Question about Nikon D60 Digital Camera
My Nikon D60 flash has stopped working despite being in flash mode. Any ideas?
My D60 flash problem was that the flash would pop up, but would not flash. The release lever would keep "clicking"...it did no know that the flash was up. Since I was told that the min cost of sending it to Nikon for repair was $250, I downloaded a repair/service manual for the D60 from http://www.tradebit.com/filedetail.php/9029672-nikon-d60-service-repair-manual ($8.99)
This manual gives a step by step assembly and disassembly of the camera.
I actually lucked up and fixed my problem...
Problem Descripton/Solution (short version):
There was a tiny plastic collar at the flash hinge that got pushed back into the camera. This collar served to close a couple of contacts. I stuck a home made wire/double hook tool into the hinge clearance hole and pulled the collar out and snapped it back into place.
Problem Description/Solution (LONG version)
WARNINGS (based on experience)
1. Yes, the flash will still shock the **** out of you..even with the battery out. You will smell burnt hair/flesh.
2. Be careful of the tiny contact leaf springs. They are hard to bend back into the correct position.
3. The #00 screws are easy to strip out. Apply firm pressure, turn slowly, and make sure screw driver is aligned properly.
4. Proceed at own risk (to camera). Make sure your warranty really has run out. There are many ways to make things worse. You can back out now and buy an external flash.
All I had to take apart however was the top cover of the flash (two tiny screws on underside of the flash #00 philips head). I found that there are two tiny copper or gold "leaf spring" contacts that have to close to send a signal that the flash is up. These are located at the hinge where the flash wiring runs into a clearance hole into the camera (hole is a center of rotation of the flash). There is a small plasitc collar that fits into this clearance hole from inside the flash/camera base and through the flash housing at the pivot point and snaps into place via 2 plastic hooks or tabs (download/see repair manual). This collar serves to secure the flash housing to the base but also has a tiny pin sticking out that catches one of the contact leaf springs and closes the circuit. The problem is that this collar got knocked out of place and pushed back into the camera. I made a home made wire/double hook tool out of 22 gauge wire (see attached picture) and worked it into the clearance hole by pinching the hooks together and working it in. Go in above the flash wires (top of hole) since the wire path goes downward into the camera. With some work and luck I was able to hook the edge of the collar and pull it back out and snap it back in place.
I then put the flash cover back on and everything still seems to work.
My Hook Tool....
Posted on Oct 16, 2010
Will the nikon sb16 flash unit work with the Nikon D60
Yes. The trigger voltage of the SB-16 is well within the safety range of the D60 and other digital cameras. I use mine with my D90 without any problems. However, be aware that the SB-16 is a rather old flash, and will not work in the iTTL mode with the D60.
Oct 29, 2011 | Cameras
I bought a vivitar sf4000 flash, how do I install it in my nikon d60
you can easily snap the flash at the hot-shoe slot on the camera,
the flash is only working in preset mode P, S, A, and M only
Dec 27, 2010 | Nikon D60 Digital Camera
Nikon D60 diigital camera. taking pictures in auto mode and now unable to take pictures. flashing "F- - " with r16 code when pressing shutterbutton.
the lens needs to be set at its smallest f-stop to work properly on your camera. The F error is telling you that the aperure ring is not at the smallest setting(largest "F" number, most likely F22. turn the ring to F22 or whatever is the biggest number and it will work. there might also be a lock on the aperture ring to keep it from moving. Good luck, Worm1855
Dec 20, 2010 | Nikon D60 Digital Camera
How do I force the flash to go off on a nikon d60???
hi there,
to force the flash off, you can simply select the dial-mode to no flash option
please see pic attached below
hope this advice help you with your problem
Nov 09, 2010 | Nikon D60 Digital Camera
Light facial detail in my Nikon D60
Are you using the flash? If so, dial in some negative flash exposure compensation. Otherwise simply dial in some negative exposure compensation.
However, you will have to leave behind the Auto and the other point&shoot modes.
Dec 28, 2009 | Nikon D60 Digital Camera
Hello i have nikon d60 and the flash do not pup out
In what mode(s)? In the point&shoot modes the camera decides whether to pop up the flash. In PSAM modes you decide.
Dec 25, 2009 | Nikon D60 Digital Camera
WHY DOES MY NIKON D60 BUILT IN FLASH FAIL TO WORK IN DARK SORROUNDINGS AFTER BATTERY CHARGING AND DESPITE HAVING ALL SETTINGS IN AUTO MODE?
Hello
Thank you for using
FixYa for your problem
Always check the batteries first but if is it still giving the same fault, your camera is faulty. It should be taken to an authorized repair centre for a repair estimate. Very few digital cameras have any user-serviceable parts.
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Nov 30, 2009 | Nikon D60 Digital Camera with 18-55mm lens
Will the Nikon SB600 speedlight work with the Nikon D60 Camera. All the instructions mention all the other Nikon camera's but not the D60. Will the auto flsh modes work with the auto modes of the camera
Yes. The SB-600 instructions don't mention the D60 because the SB-600 came out before the D60 existed. Bear in mind that the D60 does not have a commander mode so you can't use the SB-600 as a slave.
Basically, as far as the SB-600 instructions are concerned, just pretend that you have a D40.
Oct 01, 2008 | Nikon Cameras
Nikon D60 Digital Camera Logo
809 people viewed this question
Top Nikon Cameras Experts
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
