Question about Microsoft Windows XP Professional for PC
When i shut down my computer, it automatically restart. i tried to correct it by removing the power and restart button before shutting down, still it would restart.
    President:
  • 2,291 Answers
If u have installed any new program then uninstall it , or restore ur pc,
It may be a fatal error that is causing the computer to restart. You can easily stop the restart problem by changing your system features to restrict automatic startup when your computer's having a problem. Here is how:
There could be spyware problem or some kind of antivirus. Scan it with good antivirus.
Use System Failure Settings to Stop Automatic Restarts.
1. Click Start and Open the Control Panel
2. Go to System and Maintenance, Click on System.
3. Select Advanced System Settings and choose Advance tab.
4. Under Startup and Recovery, click on Settings.
5. Under System failure uncheck Automatically restart.
Another cause for random reboots is that the computers processor is getting too hot. To check this, enter the computers bios during boot (usually by pressing Delete, F1 or F10 when the computer just starts) and there will be an option about the computers temperature (often under
Posted on Sep 14, 2010
My cursor is frozen and I can't logoff or restart the computer
unplug power supply take out battery hold power button for 30 seconds with battery out reconnect power supply without battery press power button if restarts correctly log off shut down disconnect power supply reinstall battery and power supply try again
Jan 01, 2014 | Toshiba Satellite Computers & Internet
My HP laptop restarts when I try to shut it down
Try checking if your power button is defective. Check if it's stuck.
Dec 20, 2012 | Computers & Internet
I restored T5048, but now it shuts down and restarts non stop ?
Shuts down and restarts the boot process automatically continuously. Try turning it off, then hit the power button and immediately start hitting the F8 key repeatedly until you see SAFE Mode. Scroll down and see if you see an option to Cancel or Stop automatic restart on system failure. If you do click that and try rebooting your machine. It should tell you what exactly is the problem so you can read it without it rebooting all the time.
If it's that you need a CMOS battery you're in luck. Just turn the computer off, remove the case, sit the computer on it's side, get a flashlight and look inside for a battery about the size of a nickel. Normally the size of the battery is CR2032 which can be purchased at Walmart or you local grocery or drug store for $5.00. Just use a small flat head screw driver to remove the old battery and pop in a new one.
Mar 20, 2012 | E-Machines T Computers & Internet
THE CURSOR WONT MOVE WHEN YOU ROLL THE MOUSE CANT CLOSE WINDOWS DOWN
Hold in the main power on button until the computer shuts down -windows will automaticly safley shut down .
once it shuts down restart it and hopefully the mouse problem will also be fixed
I hope this helps
Andrew a
Mar 28, 2011 | Computers & Internet
System shuts down automatically
Remove the battery and adapter. Press power button for 30 sec. Then connect the adapter. Press power button. When pc started, go to
control panel---->power options--->change plan setting--->
Turn off the display-never
Put the computer to sleep-never
control panel---->power options--->change plan setting--->advanced power setting
-set hard disk "turn off hard disk after" to never
-set Sleep "Sleep after" to never
-set hybrid sleep setting to off
-set hibernate after setting to never
Restart pc
Apr 12, 2010 | Lenovo 3000 Y410 Laptop
Laptop doesnt turn on when I press on the on/off button
Remove the battery for 10 minutes, put it back in, plug to power supply for an hour or two then try again.
Please don't forget to rate this
Mar 20, 2009 | IBM ThinkPad T20 2647 Notebook
My Dell Inspiron6400/E1505 restarts automatically after shutting
It looks like the traces of the Virus infections are causing the trouble. u still some dlls related to the virus infection.
Feb 23, 2009 | Dell Inspiron 6400 Notebook
The Computer has trouble restarting Windows XP. I have to shut it down and unplug it for at least 2 minutes in order for it to start normally past the black screen. Otherwise, it will keep restarting...
I'm guessing from what you are saying, that it will in fact boot to safe mode. the culprit is most likely a resently added program. my other favourite is thermal shut down. remove the cover (after it is shut down and power is removed) and see if it's filled with dust and dirt. when the case is off start the computer up. are all the fans working as well ?
Robert
Aug 27, 2008 | Computers & Internet
Shutting down problem
go to setup utility and load the setup default values.
Also go to desktop properties and select screen saver tab and then at the bottom a power tab then go to advance tab and select when i press power button select option shut down.
Jan 04, 2008 | Toshiba Satellite A20 Satellite A25 Series...
Microsoft Windows XP Professional for PC Logo
51 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
