Question about Dell Dimension 4600 PC Desktop
Carpencote, Fedarcyks is back, and ready to try again.....
First, to answer your question if I had a Pentium CPU on an AMD board, the answer is no. I continue to try MB, RAM, and fan only, but can't get the fan to even spin, still. SO, i bought from tigerdirect a barebone package, which included a tower, power supply (which may have been suspect), a K9MM-V AM2 MB, & AMD Sempron AM2 CPU, and 1024 DDR-2. Put this all together with my old heat sink & fan, and guess what, NO FAN!!!! I'm not a software guru, but I am a Mechanical Engineer & have worked on desktops before, so what do you think. I replaced this fan 1 month ago, so it shouldn't be blown; I will do a conductivity test to see if it's fried. If not, what else can I try. The MB has an internal video, so that can't be it, but I have not connected a CRT, assuming if the fan don't spin, something is wrong. Should I try a BIOS start? or what.
Fix my computer and I'll have nothing to say but good about Venezuela. Actually, thinkiing about trip to Curacao in August.
Regards, Steve Fedarcyk
Fedarcyks@msn.com
    Novelist:
    Scholar:
  • 148 Answers
Do not just check conductivity as some fans are speed controlled and you may have a sensor problem. see this wikipedia entry explaining various modern speed detection methods: http://en.wikipedia.org/wiki/Computer_fan#Physical_characteristics
Posted on May 15, 2008
Hi sir/mam, i have a gigabyte motherboard 7vm333m-rz n now i m presently in tis board AMD processor is running... can i change the processor by pentium 3 instead of AMD.
-> NO
It has a Socket 462 processor socket. (Also known as Socket A,
http://en.wikipedia.org/wiki/Socket_A )
This is strictly for AMD processors ONLY, and only for AMD processors that use this processor socket.
An Intel Pentium III processor, that is not a Slot 1 processor, uses a Socket 370,
http://en.wikipedia.org/wiki/Socket_370
List of Intel Pentium III Microprocessors,
http://en.wikipedia.org/wiki/List_of_Intel_Pentium_III_microprocessors#.22Coppermine.22_.28180_nm.29
Scroll down also.
{ If it states Slot 1 AND Socket 370, it means there are processors Intel made, that were that model, but could have been a Slot 1 processor, or Socket 370 processor.
Using the first example;
Pentium III 500E,
http://www.cpu-world.com/CPUs/Pentium-III/index.html
The first example on top, is an Intel Slot 1 processor style.
The rest of them on down are Socket 370 processors, EXCEPT for the Pentium III Xeon. (Zee-On)
It is a Slot 1 processor.
http://en.wikipedia.org/wiki/Slot_1
Want to learn more about computer technology? Post back in a Comment, and I will give you some links.
Regards,
joecoolvette
Jul 21, 2012 | Computers & Internet
Motherboard cpu
The motherboard you listed supports AMD processors, (AMD Athlon XP/ Thoroughbred/Barton)not Pentium.
Jul 13, 2009 | ASUS A7V400-MX Motherboard
Hardware upgrade required for autocad 2009
Your existing CPU will not work with that motherboard. The AM2+/AM2 processor slot is for AMD processors only. For this motherboard, you will need one of the following processors: Phenom FX / Phenom / Athlon 64 FX / Athlon 64 X2
Jul 06, 2009 | Dell Dimension 8250 PC Desktop
What are pentium III Equivalents
Athlon 1.3GHz cpu
Celeron 300A processor.
These are a few and courtesy of Tech Enclave here is a link about a place in China that produced a CPU called Godson II which is the equvalent of a Pentium III as well.
http://www.techenclave.com/cpu-mobo-corner/chinese-made-cpu-chip-equivalent-pentium-2595.html
Hope this helps.
Feb 27, 2009 | Intel Pentium 3 , 450 MHz Pentium III...
Intel Pentium Dual Core and AMD Athlon 64 X2 processors
I'd advise don't start thinking below E2180. As per the performance go, E2180 and AMD Athlon 64 X2 5000+ are almost same but E2180 runs cooler. If you are going to use dedicated graphics card, go for E2180 and if you want a CPU for Integrated Graphics go for AMD Athlon 64 X2 5000+ because most of the 780G/790X chip-based AMD-compatible boards offer superior IGP.
Best wishes...
Nov 04, 2008 | Computers & Internet
Problem with upgrading processor
Sounds like the processor you're trying to upgrade to isn't the same frequency. The processor, motherboard, and memory have a matched frequency. For example; a motherboard with a frequency of say PC4200 will only accept a processor and memory of a PC4200 frequency. If you try to use PC5300 memory it basically won't do anything, blank screen, or maybe a beep. The same if you tried to use a processor with PC5300 on the PC4200 board. The best way to find the frequency rating is to look on the memory. They class the memory by frequency, but rarely ever list the frequency for the board or processor. Research the new processor to find out the memory class and then see if it matches the memory in your machine. If it doesn't then the processor won't work. If it does, then new processor may not be compatible, and that means more research.
Jul 18, 2008 | Shuttle AV42 Motherboard
Carpenocte, Fedarcyks is back; we were disconnected last week; have tried new things....
well, if the powersupply whent, then everything is gone and you may need another fan. tis' the way of the powersupply. just try gettin g a new fan! now, does the computer start to boot when you try to turn it on with the fan not working? if it does, then that's good. if it doesn't, then try replacing the power switches in the case(or checking them first at least). hope that helps!
May 14, 2008 | Dell Dimension 4600 PC Desktop
Biostar K6M800-AM2
Hello, just wanted to answer your request... last time chat was stopped or something like that cuz I waited a long time but did not get any answers to the last thing I told you. (you told me that you were using a Pentium 2.8... but your motherboard, if it is the model you posted in your problem... is for AMD processors, so it is imposible for that CPU to work on ***********... Im just taking what you told me, if you are sure you have a pentium then this is completely useless... if you need, get back to me, G luck!
May 01, 2008 | Biostar K8M800-M7A Motherboard
Upgrade P5RD1-VM motherboard to the gaming PC
Your pc is not for gaming right now because you are using Intel Pentuim 4 Mother board and CPU. Amd Athlon is best for gaming. I have a AMD Athlon 4200+ X2 with 4gb Ram and Nvidia 6800 256mb OC. to upgrade your computer to a gaming pc. you will need to switch your motherboard and cpu for best performance on games. in order to do that, you might need a different case for your new motherboard. because the one you have might not be right for the AMD Athlon motherboard unless you have a custom made computer. other than that everything is set for you. if you have less than 1gb ram you might want to add more. because the games they are coming with right now is 1gb minimum or required.
i hope that answers your question.
Thank You
Dec 08, 2007 | ASUS P5RD1-VM Motherboard
CPU Upgrade-Which Sockel?
Here is some information may be useful to you. Intel processors Socket 1 169 pins 486 SX/DX Socket 2 238 pins 486 SX/DX/DX2 Socket 3 237 pins 486 SX/DX/DX2/DX4 Socket 6 235 pins 486 DX4 Socket 4 273 pins Pentium 60 en 66MHz Socket 5 320 pins Pentium 75 t/m 200MHz Socket 7 321 pins Pentium, AMD K6/K6-2/K6-3, Cyrix M1/M2 Socket 8 387 pins Pentium Pro 150 - 200MHz Slot 1 242 pins PII, PIII en Celeron Slot 2 330 pins PII Xeon en P III Xeon Socket 370 370 pins PIII, Celeron, Cyrix III Socket 423/478 423/478 pins Pentium4 Socket 603 603 pins Pentium4 Xeon PAC418 418 pins Intel Itanium PAC611 611 pins Intel Itanium 2 AMD processors Slot A 242 pins Athlon Socket A 453 pins Athlon, Athlon XP, Athlon MP and Duron Socket 754 754 pins AMD Athlon 64 Socket 940 940 pins AMD Opteron Conclusion: You can not upgrade beacuse Armada M700 has a pentium III processor with 370 pins. So the Socket 478 pinned pentium is not suitable. Advise: Try to exchange it with a new laptop or buy a used laptop for suitabl configuration
Oct 01, 2007 | Compaq Armada M700 Notebook
Dell Dimension 4600 PC Desktop Logo
46 people viewed this question
Alun Cox
