go to www.sirius.com/fmchannel and search for an FM channel based on zip code.
Turn on your SIRIUS radio. In the SETTINGS or MENU on your SIRIUS radio, locate the “FM Frequency” adjustments. Set the channel number on your SIRIUS radio to match the SIRIUS preset on your vehicle radio. Refer to your user guide for detailed instructions on how to do this. The FM transmitter in your SIRIUS radio is automatically set to FM channel 88.1. This may not be the best channel in your area.
Jul 08, 2008 | Sirius Starmate ST2 Satellite Radio...
Pyle PIFMDK6 iPod Car Stereo FM Transmitter w/LCD Display Logo
599 people viewed this question
Top Pyle Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Are you a Pyle Audio Player and Recorder Expert? Answer questions, earn points and help others
