Question about Dell Dimension 4600 PC Desktop
Carpenocte, Fedarcyks is back; we were disconnected last week; have tried new things....
First, to answer your question if I had a Pentium CPU on an AMD board, the answer is no. I continue to try MB, RAM, and fan only, but can't get the fan to even spin, still. SO, i bought from tigerdirect a barebone package, which included a tower, power supply (which may have been suspect), a K9MM-V AM2 MB, & AMD Sempron AM2 CPU, and 1024 DDR-2. Put this all together with my old heat sink & fan, and guess what, NO FAN!!!! I'm not a software guru, but I am a Mechanical Engineer & have worked on desktops before, so what do you think. I replaced this fan 1 month ago, so it shouldn't be blown; I will do a conductivity test to see if it's fried. If not, what else can I try. The MB has an internal video, so that can't be it, but I have not connected a CRT, assuming if the fan don't spin, something is wrong. Should I try a BIOS start? or what.
Fix my computer and I'll have nothing to say but good about Venezuela. Actually, thinkiing about trip to Curacao in August.
Regards, Steve Fedarcyk
Fedarcyks@msn.com
    Scholar:
  • 106 Answers
Well, if the powersupply whent, then everything is gone and you may need another fan. tis' the way of the powersupply. just try gettin g a new fan! now, does the computer start to boot when you try to turn it on with the fan not working? if it does, then that's good. if it doesn't, then try replacing the power switches in the case(or checking them first at least). hope that helps!
Posted on May 27, 2008
Installed pentium d 940 duel core. Will not boot. need solution
Assuming the new processor is compatible with your MB there are several things to check. Do you have jumpers on your MB to identify different processors? Can you get to the BIOS with the new chip installed. There are several settings in there that could affect your boot process. Lastly, is your BIOS compatible with the new processor?
Feb 20, 2013 | Intel Pentium D 940 32GHz 800MHz 2x2MB...
My notebook is Compaq Presario V3646TU, motherboard manufacturer: wistron Model: CD30 Version number: 80.52 Pristine CPU is T7250 My question: change CPU to T8300 or T9300,...
why do this, there is no benefit, (that you will see)
only HP can answer this, they now own Compaq,
no story told, buy a ***** motherboard
or just want to throw money on this old PC 2007 PC
10 years old now.
2 things must match the other chips, north and south bridge
and BIOS to change CPU.
the formore, HP fails to document clearly.
the BIOS changes lists on the HP site (we are not hp)
are"
last F13.
Adds support for Intel Pentium Dual Core Mobile T2310 and T2330 Processors.
and
Adds support for the new generation of Intel Core 2 Processor Family CPUs.
https://support.hp.com/us-en/product/compaq-presario-v3600-notebook-pc-series/3543723/model/3559132/manuals
your cpu aboe is gen 8 an 9
last one certified for this pc is G7
the fastest on certified was
intel Core 2 Duo processor T7500 - 2.20GHz (Merom, 800MHz front side bus, 2MB Level-2 cache per core, 65 nm process technology)
i will attempt to show the HP parts surfer data nexe.
click processor here.
you never posted your PC, service tag so answers will be weak.
the p/n was not posted by you, like GJ831AV
or the the other 40 models seen here.
http://partsurfer.hp.com/Search.aspx?type=PROD&SearchText=GJ841AV
why not ask HP and not fixya, HP is real....
the real deal here. HP
https://h30434.www3.hp.com/
Oct 21, 2017 | HP (302203-001) Motherboard
I have a gateway 831gm. it has an Intel (Augsburg) 915G Motherboard and a Pentium 4 630 cpu 800MHz fsb & 2MB L2 cache. i've been looking for a cpu upgrade and saw that the Pentium E5200 Dual Core has...
If both motherboards are LGA775 socket, then the next concern is whether or not the case is capable of having the new motherboard installed into it. Disconnect all power cables to all dv drives or cd drives and hard drives. Disconnect all ribbons from drives to the mother board. If you can get to all of the screws that hold the motherboard into the case, you get away without removing drives. Once you've got the motherboard then you can disconnect the power cable from the motherboard. Remove the memory chips, disconnect the sound cable from the old motherboard. install the memory chips onto the new mobo, Connect the power cable to the new mobo, then install the new mobo into the case. Replace the ribbons from the drives to the mobo, replace the power cables to the drives and reinstall the sound cable to the cd or dv drive. You should be done now.
Dec 13, 2009 | Gateway 831GM PC Desktop
Abit ip95 mobo
You should really check these things first or consult the motherboard documentation which lists in great detail what the board supports
Get yourself a new manual if youve lost the one that came with it
ftp://ftp.abitshop.com/pub//manual/english/ip-95.zip
And to answer your problem , no you cant have a quad core
your specification says
"CPU - LGA775 Socket for Intel Core 2 Duo/ Pentium D/ Pentium 4/ Celeron D/ Celeron Processors with 1066 MHz FSB - Supports Intel Hyper-Threading Technology "
It would say "Intel Core 2 Quad" if you could
Try powering it up and it will probably either:-
a)Overheat
b)Spark and set on fire if theres not enough cooling
c) Cause a power cut , Quad cores take more power than the boards designed to support , otherwise they would have said i t supported quad cores.
d)Fry up the motherboard , making it useless
e)Fry up the processor , making it useless
f) all of the above
Jan 07, 2009 | Ziotek ATX Motherboard Standoff, 12 Pk...
My pc is extremely slow, I have even formatted and instal a new version of Windows Xp service pack 2 to my PC pentium-3 with 256 RAM but there is still no change. Need some one to help me out.
slow pc is the cause of many problems.
1=firstly,use disk cleanup.
2=secondly,regularly defragment your hard disk.
3=thirdly,try to switch over to pentium 4 3.0 Ghz or intel core 2 duo.
4=at last,change your motherboard to ddr2 Ram supporting Board.
Dec 30, 2008 | Intel Celeron 2.4Ghz Socket 478 CPU (...
Carpencote, Fedarcyks is back, and ready to try again.....
Do not just check conductivity as some fans are speed controlled and you may have a sensor problem. see this wikipedia entry explaining various modern speed detection methods: http://en.wikipedia.org/wiki/Computer_fan#Physical_characteristics
May 14, 2008 | Dell Dimension 4600 PC Desktop
We were disconnected last week; can we begin
The most important thing that I was thinking about is that you told me you were using a PENTIUM over a mother that is for AMD processors, make sure of that because if its as you told me, then you will never be able to fix that cuz its impossible for an INTEL cpu to work on an AMD plataform...
well it seems that if everything is well connected then your either your power supply is failing or not reaching the power demands or your motherboard is completely down... This is one of those cases where you only have to try and see what happens, thats why its hard for me to say whats happening whithout trying somethings...
things like: mother just with cpu ram and vga adapter over a table and booting it up. (what we already tried), then a bios restart.. (with the cmos jumper)... try a different power supply in case you have one.
stay in touch
May 05, 2008 | Dell Dimension 4600 PC Desktop
Biostar K6M800-AM2
Hello, just wanted to answer your request... last time chat was stopped or something like that cuz I waited a long time but did not get any answers to the last thing I told you. (you told me that you were using a Pentium 2.8... but your motherboard, if it is the model you posted in your problem... is for AMD processors, so it is imposible for that CPU to work on ***********... Im just taking what you told me, if you are sure you have a pentium then this is completely useless... if you need, get back to me, G luck!
May 01, 2008 | Biostar K8M800-M7A Motherboard
Hsf irs running
CPU or motherboard would be my guess. Try resetting the bios with the onboard jumper. Also could be a memory problem.
Nov 27, 2007 | EliteGroup Intel Pentium 4 Processor...
New processor
Usually you can use Northwood-core CPU-s on mobos with Willamatte-core CPU. But is important (exept core) - FSB support of your new processor. Which model of your CPU? What the mainboard use (model)?
Nov 15, 2007 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Dell Dimension 4600 PC Desktop Logo
42 people viewed this question
Alun Cox
