Question about Samsung Televison & Video
The screen is blue and says VIEDO 1 on it I have removed the batteries in the remote and unplugged the tv and unplugged the cable and I still can't get it to work???
  • 28 Answers
You have to change the input / source setting on the TV. Samsung generally call this "source". Look for a button for that name on the remote, or on the front panel. Press it until it's set to "TV" or "CATV" or "ANT" and the picture returns. You may have to pause briefly while changing sources.
If you still can't change the source, please provide the model number.
Posted on May 14, 2008
I cant get any of my inputs to change my kids hooked up the Xbox and now none of the inputs work for cable or DVD its just a blue screen with a no signal can anyone help me tonight please
Kindly check first if the batteries of your TV remote ( medium to change input ) are fresh. After that please check again the button on your TV remote for INPUT, SOURCE, or TV/VIDEO and it should give you input lists.
May 12, 2014 | Televison & Video
Remote will not respond. New batteries installed. I can change channels at receiver, but the remote will not do anything, even though all the led's on the remote will show lite when pushed. 6.4 ir/uhf...
Is the remote for TV 1 or TV 2. If it is for TV 2, the blue tab with the number 2 should already be on the bottom of the remote. If it's for TV 1, you need to remove the blue tab from the bottom of the remote and flip the tab over (should be a green tab with only a green 1 on it). Once you change the tab, see if you can change channels. If you can't, follow the instructions below.
At your TV 1 location on your receiver, press the System Info button to display the System Info on your TV. At the bottom of the screen, you should see Primary and Secondary Remote Addresses. Make a note of the remote addresses. With the new remote, press the record button. If this is the TV 2 remote (blue tab on the bottom), the secondary number may change; if TV 1 remote (green tab on the bottom), the primary address should change. Exit from all the menus on the TV screen till you are back to your TV picture - then try the remote.
If the above steps do not work, try the instructions below to manually program the remote to the receiver.
  • Remote to the receiver:
    1. Go to System Info screen.
    2. Hold down the SAT button until all mode lights light up.
    3. Enter a number between 1 and 15 using the numeric keypad on the remote.
    4. Press the pound (#) button.
    5. Once the SAT button blinks three times, press record. Note: If successful, the number selected in step 3 will appear in the System Info screen under Remote Address.
Aug 16, 2011 | DISH Network IR Remote Control
Blue screen help!
The TV is fine. You need to fined the original remote. Be sure you have a cable connection on the anttenna A RF connector. Push menu and find the input. Or maybe input menu...experiment and you will find and correct this. Seen this problem years ago, can't remember exactly what the remote reads. But it should not be serious.
Dec 24, 2009 | Mitsubishi VS-45607 45" Rear Projection...
Tv comes on for about two min and then turns off, can not goto any devices just a blue screen, but will let you set up chanel guide
if this set has a slot in the back for a cable card---unplug the set and remove the card---it is for HD channels---if set works with card removed--get a new card---they get messed up by upgrades and other problems--if the cable card is causing the problem--set will work normal on non HD channels with it removed
Aug 06, 2009 | Mitsubishi WD62627 62" HDTV
Television displays in blue , only checked all
For your remote problem, mine has stopped working a couple of times and here is what Sharp had me do: Take the batteries out of the compartment. Next press and hold down the power button on the remote for a count of 30 seconds. Return batteries and the RC should be reset. As for the other problem, I had a similar thing happen tonight, hence I am on this site looking for help. My remote quite working, so I did the above, to no avail. I noticed the channel number box was frozen on the screen. I could not turn the TV off manually and had to unplug from AC. I plugged it back in and got sound but no picture, just that bluish dark screen. TV would not turn off. Then I got nothing, no sound, no pic. I left the TV unplugged for several minutes, 5 or so, plugged it in and it did work and is working now, RC too. You might try unplugging it for an extended time.
Jun 11, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
No picture, blue screen only
Good Day;
It sounds like you have a lack of signal; 1. reset TV by unplugging TV & signal sources from wall for at least 5 minutes then plug back in, 2. Turn all eguipment on such as cable box, dvd & etc, then change the inputs from your TV's remote, if still no pix,only blue.
Good Luck.
May 01, 2008 | Mitsubishi WD-62725 62" Rear Projection...
Spontaneous program changes
No doubt ...
try to check out the memory module and the T board......
thank's
[Vrya]
Feb 24, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Ds3224
push reset on remote twice quickly
Jan 05, 2008 | Sanyo DS32224 TV
LCD TV picture is green
I just called Vizio and they said to unplug the TV, then physically hold in the power button on the TV for 2 minutes.
Nov 19, 2007 | Vizio L37 Television
Remote wont work TV goes off by itself
Hello, please take the batteries out from the remote. Best regards, Arpi
Jun 23, 2007 | Sony FD Trinitron WEGA KV-27FS200 27" TV
Televison & Video Logo
29 people viewed this question
Henry  Thomas
Henry Thomas
