CANNOT COME OUT OF SCREEN ALIGNMENT.THE POINTER KEEPS ON MOVING TO 5 POINTS AGAIN AND AGIAN.
    Sergeant:
  • 420 Answers
Are you using a mouse that has ball instead of optical ./ id so.. there may be some dust in the gaps between that ball which causes the pointer to go upwards
Posted on Sep 12, 2010
What is wrong with an uncontrollable cursor?
When they put the palm rest back together it looks like they did not insert the ribbon cable end properly to the motherboard plug in, which would explain the erratic behavior. The laptop will need to be dismantled and checked.
Jun 15, 2012 | Sony VAIO P Series Pink Netbook Computer -...
I need the points gap for a 1940 dodge business coupe
Top dead center:*Set breaker point gap from .018 to .022*Bring #1 piston to "Top Dead Center"*The zero "D-C" mark on the vibration damper must be aligned with the timing indicator/pointer*Rotate distributor until points begin to open slightly, then tighten distributor*Start engine & allow to reach normal operating temperature*Set warm idle at 475 RPM*Use timing light to verify that the zero "D-C" mark on the vibration damper is in alignment with the timing indicator/pointer
Nov 26, 2011 | Cars & Trucks
T104R3 Timer moving but automatic turn no longer works I mistakenly released the pointer metal (should not do that) and reattached it, probably pointing to different time. the clock is working, but...
Replace trippers.
If timer dial is rotating and keeps good time, and manual override turns load on-and-off, then replace the trippers.
http://www.grainger.com/Grainger/INTERMATIC-Timer-Tripper-2E054?Pid=search
Stationary pointer points at 6:00 and moving it does not affect timer function.
The pointer is reference point for setting current time.
http://waterheatertimer.org/pdf/How-to-operate-and-set-T104-timer.pdf
Other resources:
http://waterheatertimer.org/How-to-troubleshoot-Intermatic-timer.html
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#T100
Add a comment for more help
Take a moment and rate answer for accuracy:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Oct 02, 2011 | RTO Intermatic T104R3 Timer Switch 220V -...
Mouse pointer keeps wavering in the screen. Im not
try to look for the proper signal, try to click the button on the mouse, or try to unplug it and plug it again.hope it work.
Sep 30, 2009 | Samsung Pleomax SCM-9000 Mouse
Printer will not align
Print cartridge
When the print cartridge contacts are dirty and the printer cannot detect/communicate with print cartridge.
Clean the contact points on the cartridges with a dry, lint-free cloth.
1. Open the top cover of the printer.
2. Remove the print cartridges.
3. Clean the copper-colored contact points on the cartridges with a damp, lint-free cloth.
Use a dry, lint-free cloth to remove moisture from the contacts.
5. Insert the cartridges back into the printer.
6. Close the top cover.
7. Try printing again.
If you still cant communicate try with new cartridge .
Hope this help. Please Rate My Response! Thanks!
Aug 27, 2009 | HP PSC 750 All-In-One InkJet Printer
Freezing or Jumping Mouse Pointer
This could happen if the PS/2 connector on the motherboard is defective, or if there is a failing component in the PS/2 circuitry on the motherboard.
Could also be due to loose solder points at the PS/2 connector.
This needs to be checked by a qualified technician.
Apr 12, 2009 | Foxconn 661MX Motherboard (FOX661MXMB)
My Palm Tungsten will not complete Screen alignment
sounds like the digitizer is out of alignment. there are places where you can send the device that will replace the screen, or send you parts for DIY projects. Depending on the age/condition of the device, it might be better to just buy a new or used device.
Mar 19, 2009 | Palm Tungsten E2 (Multilingual) Handheld
The small scrolling icon on Windows Vista
1-Firstly you go to system control panel(Start button->setting->Control panel)
2-select the mouse option and click
3-you see the 5 option under it,select the pointer options
4-under the visibility option unmark Display pointer trails &
Hide pointer whilt typing option
and also check the pointer speed option under pointer option.
5-than ok..
Thanks,
Feb 10, 2009 | Microsoft Windows Vista Ultimate Edition
Mouse cursor moving by itself
In windows xp go into start menu, then into control panel then click on appearance and themes, then move your mouse over to mouse pointers click on it , uncheck "enhance pointer precision, and click apply, that will stop the mouse from acting crazy, this will work with dell mouse pointers and most.
Dec 28, 2007 | Compaq EVO N600C (Refurbished) 14.1" LCD...
Xda 2s
it will not finish until alignment procedure is followed properly. tap the  point without movement until pointer goes to the next corner. better try again
Oct 20, 2007 | O2 Xda IIs Pocket PC
Computers & Internet Logo
David Payne
David Payne
